Question about Jl Audio 1000/1 Car Audio Amplifier
My amplifier cuts out - Jl Audio 1000/1 Car Audio Amplifier
System cutting out, then cuts back in
Cheak your earth cable and positive at all joins and fuse spots earth should be nice and tight good luck
Oct 18, 2009 | Ranger MARTIN PS-55 KARAOKE MIXER...
My pioneer 600w amplifier cuts at high volume...
this means that the enternal preamp is starting to fail eventualy it will make no sound at all if you would like you can use a 4 channel amplifier if you would like to keep this deck
Feb 05, 2009 | Pioneer GM-6300F Car Audio Amplifier
Sound cutting out
Was the amplifier installed by a professional or shadetree installer?
May have tapped into wrong wire for amplifier turn-on.
Jan 02, 2009 | Kenwood KAC-9152D Car Audio Amplifier
When the bass cut on the speakers cut off
220 watts RMS x 1 at 4 ohms (400 watts RMS x 1 at 2 ohms)
the amplifier may be over-driven. are there red protection lights coming on the front panel? Or a loose wire - power, ground, or speaker.
Dec 18, 2008 | Alpine MRP-M450 Car Audio Amplifier
Amplifier cuts out sound and then turns back on then couple of more seconds the amp. cuts back out
There could be several problems. The following page should help you determine if you have a problem with the amp or something connected to the amp.
Amplifier in Protection Mode - Troubleshooting
Let me know if you have any other questions.
Sep 17, 2008 | Kenwood KAC-7202 Car Audio Amplifier
Sound cuts off
OK,  That means there's some kind of crazy fault in the temperature sensing circuits. I'm afraid you'll have to take it someplace and have it looked at for a more thorough diagnosis.
Aug 31, 2008 | NAD C325BEE Amplifier
Amplifier cuts off
your ohms on your subs are not wired right good luck
May 25, 2008 | Rockford Fosgate Punch P3002 Car Audio...
Sound cuts when volume is turned up
check that power amplifier rating(how many watt)must be more than total speaker rating by 20% at least..
exampel:if speakers watts are 100 watt-amplifier watt must be 120 watt.
Mar 14, 2008 | Technics SUV500 2-Channel Amplifier
Crate BT50 Bass amp cutting out with high input.
Sometimes an amplifier's preamp can't handle certain signals/frequencies at a high gain, so they cut out. Bass guitars are especially prone to giving such a strong signal.
I bought an older, nonworking bass amp recently and fixed it just to find it had the same problem. Best solution is to put a low ohm resistor at the amps input, but if you turn your guitar down to half volume it'll have the same effect: should prevent it from cutting out.
Nov 01, 2007 | Crate SPA1600 Power Amplifier - SPA Series...
Amplifier cutting out when volume is increased
yea my friend your audio ic or transistor is either getting faulty or you have lose connection have a tech look at your set and make the nessecary repairs.good luck
Apr 26, 2007 | NAD C340 Integrated Amplifier
Jl Audio 1000/1 Car Audio Amplifier Logo
23 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
Matthew Spark
Matthew Spark
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
