How does my mother hook up the antenna and get her TV to work (no cable)
First, you'll want to make sure that her antenna has a coaxial cable (one of the thick round ones) coming from the antenna. Some older ones have a flat piece of plastic with two wires sticking out. These are less efficient, but if you have one, use a balun (a vhf-uhf matching transformer) to change to coax. You can google "balun" if you don't know what one looks like.
Next, you'll need a digital converter box (if you don't have one already). Connect one end of the coax cable to the antenna (or balun) and the other to the jack on the converter box labeled "ant. in." Finally, using another coax cable, connect one end to the jack on the converter box labeled "to tv" and the other end to the jack on the TV labeled "ant. in." Finally, depending on your converter box, you will probably need to "scan " for tv channels. Follow the setup instructions with the converter box to do this. If you don't have the instructions, try googling the converter box company and model number to find the users manual.
I hope this helps, and good luck!
Sincerely,
Der Strom
