Question about Vizio VX32L Television
How do you remove the back of the vizio tv to get to the main circuit board
  • 4234 Answers
SOURCE: i have a vizio gv42lh tv just had main board
If the work was done by a service shop, you should have received a 90 day guarantee of the work. Please call the service center and indicate that the "repair" was not successful. They should resolve the problem without additional cost to you.
Dan
Posted on Jun 29, 2009
alpug
  • 1961 Answers
SOURCE: my vizio gv42l fhdtv 10a picture flickers like a
you need to check first the power supply board whether the output supply 12-24vdc for the inverter board is stable and not flactuating..you can measure the output voltage with a multitester..you get a voltage output of 12-24 with the inverter board is connected or loaded to the system.be carefull of the high voltage at the inverter board..once the output is stable replace the inverter board or you can measure the output of the inverter be very carefull..the output range upto 500vac.be carefull..if the high voltage is stable replace the lamps...tnx and good luck..
Posted on Jun 03, 2010
Testimonial: "Thanks again. :)"
SOURCE: 52" VIZIO LCD backlit with no display
Hi Crewzen,
I have the same problem as you. You just didn't mention which was the culprit. I assume it was the mainboard, correct???
Thanks
Posted on Jul 25, 2010
SOURCE: My VP504fhdtv10a vizio plasma TV when connect
Logic Control D Board got nothing to do with this problem. This is your main power supply gone bad(usually not the sub power supply). I just repaired my VIZIO by replacing main power supply. Just remove back cover and your board will be right in the middle of the screen. Just get board part/serial # and google it. My best price was through eBay(around $100). Everything is fine now.
Posted on Feb 07, 2011
  • 879 Answers
SOURCE: number one fuse on my main board is deadl vizio gv47l hd tv 10 amp
If fuse is dead, there must be some reason for that. Some short circuit or so. Without rectifying the fault, if you replace it with an other fuse, the fuse you insert will also blow out, and might make more faults to occur. The rating of fuse will be marked on the printed circuit board itself, very near to the fuse.
Posted on Aug 20, 2012
Have a dark band horizontally across vizio tv. Appears to be a backlight, but not sure how to fix
Could be a bad CCFL lamp, if the set usess CCFL back-light system. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jan 08, 2017 | Vizio Televison & Video
I have a Vizio E322AR tv, and the screen goes black after a few hours. The reset procedure brings it back to life for a while. Any suggestions on what may need replacing?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Dec 05, 2016 | Vizio Televison & Video
I have a Vizio E601i-A3. The "Vizio" emblem does not light up and the screen does not light up. Is it most likely power board that needs to be replaced?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Nov 26, 2016 | Vizio 60" E601I-A3 Full HD LED-LCD TV
How do I fix my Vizio TV which has no back light or display?
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board...
Nov 22, 2016 | Vizio Televison & Video
Have a Vizio TV: GV47L FHDTV10A. I turn on the TV, has sound but no picture. Did flashlight test & I CAN see an image when I shine the flashlight on the TV. Videos suggest an inverter slave. Any help?
Nov 06, 2016 | Vizio Televison & Video
My Vizio TV
Sep 30, 2016 | Vizio Televison & Video
My flat screen TV has a dark shadow in middle 3rd of screen the upper 3rd and bottom 3rd are nice and clear. Would this be LEDs starting to die?
back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Sep 26, 2016 | Vizio 42 in. LCD TV
VIZIO XVT553SV FLASHING BACK LIGHTS
Jul 19, 2016 | Vizio XVT553SV 55 in. LCD TV
Sound but no picture. Vizio E470i-AO
Sounds like Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.....
Jul 18, 2016 | Vizio Televison & Video
The power button on the corner of my TV lights up but when I turn on the TV the VIZIO logo lights up but immediately turns off and the screen stays black. What could be the problem?
May 27, 2016 | Vizio M190MV 19 in LCD TV
Vizio VX32L Television Logo
26 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
