Question about HP Computers & Internet
Connect hp notebook to lc62c42u sharp tv
I would like hook up my HP 2000-369wm laptop to Sharp Aquos lc62c42u tv so I can watch shows on the internet
peepnklown
  • 175 Answers
SOURCE: HP pavilion dv4000 hooking it up to a TV
I would try this: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00367779&cc=us&lc=en&dlc=en&product=468789&dlc=en&lang=en
Posted on Nov 10, 2007
  • 18 Answers
SOURCE: Gateway PC to Sharp Aquos
You need to go into the display settings of your computer once the cable is connected and change it to a dual-monitor setup. I'm going to assume you have windows 98/xp, you can find the display settings in your control panel under the title of "display". it'll be under the last tab of the window called "settings".
Keep it in mind, in reality there are a ton of ways to run two monitors. Chances are the one that your going to find easily is to "extend" your desktop onto your tv, making them both run as one screen. Hopefully that doesn't happen to you (you'll probably find it extremely annoying). Also, some video players wont let you play videos on your TV because their worried that your going to copy the video onto vhs.
The display on your tv will be blurry with s-video, and you wont be able to read text easily (hd-tvs are different if your video card is new enough to use the hd-tvs features, and/or your hd-tv can run computer displays. You can purchase a computer monitor to hd-tv cable online or at computer stores) but videos and pictures will look good. And if you have problems and you accidentally switch your display to the tv and your monitor is off, turn off the computer and unplug the s-video, it should go back to normal although it may happen if you put the s-vid cable back into the pc.
If you have any questions, feel free to ask. I have lots of experience doing this.
Posted on Jan 15, 2008
swami nathan
  • 208 Answers
SOURCE: Sharp Aquos LC-37P50E connected to computer with HDMI cable
I got the chat , but some how it got disconnected.
But i would like to help you in this aspect.
HDMI stands for High Definition Multimedia Interface, and supports transmission of both audio and video in high fidelity.
First make sure these things,
Both your computer and your TV will need to support HDMI interface.
It's quite a recent thing in PC graphics cards, so you may have to resort to S-Video, DVI or VGA for the video, plus a 3.5mm stereo cable (or the optical TOSLINK equivalent) for the sound.
Let know your comments and i will follow up with the suggestions.
Thanx for using fixya,
Good luck.
Posted on Sep 28, 2008
Dr Geek MD
  • 201 Answers
SOURCE: Want to connect my Sony vaio VGN-A250 to Sharp 19'' LCD TV
Your laptop will have a VGA output or possibly a S-video out. For the VGA you'll need a standard VGA cable. Plug the cable in to your laptop and the PC input of your TV. If your TV does not have PC input it may have a DVI input. IF it does you can use a VGA/DVI adapter to plug it in. If it doesn't have a DVI input you can use the S-Video output on your laptop with a standard S-video cable. After the connection to your TV is made you will have to toggle alternate display by pressing and holding your [Fn] key and pressing F4, or F5, or another F# key. It's the one that looks like a TV screen. Press once to turn on output, press again to turn off your laptop screen, press again to go back to laptop screen only
Posted on Feb 10, 2009
ginko
  • 19396 Answers
SOURCE: LC-37AF3X Sharp Aquos KCD TV
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on May 05, 2009
My TV will connect to the network but is not connected to the internet.
Check the videos to understand how set up the network connection on sharp tv . Hope it would help you to set up your tv. If you go for manual connection the you have to have some information . you can get those information from your internet provider comcast.
http://electro-medical.blogspot.com/
Easy Sharp Aquos TV Setup wifi internet network connection for Netflix apps
Wireless setup for Sharp AQUOS TVs HSN How Setup WiFi On The Sharp Aquos 60 Smart TV
Nov 13, 2015 | Sharp Aquos Televison & Video
Sharp aquos lenovo sl410 hdmi cable
I would look for a newer driver from lenovo. Has 8.1 got a fix?
Jan 19, 2014 | Lenovo ThinkPad SL Series SL410 (2842F7U)...
How do I hook the Sharp LC-52sb55u up to the internet? To get Netflix mainly. Also, is it possible to stream tv directly to the tv, in place of cable
Your HDTV would have to have internet connectivity, either an RJ-45 ethernet jack on the rear panel or wi-fi capability. Sharp calls it the AQUOS NET feature on the TV and is usually an ethernet port. If your TV does not have this capability, you can use a laptop and hook this up to your HDTV. You still need high-speed internet service and a Netflix account.
Mar 13, 2011 | Sharp LC52SB55U LCD TV
Can I hook up my Toshiba laptop to my Sharp Aqous TV, if so what connections do I need, ?S-video? I have an SGA connection on my laptop but not on the TV?
If this is the exact model Sharp Aquos television you have then you would have to have a laptop that has hdmi or dvi. You can try S Video on a laptop but the laptop's resolution would have to be so low that most laptops cannot accommodate this. You're right; this television does not have a VGA (RGB cable) input.
Nov 02, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Vga cable connects TV to HP laptop...then what?
You have to enable VGA port on the laptop. Press Fn + F5.
Nov 15, 2009 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
I hooked my laptop up to my tv, through a docking station and I have this annoying background noise, because I hooked my computer audio to my tv. How do I get rid of that noise? I have a 46'' Sharp Aquos...
If you connected everything correctly EG: a 3.5mm jack to 2 X RCA plugs,into the TV. then the background noise might be because the volume is too high on the laptop. double click on the Volume control on the task bar and drop the level to half on main and wave volumes.
Sep 28, 2009 | HP Computers & Internet
Sharp Aquos 46" HDMI problem
I have a similar problem. The Sharp TV aquos appears to be shutting down my blue ray player and dvd recorder when connected via HDMI. They work fine and never close down when I connect them via the rca cables either single video connection or a composite 3 cable rca lead. I have 3 HDMI inputs on the tv and the problem occurs on all 3. Any suggestions?
Jun 16, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
HDMI connection problem
Your TV doesn't like your laptop I guess.
There should be 2 reset buttons behind your TV.
Press the reset button first.
If that doesn't work, try the system reset button next.
If that doesn't work, you'll have to call 1-800-BE-SHARP to help you with the possible software problem with the TV
Good Luck
Feb 12, 2009 | Sharp Aquos LC-32D40U Television
Computers & Internet Logo
27 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
