Question about Ingersoll Air Tools & Compressors
Ingersoll rand vr843 telehandler, won't go into reverse, and now in neutral it's in forward gear,and forward gear works fine
SOURCE: ingersoll Rand SSR compressor shuts down loaded or
When it shuts down, press DISPLAY SELECT button once and use the up down arrows to see the code just before shutdown.
HIGH AIREND TEMP
HIGH AIR PRESSURE
LOW SUMP PRESSURE
PRESSURE OR TEMP SENSOR FAIL
CHECK MOTOR ROTATION
MOTOR OVERLOAD
FAN MOTOR OVERLOAD
STARTER FAULT
I am assuming this has a Intellisys controller.
Posted on Sep 25, 2009
  • 243 Answers
SOURCE: i have an ingersoll rand P185WJD Compressor that
possible that one of the protections switch it off check oil levels motor and screw can also be a sensor, can check these by briging them one by one. first indication is control lamp. or possible fuel problem check filters and tank. also check wiring complete. is weak point for ir machines. good luck.
Posted on Feb 10, 2010
compman66
  • 169 Answers
SOURCE: what type of oil for ingersoll rand model 2475 air
Ingersoll Rand likes you to buy their all season select oil for their air compressors, most piston air compressors use an R+O 100 oil it is equivalent to n SAE 30 wt oil.
Posted on May 12, 2010
  • 205 Answers
SOURCE: what is a vsp fault 10 alarm Ingersoll rand
A VSD 10 fault is bus oscillation. Quickly rising and falling voltage. Recommend having power company check incoming voltage for oscillation.Voltage can not vary more than 3 percent or alarm is issued.
Posted on May 28, 2011
  • 1212 Answers
SOURCE: INGERSOLL RAND SS3P OVERHEATING OF CYLINDERS
Heat in that location noted is to be expected, but to the degree that it is should be of some concern.
When was the oil changed in the compressor last?
If you are running with a multiviscosity oil, use it only if the manual indicates it. Running straight weight oils, especially in extreme conditions is prudent insurance against failure. If you are running 10W20 for example- run 20 weight instead until regular air temps are below freezing- then the switching to 10 weightshould be a consideration..
The oil sump serves 2 purposes- 1- Coolant. 2-lubrication.
However I think the bearings in in the compressor are needing attention.
More because it sounds like there is an oiling problem in the compressor itself. At an absolute minimum it sounds like the head should be pulled to inspect for galling in the cylinder walls and to look for trace oil on the cylinder wall.
Posted on Feb 14, 2012
How to assemble an ingersoll rand sander 315
Gear timming in line sander
The above link may help as the unit is similar to the Central Pneumatic Straight Line Sander
Mar 02, 2015 | Ingersoll Rand Ingersoll-Rand IR 315 Heavy...
Replace reverse valve ir 2135
Did you ever get the 2135 reversal valve installed?
Jan 24, 2014 | Ingersoll Rand 2135Ti Air Impact Wrench
Ws550 eletric. i need the forward and reverse switch for my ingersoll electric wrench
Ask your IR dealer for this part > IR 201718 SWITCH, last price I saw was around $38.00
Sep 12, 2013 | Ingersoll Rand Ingersoll-Rand 1/2 in....
My directional control buttons on the gun are sticking
Ingersoll Rand impacts have o-rings that are mounted in the housing or on the valve that are susceptible to swelling and causing the reverse valve to stick!
if you know the model number, follow this link to find the appropriate manual to see the valve set up.
Ingersoll Rand Industrial Technologies On line Publications
Jan 31, 2011 | Ingersoll Rand 1/2" Air Impact Wrench Gun
I HAVE RE BUILT MY IR 231 1/2 IN DRIVE WITH REBUILD KIT 231-TK3 TUNE UP KITS..THEY WORK FINE FOR A COUPLE OF WEEKS. NOW I HAVE A BY-PASS PROBLEM. P.S. I USED ALL PARTS IN KITS, I EVEN DID A LIGHT BALL HONE...
never use a hone on a air tool cylinder! use 00004 steel wool! make sure the compression rings are concave facing up! then if the vanes have the cut out on one side put that to the bottom of air motor.
Jan 05, 2011 | Ingersoll Rand Ingersoll Rand Ir 231HA 2...
Runs fine in reverse, but will not run full speed
make sure the power /speed controll is set on high in both directions yes it can easily be rebuilt i can do it cheaper than most places, i have 30 years experience at fixing air tools - i worked for snap on tools also check and see that the front housing screws are equally tight.
Feb 18, 2010 | Ingersoll Air Tools & Compressors
Looking for the reverse button cannot find a part number
Try looking for a owners manual on the web under"Rand 213-KS- 1/2 ' Super duty air impact" or contact Rand.
Sep 23, 2009 | Ingersoll Rand 231C-KS - 1/2" Super Duty...
It turns weakly to loosen, and not very strong to tighten.Have removed the air chuck, and it is not plugged
Check to see that the power regulator dial is set to its highest number. The forward/reverse selector is also the power regulator and can be turned from 0 to usually 5. Look at your impact gun from the side and you should see the numbers next to the forward/reverse knob.
Sep 11, 2009 | Ingersoll Rand 231C-KS - 1/2" Super Duty...
Air Tools & Compressors Logo
41 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
