Question about Delta Plumbing
Delta 2467 faucet
Leak in spout.
  • 68 Answers
SOURCE: Faucet leak from the connection with spout.
Return the new faucet for another one. The o-rings in the base of the spout are leaking. Either installed wrong at the factory or defective rings.
Don't fight with it, trade for a different one.
Please rate this answer and Good Luck, Phil
Posted on Dec 29, 2008
SOURCE: water pooling at base of delta waterfall faucet spout
I have the same problem. The part that is needed is found with a simple Google search for "Delta Waterfall RP22934 O-Rings"
Simply Slide the collar up at the base of the spout where it swivels.
Gently open the now exposed split plastic retainer so that the tabs near the bottom are pulled from their holes.
Lift the spout off the base to expose the o-rings.
Replace with the new o-rings and apply o-ring grease.
Re-assemble and enjoy a dry sink area.
Posted on May 23, 2009
  • 297 Answers
SOURCE: repair leak on jasmine faucet - American Standard
you need to replace the 0-rings in side the spout between the base and neck,
Posted on Jul 22, 2009
  • 21 Answers
SOURCE: I need to replace the two o-rings and the bushing
The spout is locked in place with a nut. Loosen the nut, raise it above the spout post, and the spout itself will simply lift up towards the ceiling.
Posted on Nov 16, 2009
bearsfan7538
  • 119 Answers
SOURCE: HOW TO FIX LEAK ON AMER. STANDART SINGLE CONTROL
Replace the cartridge
Posted on Nov 28, 2009
I have a leak under my bathtub/shower it only leaks when the shower is on.It's not the drain or the pipe up to the shower head
There may be some leakage in pipe.Take the help of experts.Nowadays there are many leak detection services that can help in solving such problems.
find a leak in wall
Aug 02, 2012 | Delta Faucet Delta RP17453 Pull-Down...
Delta 2467 water flow has gotten very slow. Do I have to remove the whole faucet from under the sink, or is there a way to clean it out from up above. Already replaced the faucet cartridges and the...
Hi, i would suggest to check the faucet and make some adjustment for proper water flow and if you already replaced the faucet then this problem should not occur , i have had same problem and i had called A-General for this and they fixed easily all issues ,please take some help http://www.a-general.com
Jul 22, 2011 | Delta Faucet Delta 2457 Orleans Two Handle...
I have a Delta Tub/Spout Pull Down Diverter that has a pretty persistent drip. The HOT and COLD handles are turned off and seem to be as tight as they can be. After doing some research online I believe...
If your Delta RP17453 Pull-Down Diverter Tub Spout stops dripping after 5 minutes, your ok. If it never stops dripping, you need to replace delta faucet cartridge(s) behind the handle(s). This is were the water turns on and off and stops the water flow to the tub spout.
Delta faucets are some of the easiest to repair, and parts are usually available at any hardware store or home center. If you have a two handle faucet, replace both delta seats and springs and stems. If you have a single handle Delta faucet, replace the entire cartridge.
Jan 26, 2011 | Delta Faucet Delta RP17453 Pull-Down...
I purchased the Danco 80701 "Repair Kit for Delta, Aquasource, and Glacier Bay Faucets with #70 Ball" so that I can repair a leak in my Delta kitchen faucet. The instructions on the package are...
Sounds like the old style center-control delta type faucet, rubber washers describe older type but still good. The rubber seats have holes in middle, supply water to the cylinder which diverts water to the spout, and has a seal over top of ball allowing stem for handle.
Think they are talking about flex-hose type faucet accessory getting clogged, Maybe: lift the flex-hose faucet housing off the center-control faucet body? Water to it runs directly from center-control faucet and if broken seat gets in narrow line could inhibit spray.
Kitchen faucet spout too has an O-ring under where it connects to the faucet body. Unscrew large nut where meets the faucet body unit (slip-joint pliers), once free of threads, spout should pull straight up, easy or slight tug. I use bent paper clip to remove old one trying to save it in one piece so as to get exact size (that's important) to replace, push on one side then other.
Jan 13, 2011 | Microwave Ovens
Hard to turn spout side to side
Remove the spout and apply a thin coating of plumber's waterproof silicone lubricant to the O-rings on the spouts mounting post. If the spout is still difficult to turn, replace the O-rings. Here is the link to the delta waterfall parts breakdown.
Sep 04, 2010 | Delta Faucet Delta 172-SSWF Waterfall...
I have 5 of these faucets in my home that was built only 2 years ago. All of these faucets leak from the spout. I have replaced cartridges and they still leak.
Did you replace the seats and springs under the cartridges, Delta part number RP4993. These are the more important parts to replace when your Delta faucet is dripping from the spout.
Sep 03, 2010 | Delta Faucet 2578LHP/H277 Leland 4''...
I need to replace the two o-rings and the bushing for the spout of a Delta 2467 series. How do I get the spout out?
Nov 16, 2009 | Delta Plumbing
My delta faucet pull down diverter tub spout is
It sounds like it could be manufacture defect. Take it back for a new one.
Sep 28, 2009 | Delta Faucet Delta RP17453 Pull-Down...
Delta Faucet (Series 2467) Sprayer doesn't work
Yes, the diverter assembly is probably corroded or clogged shut. Garunteed its the problem on a 10 year old delta kitchn faucet.The diverter routes water from the spout to the sprayer when the sprayer is triggered.
Jun 02, 2009 | Delta Faucet Delta 2457 Orleans Two Handle...
Water pooling at base of delta waterfall faucet spout
Nov 25, 2008 | Delta Faucet Delta 172-SSWF Waterfall...
Plumbing Logo
Top Delta Plumbing Experts
Donni Steen
Ed Mac
john h
Are you a Delta Plumbing Expert? Answer questions, earn points and help others
