Question about Hunter Ceiling Fan Light Remote Control
Transmitter remote 175-776
I changed the battery in my wireless remote transmitter sku#175-776 model 7067r. As the prior battery went dead. Now the fan and light doesn't work. Please help
  • 323 Answers
SOURCE: remote not controling fan
You either have a bad receiver or the receiver isn't wired correctly,
On the receiver house wire side are black, white, and green.
On the receiver fan side are white, black, blue, and green. The black is hot for the fan, the blue is hot for the light. They can be wired together from receiver to fan.
At the bottom are a blue and a white wire to go to the lights.
Sometimes when installed the receiver is placed so that a part of the wiring box obstructs the signal from the remote and it doesn't work properly, or misses some commands.
I recommend buying a new remote and receiver and wiring the receiver in so that it rests on the sheetrock beside the wire in box.
Posted on May 26, 2009
  • 2841 Answers
SOURCE: remote control will not turn on/off fan or light.
The transmitter is the remote. The receiver is located inside the fan mounting bracket next to the ceiling. If you replace it make sure to set the dip settings on the new receiver exactly as they are on the old one. Wire the new receiver exactly as the old one is wired if it was working before.
Posted on Nov 07, 2009
SOURCE: 2006 Hunter ceiling fan remote transmitter
The problem turned out to be the fans, not the remote. An electrical surge fried the electronic componants.
Posted on Mar 26, 2010
  • 6 Answers
SOURCE: Hunter ceiling fan 52 ",
Hey dale. Sounds like either the integrated remote pack inside the fan housing might be bad, or the reversal switch part. If it has a switch on the fan housing to change it from forward and reverse, you could try going to a hardware store and replacing that switch. If that doesn't work, then it is probably a bad remote receiver pack iside the fan, it will be a bigger, probably black little box. If this is the case, your better off getting a new fan, as it will cost about the same. If your fan doesn't have a little switch to change blade direction, 9 out of 10 times it is the receiver pack. If your fan does have a switch for fan direction, there is a good chance it is a bad switch. It could also be both. After 10 years with the fan, you might seriously want to consider purchasing a new fan.
Posted on May 21, 2011
SOURCE: my hunter ceiling fan remote batteries went dead.
Here's what you do. I just fixed mine. I had the same issue. Over time the rubber on the buttons will wear down and block the contacts. Take the remote apart. There should be two screws, take them out, the back should come off. you will see the electric board, one screw you take off. Flip it over and you will see the contacts on the back of the board. If there is a build up of rubber all you do is take a pencil eraser and lightly rub the contacts. This will clean them and then you should have no other problems. Hope this helps..
Posted on Nov 15, 2011
How to program remote control sku#33201048
I don't know what type you have but most have 4 dip switches in the transmitter & receiver. The dip switches inside the transmitter will be near the battery. Match the settings to the dip switches in the receiver.
Aug 11, 2015 | Televison & Video
Tip
Genie Intellicode Remote Transmitter Programming Instructions
USE ONLY WITH SERIES II ELECTRONICS.<br /> Older Transmitters and Receivers will not work with these new electronics. There are no Security Code Switches inside the Door Operators, Transmitters and Receivers.<br /> <br /> <br /> To Program Receiver <br /> Step 2-1 Locate the Learn Code Button and Radio Signal Indicator on the Power Head Receiver of your Door Operator.<br /> <br /> Step 2-2 Press a Transmitter Button once within 30 seconds.<br /> <br /> Step 2-3 Press and release the Learn Code Button<br /> &bull; The Radio Signal Indicator will blink approximately 2 times per second.<br /> &bull; The Radio Signal Indicator stays lit - SOLID.<br /> <br /> Step 2-4 Press the same Transmitter Button within 30 seconds.<br /> &bull; Radio Signal Indicator will go out.<br /> <br /> NOTE: If a second Transmitter Code is not confirmed within 30 seconds or if a different Transmitter Code is sent, the Radio Signal Indicator will blink approximately 4 times per second, then programming will stop. If programming stops, repeat Steps 2-2 through 2-4.<br /> <br /> Step 2-5 Repeat Steps 2-2 through Step 2-4 for each Transmitter, Wireless Keypad or other access device to be learned.<br /> <br /> NOTE: A maximum of 7 Transmitter, Wireless Keypad and other access device Codes can be stored into Receiver Memory at one time. If a Transmitter becomes lost or if you want to delete a Transmitter, Wireless Keypad or other access device, proceed to ERASING ALL RECEIVER MEMORY.<br /> <br /> <span style="font-weight: bold;">Multi-Button Transmitters</span><br /> <br /> NOTE: Only ONE button of a Multi-Button Transmitter can be programmed into a single Receiver. The other buttons are to control other Door Operators.<br /> <br /> NOTE: If you are replacing a lost or stolen Transmitter:(1) Erase ALL Transmitter Codes from the Receiver memory. (2) Reprogram the Receiver with the remaining Transmitters Codes.<br /> <br /> <span style="font-weight: bold;">Erasing All Receiver Memory</span><br /> <br /> Step 4-1 Press and HOLD the Learn Code Button for 10 seconds or until Radio Signal Indicator goes out.<br /> <br /> <span style="font-weight: bold;">ALL Transmitter Codes are erased from Receiver memory.</span><br style="font-weight: bold;" /> <br /> Step 4-2 Reprogram the Receiver with the remaining Transmitter Codes (Repeat Steps 2-2 through 2-4).<br /> <br /> <span style="font-weight: bold;">Step 5-1 Battery replacement</span><br /> &bull; Slide Battery Cover off of Transmitter back.<br /> &bull; Replace with new batteries.<br /> &bull; Slide Battery Cover back on.<br /> <span style="font-weight: bold;"><br /> Step 5-2 Visor Clip installation</span><br /> &bull; Slide Visor Clip into back of transmitter until it snaps into<br /> place.
