Question about Zumex Essential Pro Orange Juice Machine Orange
The screw from the top fell in and got jammed how can I fix it ?
Lanier ld040 paper jams
your web fell out, remove fuser,( lift handle on each side), take off web assy 2 screws 1 each side, rewind web and reinstall
Dec 03, 2013 | Lanier Ld 040 With Feed, Print, Scan,...
Door will not open
I had this happen to mine a couple of years ago .. due to vibrations the screw(2) there are two that hold it in place to the counter top which appears right above the handle to either side had lossened up and prevented the door from opening. I hope this is the case and if so you want the same lentgh screw but with a sloghtly wider tread to grab as the old screw will have made the hole it goes into bigger where it will not stay in place anymore unless you have a wide theaded screw..
It wil be hard to get it opened you will have to locate the screw that is causing the door not to open.. also it can be something along the sides of the dishwasher door getting jammed in the line of it closing and it has wedged itself in a way that prevents it from opening.. but once you do if this si the problem.. you have to do what i said above
I had to unscrew my mounting screws that hold it to the counter top which are along hte front under the lip of the counter at the top of the dish washer and slowly walk the dishwasher out from under the countertop.. take care not to pull it out too far as you have water lines connected.. dont need to flood the house..
GL
i honestly think that the sides of the dsih washer problem was a screw fell in around the gasket and caused me to have a small leak..after we fixed the door getting jammed..so i think it is your mounting screws..
Jan 02, 2011 | Dishwashers
Error message clear carrier jam, when I opened the top of the Dell Photo 926 a long clear strip fell out, What do I do to fix this.
if you can do the fixing then just open the cover and fix the strip othewise it will not work.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Dec 24, 2010 | Office Equipment & Supplies
Printer has been working fine. all of a sudden the paper started to load crooked and jammed. now it continues to do this...why?
Usually it's because something has fallen down the back where the paper goes. One person on here turned her printer upside down and shook it and a Bic pen fell out. I got one last week with a wood screw inside. sometimes I find push pins, candy or jewelry. If nothing comes out try looking inside with a light and small mirror.
Jan 25, 2010 | Lexmark X4650 InkJet Printer
I have a Yamaha PSR-170 that has a jammed key
Most keyboards of that scale are not especially fragile. You may have to remove the back (lots of screws) and maybe a bezel that is across the top of the keys to get full access to the keys. The good thing is you have lots of working models --- all the other keys. So carefully consider the differences. It may be that one or more plastic parts have broken, particularly if it fell and landed with pressure on that key.
Most of the keyboard manufacturers have parts departments that can supply just the part of the keyboard you need if you can specify exactly what you want.
Sep 19, 2009 | Yamaha Portable Keyboard
Individual package of detergent fell into lint trap of Whirlpool
HI, You should remove it. Here is how Normal 0 UNPLUG the dryer! Remove the two screws under the lint screen and pop the top up by inserting a flat blade screw driver in the gap between the front panel and the top. Remove the rear panel of the dryer and locate the four 5/16" screws that hold the lint screen housing to the bulk head. Pull the lint screen housing away from the bulkhead and reach in to remove the item that fell.
Please let me know if this help or if I can assist you further.
Thanks
Vic
May 28, 2009 | Whirlpool LER5636P Electric Dryer
One of the 3 tumblers inside the dryer fell off.
you actually open the top first if you look between the front and the top you will see two clips. push these in with a small screwdriver to lift the top. then there is two screws holding on the front to get it off.
May 21, 2009 | Dryers
Washer
If at first you don't succeed......
If you still don't succeed....... Call "the man" !
Jun 29, 2008 | Hotpoint Ultima WF860 Front Load Washer
Kenmore gas dryer. 70 series
sound slike something fell down there and is jamming the blower from turning. if the filter is ontop of the unit, remove the 2 phillips located under where the filter pulls out from. and the n remove all the screws on back panel youll see ( down the left side of unit ) the filter houosing, its secured by 3 5/16 screws toward the bottom portion of the housing, simply unscrerw and wiggle out, then remove the debris, and reassemble.
if the lint screen is located inside behind door, eitehr remove the bottom accesss panel or pop the top(with a screw driver approx 3 inches in from ither side of main top relaes the clips) the lid tips back revealing 2 screws holding front panel to the unit, after removing you will see the filter housing, still mounted by probalby 3-4 screws, remove the housing and retrieve the debris that has fallen down there
Apr 05, 2008 | Kenmore 74602 Gas Dryer
Front vent fell off
This should be a very easy fix. I assume you are talking about the plastic vent grill on the top of the oven above the door. There should only be a couple of screws holding it in from the top. The grill then should tilt out from the top first then from the bottom to remove. Since you said that it had fallen off, it sounds like the tabs where the screw holes are have broken off. This is a common problem. You can buy the part by ordering from the manufacturer, or from most repair websites. All you need is the model number from the microwave. Good luck.
Jun 19, 2007 | GE JVM3670 Microwave Oven
Zumex Essential Pro Orange Juice Machine Orange Logo
471 people viewed this question
Top Zumex Wine & Spirits Experts
deton8 von Splosion
Dave braun
Dave braun
guymark
Level 1 Expert
Are you a Zumex Wine and Spirit Expert? Answer questions, earn points and help others
