Question about Eureka Vacuums
Cord won't rewind
Won't rewind when button pushed in
2 Suggested Answers
SmartAlec
  • 171 Answers
SOURCE: Cord rewinder on a Electrolux model C102J vacum cleaner
Hi there Johnd, SmartAlec from Nelsonvacuums.com.au here. I fix vacuums full time for a living and the first time i had this problem with the australian version of this vacuum it tok me an hour to pull it apart and back together. now i have done a dozen or so it is about a 30minute operation. I dont know what you rate your technical skill level at but i give this machine a 8/10 for hardness. It is most likely that the cord has jumped off the reel and is wedged so it shouldn't require parts but it cant be done without nearly stripping it down. There is no reset or similar for the reel. My advice unless your very confident take it to a repairer. It would be 1/2 - 1hr of labour charge only i would think.
Hope this helps.
SmartAlec
Posted on Sep 02, 2009
VC248. Why won't the cord retract?
Vacuums today are most all plastic parts, and you have likely accidentally broken the retractor. Very highly likely you will be wrapping the cord around the machine from now on, as the repair parts are probably not available.
God bless your efforts.
Sep 07, 2015 | Cirrus Vacuums
How do I stop my miele revolution s758 from cutting out
If you pull on the cord's rewind and it cuts in and out, then the repair we do is to remove the rewind which is very simple, .....only one screw holds it in place!
Turn the rewind over so you can push the white take up wheel for the cord, and it will feel springy.
They are too springy some times when out of the factory and the 120V contacts will not connect to the line voltage.
Once you have pushed the white wheel in but not too much, drill a small hole in the brown shaft and slide a cotter pin through.
Remember not to push the white take up wheel in too hard while drilling because it will be too tight and the rewind will stick when you try and push the cords take up button!!!!!!
I hope this helps as it is the fix we use and have not had one come back for the same problem again!
William R!
Feb 12, 2015 | Miele Vacuums
My cord wont rewind
The rewind tension spring may be broken or fully extended. Try to yank hard on the cord and pull toward you with some force. Pull until the line will no longer come out and if it won\'t recoil then it needs to be repaired.
Apr 01, 2014 | Electrolux Vacuums
Won t turn on
Has it powered up for you before or did you just assemble it and aren't getting any power?
Mar 31, 2014 | Hoover Elite Rewind Bagless Upright...
The power cord does not retract or rewind when the button is pushed. How can I repair this?
Sometimes you can help get the springs working again, by gently pulling the cord out a little further and then let it slowly in while pushing the cord retract button.
Nov 08, 2012 | Kenmore 25512/ 25513 Progressive Canister...
Hope this helps.
SmartAlec
Sep 02, 2009 | Electrolux EL7055A Bagless Canister Vacuum
Kenmore progressive canister Sweeper
I figured it out ..by pushing the lever down and pry a screw driver into three different spots on the top, to release the rewind bar. Looks like three little j hooks hold it down. It took a flashlight and night time for me to see it.
Mar 19, 2008 | Vacuums
Power cord retrieval
Depending on which model you have, take the bag door or lid off by pushing it back and it will unhook and come off, there are 4 screws that hold the cover on over the where the cord rewind button is, take that cover off and you can get to the cord reel.
Feb 12, 2008 | Kenmore 23313 Whispertone Bagged Canister...
Vacuums Logo
12 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Irene Tulloch
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