on Jun 21, 2011 | Genie Company IntelliCode GICT390-1BL...
My Ford Focus car doesn't centrally lock anymore, I have to use the key. It's not the fob battery because I changed it.
Sure you did put in a new battery? sure you did insert it correct? not the other way around? sure you did use the correct battery? like CR23 or AAA?
Sure all contacts in the battery compartment and on the battery are clean and shiny?
just a few things you could check.
Feb 09, 2015 | Ford Focus Cars & Trucks
Can't get outside temp on my atomic clock
If you still have the instructions read up on pairing the transmitter to the clock. You'll need to do that every time you change batteries on the outside transmitter. If you don't have those instructions , go to the clock's web page to get the manual for your model of clock.
Sep 23, 2014 | Home
Remote transmitter stopped working, changed battery, reprogrammed opener and it works but now only at a very short distance - about 1 -2 feet. Is this a transmitter issue or the opener?
There is no way to tell if you only have the one transmitter. If you have another remote or a wireless keypad that is working normally then it is that remote.
Jul 07, 2011 | Sears Craftsman LiftMaster Chamberlain...
Cordless keykeyboard went dead have changed
Hit the reset button on the keyboard or on the transmitter so you can pair the keyboard with your pc.
Apr 19, 2010 | Logitech Wireless Access Duo Optical...
Keyless remote wont work
try to reprogram the remotes using these instructions..........
i assume for 02 explorer not th 05 frestyle listed (although similar procedure)
Remote Transmitter Programming NOTE: All remote transmitters are programmable and must be set at the same time.
  1. Make sure that the anti-theft system is not armed or triggered and key code programming is not active.
  1. Open the door, then press the driver door lock control switch UNLOCK button.
  1. Turn the key from OFF to ON 8 times within 10 seconds, with the eighth turn ending in ON. If the program mode is sucessfully entered the doors will lock and unlock to confirm.
  1. Press any button on a remote transmitter, and the doors will lock and then unlock all doors to confirm that the remote transmitter is programmed. All remote transmitters must be programmed within 20 seconds of each other. Up to four remote transmitters can be programmed to the vehicles security module each time programming mode is entered.
  1. If the door locks do not respond for any remote transmitter, wait several seconds and press the button again. If the door locks still fail to respond, refer to Locks, Latches and Entry Systems — Late Build or Locks, Latches and Entry Systems — Early Build in this section.
  1. NOTE: Exiting is acknowledged by locking and unlocking the doors if at least one remote transmitter has been programmed.
    Exiting the programming mode is accomplished if one of the following has occurred:
    • The key transitions to OFF.
    • 20 seconds have passed since entering programming mode or since the last remote transmitter was programmed.
    • Four remote transmitters have been programmed.
Jun 02, 2009 | 2005 Ford Freestyle
Terk wireless transmitter
Hi Sleopard,
Wireless transmitters should allow broadcasts of a single source such as a VCR, DVD player, or cable boxes. They normally wouldn’t be able to transmit something like a cable signal to your television. One way this could work is if you connected a cable box right below your outlet and then connected the cable box to your transmitter. If your transmitter has a infrared extender you may be able to change channels by pointing your remote at the wireless receiver.
Cordially,
Agent Jon
Go Ahead. Use Us.
Apr 13, 2008 | Televison & Video
Temperature Transmitter
You need new SioScan Temperature Transmitter 433 MHz. Take a look on amazon La Crosse Technology TX6U Wireless Temperature Sensor for 433 MHz units.... Hope this was helpful. cheers
Oct 16, 2007 | SkyScan 86709 Atomic Wall Clock
Dryers Logo
130 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Brandon Berry
Brandon Berry
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
