Question about YouTube Videos
Can't figure out how to pull front wheel bearings-jdeere gator
There seems to be no way to use a puller on these bearings as the manual suggests there is not enough room to insert any sort of a pullers fingers in the space available because of the spacer tube between the bearings
Is it possible to remove and replace front wheel bearings with out a press
In order to remove the front wheel bearings without press hub off the bearing and then the bearing out of the knuckle. To do the first step need a a Support Bridge.It is a special tool. Make bridge and use a general bearing pulled kit to replace bearings. use a "Front Wheel Drive Bearing Removal Adapters Puller Pulley Tool Set Kit" .To replace the bearing, remove front CV shaft taking care not to move the CV shaft too far out .
Nov 06, 2015 | 2002 Kia Rio
We replaced the rear wheels on the Gator and now it doesn't seem to have any traction or go as fast as before.
Take a tape measure and check if the back wheels are same diameter. They may have given you two different size wheels so one is too small. Some machines have bigger back wheels than front - so if they sent a front wheel and a back wheel (instead of two back wheels) one may be too small. If machine has any kind of suspension measure how long each side is to see if one side is stuck in the up position.
Jan 11, 2015 | Peg Perego John Deere Gator HPX Ride on...
Remove bearings out front diff halfes races
there a 2 tapered bearings on the crown wheel carrier housing ,remove the 4 bolts pull out the crown wheel. the bearings can now be removed with a split type bearing puller. I would take it to a machine shop .as the bearing preload has to be set up , the pinion back lash and tooth depth has to be adjusted. If you can't do this you will have all sorts problems .
Oct 02, 2014 | Interactive Toy Concepts R/C Polaris...
Instructions on replace wheel bearing on 2005 f150 2wd front wheel
Johny brown is wrong.... the 2005 ford f150 2wd requires a rotor/bearing assembly it is really really easy to change...... jack it up remove wheel, 18 mm wrench to remove caliper mount... then remove spindle cotterpin and nylon nut (26mm? ) with any luck the rotor/bearing /hub will pull right off ...if not a make shift lever/puller should do the trick.... I actually had a bearing frozen on the spindle that i used heat and a small 3 jaw puller to get the bearing free.... if everything goes smoothly you should be done in less then 30 min
Jun 13, 2012 | Cars & Trucks
How to replace Front Wheel bearing
Remove the wheel and the "end grease cap:. Pull the bearing off the shaft. You may need to buy a bearing puller to get it off.
Put all new grease on the shaft & bearing and replace the bearing.
Jul 28, 2011 | 1995 Toyota Corolla
How do i pull the hub off my 2002 mazda , on drivers side front
REMOVAL & INSTALLATION Except Miata FRONT
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Remove or disconnect the following:
    • Steering knuckle from the vehicle
    • Inner oil seal from the knuckle
  3. Using Mazda Hub Puller tools 49 G033 102, 49 G033 104 and 49 G033 105, pull the front wheel hub from the knuckle assembly.
  4. Remove or disconnect the following:
    • Bearing inner race from the front wheel hub
    • Retaining ring from within the knuckle
    • Front wheel bearing from the knuckle, using the hub puller tools
    • Brake dust shield
  5. Clean and inspect all parts but do not wash or clean the wheel bearing. The bearing must be replaced. To install:
  6. Using Mazda Press tools 49 G033 107 and 49 H026 103, install a new dust shield cover assembly to the knuckle.
  7. Using the press tools, press a new wheel bearing into the knuckle assembly.
  8. Install or connect the following:
    • Wheel bearing retaining ring
    • New oil seal using Installation tool 49 V001 795
    • Front wheel hub using the Mazda press tools
REAR
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section. NOTE: The wheel bearings are not serviceable. If the bearings are bad, a new hub/bearing assembly must be installed.
    • Rear wheels Fig. 1: Exploded view of the rear wheel hub and bearing assembly (disc brake model shown, drum is similar) 7923mg87.gif
    • Brake drum, if equipped
    • Rear caliper and rotor assembly from the hub, if equipped
    • Hub dust cover
  3. Raise the staked portion of the hub retaining nut with a hammer and chisel.
    • Hub retaining nut and discard it
    • Hub and bearing assembly from the spindle Fig. 2: When installing the new hub nut, be sure to stake it into the notch on the spindle 7923mg86.gif
    To install:
  5. Install or connect the following:
    • Bearing assembly on the spindle. Torque the new nut to 131-173 ft. lbs. (177-235 Nm)
    • Stake the nut into the groove in the spindle
    • Dust cover
    • Assemble the brakes
    • Rear wheel
Jan 01, 2011 | 2002 Mazda Protege
How do I replace the front wheel bearings on a
remove cv outer nut, tire brake caliper and lower ball joint use a bar to pry against lower a frame to seperate ball joint slip out cv axel then remove four nuts securing wheel bearing. I would have to check at home for exact instructions.
May 18, 2010 | 2005 Chevrolet Silverado
Wheel bearing replacement left front wheel Hello Everyone, I may need to replace the wheel bearing on my right front wheel of my Corolla wagon. How can I know for sure? And how can I find out how to do...
Diagnosing the bearings can be tricky depending on severity of wear. Typically - drone noise at highway speeds, squeeling, clicking or grinding noises at low speeds that reduce during braking, or pull off the wheel and brake assembly and check the bearing for slack or smoothness of rotation by hand. While doing this, check the brake assembly thoroughly - generally a more likely culprit of wheel noise.
Wheel bearing replacement is not for the novice backyard mech. - you will need pullers, press, etc. If you can get a rebuilt assembly - much easier.
Apr 23, 2009 | 1996 Toyota Corolla
Hub pulling problems
The front wheel bearing on you Cavalier is replaced as a assembly that unbolts from the back. You should not need a puller, it should pull off after you have removed the bolts and the axle nut.
Please let me know if this information is helpful. Positive feedback is appreciated. Thank You!
Mar 30, 2009 | 2002 Chevrolet Cavalier Coupe
Front Wheel Bearing Shot - Please help!
I might have the right size internal bearing puller at work. It looks a little like this... but uses a threaded bolt instead of a slide hamer.
Nov 10, 2008 | 2004 Aprilia Caponord Rally Raid
YouTube Videos Logo
14 people viewed this question
Top YouTube Computers & Internet Experts
Rizwan Hanif
Level 1 Expert
LP
Are you a YouTube Computer and Internet Expert? Answer questions, earn points and help others
