Question about Canon PIXMA MP150 All-In-One InkJet Printer
Canon MP150 scanner problem.
I have had this printer for over a year with no problems.  Now when I try to scan I get this message.  "The scanner driver supported by this software is not installed."  I have reinstalled the program and the drivers several times.  I have even downloaded the lastest drivers and tried them.  I have contacted Canon support and tried everything they suggested.  The copy function works, the OCR portion works, the print function works.  The only thing that does not work is the scan function.  I use MP Navigator which came with the printer.  It also does not scan from other programs.  The only thing that I can think that I have done different is installed some generic ink cartriges that it thinks is low on ink.
  • 4 more comments
  • Anonymous Mar 16, 2008
    i have the same problem. i just connected the printer to a new comp. and then it shows the same message...
  • p_baller_1 Aug 24, 2008
    i need the scanner software, but whenever i download it, it still doesn't work
  • aproberts1 Oct 23, 2008
    I have the same problem with the MP970
  • sbr0 Oct 30, 2008
    Same problem with MP970. 3 hours with Canon support, still no luck.
  • davidslicer Nov 12, 2008
    I have the same problem with a Dell laptop and Vista. Everything worked fine with Win 98.
  • pmaldonado May 11, 2010
    I neeed an up-date program i could scan any document
I had the EXACT same problem at first and I somehow solved it. All I did was restart the computer, unplug the cables and replugged them again. Started MP navigator and it worked!
Hope this will help.
Posted on Dec 06, 2008
I have an HP Pavillion a6528p PC running Windows VIsta and got the same message for my Canon PIXMA MP150 printer when trying to run the scanner.
I fixed it by downloading/installing a new MP Navigator version 2.02 driver from Canon found here under "Software" after selecting "Vista" as my OS:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=12764
Posted on Jan 27, 2010
  • 1,006 Answers
Try to install driver in another location NOT IN PROGRAM FILES and use registry repair to repair ur registry..If u still have a problem the snanner have problem
Posted on Oct 26, 2007
May also have to go to canon website to download the correct version of the mp navigator.
Posted on Apr 20, 2008
I had the same message, but I some how fixed it. To fix, i either re-installed the driver(make sure its the correct driver version-check your computer properties) or I unplugged the usb cable, turned off the printer and then plugged the usb back in and turned on the printer so that it restarts and installs properly.Then an icon in the right corner says it's installing device.I dunno if that makes sense or if this even helps.Good luck.
Can[t scan into my documents
Did you install the scanner application? if yes, then just open your scanner application and select scan. If still can't use the scanner, try reinstall the program and drivers..
Feb 24, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Canon - Pixma MP150 printer/scanner won't scan in color.
may be you not installed the scanner application software if you have driver disk of printer choose the customs installation and select the scanning option menu and re install it the application.
Sep 18, 2009 | Canon PIXMA MP150 All-In-One InkJet...
I have a cannon mp 140 and cannot get it to scan
  • Unplug the Scanner cable from the computer.
  • Unistall the Scanner drivers from Device manager and also unistall the all the Scanner appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the Scanner.
  • then you can connect the Scanner and and try to Scan.
Hope this help. Please Rate My Response! Thanks!
CF
Jun 27, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Lost install disc Canon MP150
This is for the Mac OSX operating system if you are using windows let me know and I will get you the links MP150 Scanner Driver Ver. 12.13.0 (Mac OS X) mp150osxsd12130ej7.dmg 12.13.0 MP150 Printer Driver Ver. 4.8.3 (Mac OS X) mp150osxpd483ej7.dmg 4.8.3
Mar 30, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Scanning fails
Uninstall the present software and driver .Reinstall the sofwware and correct driver for your apple.
Feb 04, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Canon PIXMA MP145 Scanner Problem
Take it to a Canon Repair company, It has a 1 year warranty and needs to be replaced or call 1-800-ok canon.
Nov 02, 2008 | Canon PIXMA MP150 All-In-One InkJet...
MP145 Scanning Problem
hi Fulminater.
this is all i could find out from the internet.
Scanner driver will be closed : Code 2250.
check can't work the scanner because the cartridge are not inserted.
this is all i could find out.
Nov 29, 2017 | Canon PIXMA MP150 All-In-One InkJet...
E5 error code on canon pixma mp150
I had run into a similar problem with my all-in-one and had to use
http://www.irfanview.com/ (which is free) to scan with
Open irfanview and select File>Acquire Batch Scanning
Jan 09, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Problem with Scanner
I am not sure if you have tryed this or if it will work yet I had this problem and did the following: Went to: Cannon Utilities MP Navigator 2.0 or other version Preferences Select Cannon Product using
Jan 18, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Error Message
I had the same problem.Adding twain_32.dll to the Windowsfolder solved the problem.For people who don't want to search for it: Look Here.
Then you won't get this error but one saying to reinstall the printer driver. Just do it and the problem is solved.
Nov 28, 2006 | Canon PIXMA MP150 All-In-One InkJet...
Canon PIXMA MP150 All-In-One InkJet Printer Logo
6,745 people viewed this question
old marine
old marine
