Question about Winchester Optics
Gun felll,shot 1 time ejected didnot lift shellin gun, bolt cameapart
  • Winchester Master
  • 653 Answers
Take it to your local gunsmith.
Posted on Mar 15, 2015
I have a question on a 775a Savage.
Hello Stephen Godfrey...
I have a SAVAGE pump...
That I have had since I was young
( long time gone (at that time it was old))...
When one of my "friends" felt compelled to DRY-Fire it...
(which I was trained to NEVER do) the firing pin emerged from the BOLT.. and stuck (in such a way as to crush the primer well before the BOLT would be locked (I poured my favorite gun-smiths
sources... and contacted my munitions mentors... BITTERLY COMPLAINING about my inability to get any meaningful numbers ...
With some fiddling... measuring and looking in SAVAGE
catalogs... I was informed that I had a PRE 1958...
model 30, 12 gauge
... and to concern myself no
further about the TOTAL LACK OF ANY NUMBERS...
Savage DIDN'T do NUMBERS on shot-guns previous
to 1958
They ordered my new FIRING PIN... and it fit perfectly.
We all lived happily ever after.
The END.
Carnac the Magnificent
Nov 14, 2017 | The Optics
My Remington 1187 super mag will not eject shells once it has been shot have to play with it to manually eject them
Are you using light loads? Is the gun dirty? Too light a target load may be the issue. Also if you've shot many rounds through it, theweapon may need to be disassembled and cleaned to include the gas ports.
Sep 09, 2013 | Computers & Internet
My mossburg 600 jams up
when was the last time you cleaned the firearm. Look at the bolt action and ejector arm for movement should be fairly stiff
Mar 16, 2013 | Tools & Hardware - Others
My 94 which i recently purchased used is a 45 long colt.recently shot it and it does noy eject the fired cartridge and will not eject an unfired one either.what is the problem?thanks
Hi royfincher...
Your ejector clip/arm/rod is faulty.
It may be worn to the point that it cannot eject the cartridge because of wear.
But most likley it is due to a cause below..
It may be due to trash/debris/unburnt powder around the ejector clip.
The clip should move a small amount to slip behind the cartridge case head to pull it from the chamber after it is fired.
Take the bolt apart and clean and oil the ejector clip and assy. with a good grade of gun oil.
Also check the chamber, they may be some dirt/debris/unburnt powder,etc in the slot that the ejector clip fits into also causing your problem...if so clean it out with a metal pick, being careful not to damage anything inside the chamber.
After you have done the above, Your problem should be solved.
Please take time to rate me
Sep 08, 2011 | Garden
I have response trigger on my a5 and only shots one shot at a time when pointing straight. When i raise the gun to the air and shot it response trigger works. What could be the problem?
If you are using CO2 it may be affecting the system. With a gun down straight, you could draw liquid CO2 into the internals. A siphon tube can be installed in a CO2 tank to stop or manage this. If you have access to someone's air tank, try using HPA (high pressure air aka nitrogen). If it fires fine with air you have deducted that the CO2 is to blame. Simple. Switch to air. It's better for the gun anyway! Now if the air didnt change anything I would think a component of the response trigger system is to blame. I am not familiar with the response trigger( I use E-grips) but I would think that a part that may slide or move forward or bak when you lift the gun up would be to blame. Most local shops should be able to diagnose the problem. I did find an installation video by Tippmann on youtube.
Here is a link.
A5 response kit installation
Mar 31, 2011 | Tippmann A 5 Standard Paintball Gun
Looking to buy 5 shot mags 595/695 bolt action mossberg shotgun.
You can check this website http://www.gun-parts.com/mossberg/ Most of my friends buy their gun parts and accessories here. thanks
Jan 11, 2011 | 1&1 Soft Air Smith Wesson Mad Max...
WILL NOT EJECT AFTER FIRST SHOT. IT BELONGS TO MY FATHER-IN -LAW, I HAVEN'T SHOT IT YET BUT HE SAID THAT IT WOULD NOT EJECT THE FIRST SHOT. I KNOW THAT I'LL HAVE TO SHOOT IT MYSELF TO SEE EXACTLY WHAT THE...
If you are talking about a firearm 95% of the time this is caused by it being dirty and carboned up in the chamber and bolt face/ejector area. Give it a real good cleaning and you should get it working again. Also if it's a shotgun you may have to clean the gas tube/piston that is under the barrel. hope this helps you
Jan 12, 2010 | Sport & Outdoor - Others
Can not remove crank shaft pulley bolt
im a macanic for 25 year be carefull when doing what im gonna tell you use a socket that fit the crank bolt use a bar that gonna fit the socketthe bar need to touch the ground go inside the car crank the starter 1 shot but i can tell you enough to be carefull or if you got air use pneumatic air gun with chisel with percussion it should come off that owe we do it
Jan 17, 2008 | Baby Gear
Optics Logo
42 people viewed this question
Top Winchester Optics Experts
james laughton
james laughton
Colin Stickland
Colin Stickland
Andrew Taylor
Andrew Taylor
Are you a Winchester Optic Expert? Answer questions, earn points and help others
