Question about Weller WES51 SOLDERING STATION
Can i connect Weller WMRP iron or even the tweezers for smt desoldering on wes51?? cable connector is the same 5 pin
Can I interchange weller iron from newer smt tech pens for wes51?
  • 202 Answers
SOURCE: Hi!
Bill, i would use a connector with the correct number of ends made for a radio. you could probally find them at radio shack. be sure to connect the right wire to the right pin on each. you would need male and female. then the next question is yes four screws under the rubber feet
Posted on Jul 07, 2009
  • 33 Answers
SOURCE: I have a Weller 1002B soldering station. Haven't
Hi, I'm not sure the tip is defective. Check that the tip is screwed in tight. If it is not good and tight the tip will not get a good heat transfer from the solder wand. Hope this helps. If the wand will heat then the tip should.
Posted on Aug 30, 2010
  • 1267 Answers
SOURCE: Hi, I have a
See: http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=weller+WM17D+soldering+tips&x=15&y=19
Also Radio shack may have the tip at a larger price, but you don't have to pay shipping
Posted on Dec 10, 2010
  • 185 Answers
SOURCE: The tip of my weller
This happens quite frequently. On the tip there are two nuts that hold the tip to the gun. Tighten them a bit. The tip is made of copper and as this heats, it causes the connection where the nuts are to become a higher resistance and thus lower heat. When you tighten them, it "cuts" through the copper oxidation (caused by the heat) and lowers the resistance, hence more heat.
Posted on Jan 12, 2011
  • 185 Answers
SOURCE: soldering tip is not getting
I had a similar problem. I found that the cable from the transformer to the iron had an open in it. There are two spots where this mainly happens. At the transformer connector, or and probably this is it, at the iron entrance, You can remove the heater on the iron and take a voltmeter and see if you have power there. I found on mine that there was an open. I removed my cable, cut off the end at the iron and re-installed it. It was not easy but I managed to get it repaired. This is a kinda trial and error thing, mostly cables fail at the strain reliefs, this is where there is the most play in the system, and the constant flexing eventually breaks a wire. There are a number of places to get replacement cables, etc. Here is the one I use www. eaesales.com . Please let me know if this has helped.
Posted on Jan 28, 2011
I have Weller EC1002, WES51, and WTCPS all with base, cord, and handpieces (complete). On shelf for years. Can you test, quote and do repairs as needed?
yes but shipping alone would eat a lot of $$$
they r pretty basic - u should be able to do that urself.
a multimeter may be necessary
it is either
broken wire in cables
bad connection inside case
thermal cutout
bad tip
switch.
Jun 30, 2014 | Weller WES51 SOLDERING STATION
Weller WES51 does not heat up unless I turn to 700 degrees or higher
You may have a broken wire in the temp sensor in the tip of the iron or near where the iron connects to the base.
Jan 24, 2014 | Weller WES51 SOLDERING STATION
I have a weller EC1201A iron connected to an EC2100D base unit. It is a UK 240V model with digital temp set and display. The iron does not heat up. You can set the desired temp but the display just...
its my be the controler
http://cgi.ebay.com/New-weller-control-Board-EC1002-soldering-stations-/390286420305?pt=LH_DefaultDomain_0&hash=item5adee22951
good luck...
Feb 25, 2011 | Weller Welding Tools
Soldering tip is not getting heated up as well as led is not glowing .i am getting 26 V AC at the output of Transformer for my weller WES51
Jan 28, 2011 | Weller WES51 SOLDERING STATION
Unit does not heat up to temp and green light blinks
hi, i have faced the same problem with my station also. the issue will be only with your 6 pin connector, check whether all the pins are getting connected properly. some times when u apply force the connector's pin may go inside. check up with that.
Nov 04, 2010 | Weller WES51 SOLDERING STATION
I have two WU81 Weller soldering irons and their are both showing the same fault. When we turn the irons on in the morning, the 500mA fuse that can be found in the base unit is blowing. Is this a common...
Perhaps this fuse should be a "T" type or delayed acting (antisurge fuse) . If the fuse has been replaced by an "F" fast acting fuse then this could explain why they are blowing.
Aug 10, 2010 | Cooper Industries Weller Soldering Iron,...
NEED MANUAL FOR Weller soldering station WESD51 POWER UNIT
You can download the manual from here: http://www.weller-toolsus.com/MagentoShare/media/mannuals/WES51_OI_PL.pdf
Jan 19, 2010 | Weller WES51 SOLDERING STATION
Weller WMRP soldering iron faling prematurely.
I suggest that you set the "Auto Time Off" much longer or turn it off by setting it to 0, and use a standby of 400 degrees after 10 minutes instead.
The reason is that every time this soldering iron has to turn on, it's trying to heat up in about 5-10 seconds. When it does that, it applies full wattage to the heating element, and putting full wattage on them a lot of times is what's burning them out. If the soldering iron maintains the same temperature while not soldering, it only uses 20-30% of the full wattage to keep it at the set temp. This isn't nearly as hard on the heating element.
Aug 04, 2009 | Welding Tools
Weller WES51 SOLDERING STATION Logo
32 people viewed this question
Top Weller Welding Tools Experts
Lawrence Oravetz
Mike
Are you a Weller Welding Tool Expert? Answer questions, earn points and help others
