Question about Whirlpool Inglis IP4400 Washer
My inglis washer stop on 17 minutes left
My washer stops with 17 mins left and error code nf comes up inglis
the dr
  • 447 Answers
SOURCE: keep getting SL error code
SL is a suds lock code it can be caused by the drain pump not draining the water, too much detergent, non HE detergent, or extra heavy loads, try running it empty, if code persits it is a computer failure
Posted on Sep 28, 2007
  • 4 Answers
SOURCE: Whirlpool duet washer problem
Our machine was giving the HF code at 37 min after over filling with water. I unplugged the machine, popped the top (took the 3 torx screws off the back) pulled the small hose off the pressure switch sensor (round sensor on the upper back right of the machine) and blew it out just by mouth. It obviously cleared some junk. It works fine now. (also unplugged the 6 wires on the sensor, turned it around and blew on that and heard it clicking, so I knew that was ok.) Hope this helps someone.
Posted on Feb 26, 2008
SOURCE: Whirlpool Cabrio Washer Error message code F1
I have started a petition to be sent to the CEO of Whirlpool Corp., Jeff Fettit.
Follow the link, and please sign it! The more the better! Spread the word!
You may also copy and post it to any other groups/discussions about this problem.
http://www.petitiononline.com/cabrio08/petition.html
Thank you!!!
Posted on Aug 02, 2008
SUPERMAN_B_1
  • 294 Answers
HELLO, Error code F1 indicates a control failure and most likely the machine control board will have to be replaced. Depending on when you purchased the machine, the board may be covered under extended component warranty.
I had the same F1 problem and they had to replace the control board and something relating to the balance. The tech told me this is a common problem.
Posted on Apr 06, 2009
SOURCE: whirlpool awm 8125/3 fault code FH
Probably too late, but here it goes:
FH means some cicle is taking too long time.
Replace the inlet electrical valve. It probably wont open enough and the water flow is not enough to fill to level in time. This should cost you 10€ and is easily done by anyone.
Just remove the top of the machine (two bolts on the rear and slide to the back), disconnect the valve (electrical and water input and output), push the lockers and twist the valve free.
Posted on Jun 02, 2009
Washer stops cycleing
First are you sure the error code is 'LE' and not 'tE' which looks very similar. The LE is usually the motor position sensor. Common on older washers. Easy fix. Under $20 part. The tE error is usually the thermistor. Inexpensive part about $6, but can be more complicated to get to. Ad a comment to your question and my answer with error code and I'll reply with more info if needed.
Jun 24, 2017 | LG WT4870CW 4.5 Cu. Ft. Top Load White...
FRONT LOAD WASHER samsung model WF338AAW/xaa
please see the cause and proceed to test the water inlet valve can be defective and replace it.use the common sense,see the diagram
God bless you
Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the preset water level after 10 Minutes or more at the time of initial water supply. The error status can be cleared by turning the POWER switch OFF and back ON.
Sep 19, 2012 | Washing Machines
It stops about 13 minutes from the end of the cycle, right before it spins. It displays NF.
""It stops about 13 minutes from the end of the cycle, right before it spins. ""
NF is no fill for the FAV6800A and FAV9800A are you still having the issue.
To me it sounds like you have two issues
""It stops about 13 minutes from the end of the cycle, right before it spins. "" with no additional info this could be a issue with the Clutch Pulley. Did you take any error codes like DC or UC?
Are you going to DIY the fix or call in a repair service?
Jan 26, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Code nf shows on my washer
unplug for 15 mins and plug again to rest
Sep 14, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
When i am on spin cycle it stops and has a nf error code! what can i do?
This error code, pops up usually when in the spin cycle, your clothes are out of balance, too heavy of a load, or even at times it can happen with a too light of a load. Just stop or pause your washer and re arranged the items inside,
Jul 08, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune TL
The machine needs to cut you a break;
“”i have a maytag neptune TL and there are several things wrong with it...1. I can't wash small loads it will stop at the spin cycle and flash dc””
This issue is a clutch issue see this post to DIY the repair.
“”it will wash fine on regular loads until it comes to spin cycle again and it will stop and flash nf””
This one is a little confusing the “nf” error is a No water fill error code. Check these two post for support regarding water inlet restriction or valve not opening properly.
nf post nf post 2
“”my fabric softener dispenser will not let the softener out neither will the bleach dispenser””
See this fabric softer post for support. The fabric softener dispenser may be clogged or the water dispenser valves feeding both dispensers may not be operating properly. The Service Manual on page 16 “Board Output Test” will give you support to turn on the Fabric Softener Valve and Bleach valve. See if you hear the valves operate in Service Mode”
My method may seem a little confusion for viewing water flow to the dispensers. This issue could be associated to the nf error you are receiving, restricted water flow (inlet screen clog) or cold water valve not working properly.
Post back for any questions or possible support I can offer. I’m an owner like you not a repair person but I’m very comfortable working on this machine. Rich
Jun 17, 2009 | Maytag Neptune FAV6800AW Top Load Washer
14 cycle front load washer fridgidaire
press cancel. (turns off washer)
press start/pause (wake up)
hold cancel and start/pause 10sec
last error code will come up.
E47 door lock error
check wires connections to the door lock..
replace door lock..
hope it helps
Aug 08, 2008 | Frigidaire ATF6000ES Front Load Washer
Whirlpool Inglis IP4400 Washer Logo
16 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
