Question about GPS
I have a touch screen navsure 300i and when i turned it on today a application error came up on screen also it want shut down
2 Suggested Answers
SOURCE: i have a navsure n420i
Take the SD card out and put it in your PC, go to the folder called Navigation and replace the Navigation.exe with this one. Hopefully this will work. (The file i am sharing is from my Navisure N420I's Satnav so it should work no issues).
http://hotfile.com/dl/110244854/dd4a70a/Navigation.exe.html
Posted on Mar 14, 2011
When i turn on my smartbook a thing pops up and says:: APPLICATION ERROR application explorer.exe encountered a serious error and must shut down ive shut it down at least 5 times now i need help!
See if going into safemode would get you the same error, if the error persists, then it could be hardware related issue if it doesnt, simply reformat your OS.
Jan 31, 2016 | Computers & Internet
Digitizer doesnt work
The Apple iPod is a handy device for listening to your favorite music, but mechanical issues can lead to frustration.
In particular, one problem you may encounter is a touch screen that ceases to function, whether completely or only on certain portions of the screen.
In some cases, a simple fix can solve the problem, while in others, a malfunctioning touch screen may be the sign of a more serious issue.Moisture
Moisture on your fingertips can cause an iPod touch screen to function erratically or not at all. Foreign substances such as hand lotion can also impact the touch screen.
A good practice is to thoroughly wash and dry your hands before using the device.
Wiping the screen with a microfiber polishing cloth can remove any debris accumulated on the touch screen, allowing for the direct fingertip contact necessary for proper functioning.
Barriers
Using a plastic sheet to cover the touch screen provides protection against dirt and smudges. However, the plastic can also create a barrier that prevents essential fingertip contact, especially if it is old and dirty.
Removing the plastic allows you to test the screen to see if it is hindering operation.
Wearing gloves when using your iPod may also inhibit the necessary screen contact, so removing them may also provide a remedy.
Ending Application If your iPod's touch screen freezes or becomes unresponsive when using a specific application, simply restarting the application may solve the problem.
First shut down the application; if this doesn't work, shut down the unit completely and then restart it.
Dead Spots
Instead of a completely unresponsive screen, you may experience difficulty only in specific areas. These "dead spots" are often the result of malfunctioning pixels, which are the components that comprise a digital image.
If you suspect bad pixels are causing your touch screen issues, notify Apple Support for repairs or even replacement.
According to the Tuaw website, Apple's policy has generally been to provide automatic replacement for iPods experiencing pixel problems.
Apr 11, 2014 | Apple iPod touch
Navsure n420i won't load
This is washers & dryers. Try posting in Nav.
Oct 23, 2017 | Washing Machines
I have a navsure n420i and soon as i try and use it a message comes up saying - application navigation.exe has performed an illegal operation and will be shut down can you tell me why this is please ...
Mar 13, 2011 | GPS
Just bought a new LG Axis smart phone today and after loading some applications from the application market on the phone, whenever I went to view an application I kept getting an error message that the...
A Hard Reset might help. it will bring lost file/folders back.
Also to turn on phone in safe mode, but not if cannot get passed initial Android screen.
Pull Battery to power off phone.
Hold Up Volume button, and power on button simultaneously until green android guy and DOS window open.
If Home key is solid button, then also hold
up vollume button, home button, power button.
use volume up and down to scroll.
Scroll down to Reset Manufacure Settings.
Use power button to select OKay.
Then select reboot system.
Mar 27, 2017 | Cell Phones
Phone has power just can't get to the main screen
carry it by a technician the phone probably needs to flash had that same problem with a w 300i and its works well up to today!!!!
Feb 27, 2010 | Samsung SGH-D900 Cellular Phone
When i try and play a application on my new itouch ipod 16gb it t
Hi Vicky-Joy,
it is always a good idea to turn off your ipod touch or iphone after installing an application.
To do this, hold down the sleep/wake button on the top for 6 seconds until slide to turn off apears.
Then turn the ipod back on again, and it should work properly.
Also bear in mind that it may be poor programing that is causing the application to crash and exit out of itself.
Hope this helps,
Nathan.
Apr 05, 2009 | Apple iPod touch
Mio digi walker 220
application MioUtility,exe has performed an illegal operation and will be shut down. if the problem persists, contact the program vendor
program:MioUtility,exe
Exception:0xC000000D
Address:8C06DF8C
Mar 20, 2008 | GPS
Imate jasjam
I would look at some third party applications that clear up the memory while you are on the PDA / JAM. You can also go into the settings function, memory and view running programs.
One of the earlier version flaws of Windows 2003 is that it does not offer a shut down menu on the Today Screen. There are quite a few freeware applications that allow you to shut down running programs. I tend to run one or two programs - maximum at a time. This is not a laptop. I find my touch screen unresponsive if too much memory is in use. It's not really the touch screen but that the computer can't follow my commands, almost like an old 283 or 386 computer.
Take a look for these tool bar/memory manager programs before sending out to service in Mumbai.
Dec 11, 2007 | i-mate JAM Pocket PC
GPS Logo
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
