Question about Zojirushi Home Bakery Virtuoso Breadmaker, BB-PAC20- Stainless Steel,
My zojirushi bread machine is 110 voltage and accidentally plug to 220 voltage without touching any buttons of the machine and there was a popping sound
110 voltage plugged into 220 voltage
  • 5 Answers
SOURCE: The arm of the bread machine is not turning
partstore.com has repair parts. Try them to see if they have your part available. I've used them and had good luck
Posted on Feb 27, 2008
SOURCE: Need bread to be lighter, more fluffy
To make it light and fluffy you need to add more water or milk so that the dough is sticky, also add a little more yeast. You will have to experiment to get the right quantitys but as a rule if the recpie adds 2 tsp of yeast i add 1 more, with the water if it aske for 10ml extra for every 100gm of flour.
Posted on Mar 29, 2009
SOURCE: Zojirushi BBCC-S15 Flashing Lights won't reset
Reading my manual...the built-in lithium battery can be good for 4-5 years. The blinking"8:00 am" would indicate the problem. I am at that point now, but to send in the machine to fix it would be a challenge...
Susanna
Posted on Jun 18, 2009
  • 433 Answers
SOURCE: Replacement part for my Zojirushi BBCC-X20 Bread Machine
That sub component consists of a sealed bearing and seals that are spot welded onto the bottom of the pan. Unfortunately you can not purchase this assembly separately. Sorry Hank
Posted on Feb 12, 2010
SOURCE: Zojirushi bread machine
BBCC-S15A
All three lights are flashing and control panel not responing. I just finished baking a loaf cleaned up put the pan back in the bread machine then the lights started to flash
Posted on Apr 12, 2011
Tip
How to convert 220 volts to 110 volts for the iPod Touch
<p> <p>The battery of an iPod Touch prepared for use in the United States is designed to be reloaded from the current supplied by a 110-volt electrical system. Power is transmitted to the battery charger with an iPod battery, which are connected via a USB cable and then connected to a 110 volt outlet. To use the power of a 220 volt outlet with an iPod Touch, set the current 220 volts to 110 volts. A conversion adapter voltage, also known as "Step Down Transformer," it is necessary and can be obtained from an electronics store, a hardware store and even some drug stores. <br /> <p><br /> <p>1. Place the 220-110 voltage converter card (aka, "Step Down Transformer") next to a 220 volt outlet. Plug the adapter into the outlet. <br /> <p><br /> <p>2. Connect the end of a USB cable to the USB connector USB iPod charger iPod. Connect the other end of USB cable into your iPod's own socket on the bottom of the iPod Touch. <br /> <p><br /> <p>3. Plug the iPod into the 110 volt outlet in the battery adapter for the iPod Touch. <br /> <p><br /> <p>4. Unplug the charger from the iPod adapter and the adapter from the outlet when the battery is charged. Unplug the USB cable from the iPod charger and iPod Touch. <br />
on Aug 09, 2011 | Apple iPod touch
I plugged 110 volts xbox 360 into 220 volts outlet. and it's dead. what will i do?
Unless the item has internal fuse, it is burned up.
Look for product manual.
Many times, there is a glass fuse rated for unit voltage.
Replace fuse.
Each fuse has specific markings.
Oct 17, 2012 | Microsoft Xbox 360 with Kinect
I plug it in 220V
Do I understand you plugged this device into 220 Volts? Is this a machine designed for 110 Volts? Check the fuse - if it is burned out (as I suspect it will be) replace it. If the machine comes on - check out its operation. If it does not come on - I think that is the end of the road for your machine. To get to the fuse, remove the cover. Find the fuse near where the cord enters the cabinet.
I don't know where you live (please do not say) nor what the prevailing standard house hold voltage is. I don't know where you got the oven and please don't say. I really don't understand how you accidentally plugged a 110 Volt machine into a 220 volt outlet - that would be interesting to hear about.
Thank you for your interest n FixYa.com
Mar 09, 2011 | Microwave Ovens
My drier 110 volts was accidentally plugged to 220
The least of your problems would be a burnt out relay or internal switch which can be replaced at reasonable expense. In a worst case the motor or heating element "fried" and it'll be cheaper to buy a new dryer.
BTW 110 and 220 plugs are entirely different and a 110 plug cannot be plugged into a 220 outlet.
Apr 16, 2010 | Whirlpool LGR5636L Gas Dryer
My window air conditioner will not start. First time installed this season.
Make sure you have the correct line voltage at the plug.Some are 110 volt, some are 220 volt.
Here is the kicker...220 volt can be plugged into 110 volt plug at the wall with no damage.110 volt cannot be plugged into a 220volt socket at the wall without sustaining damage.
You can find out the required operating voltage of the a/c by reading the nameplate data printed on the a/c specs somewhere on the machine(not the housing}.
The plug end from the a/c should clue you into the proper machine voltage if you purchased a brand made in the USA.If it came from some third world country like Bangladesh, for example, the cheap bastards probably didn't wire the pigtail in at time of manufacture cause they are cheap ********.
You get what you pay for these days.
Call an electrician to chech it out.Don't be like the Bangladeshians!
Aug 02, 2009 | Haier Heating & Cooling
Need new blades for Zojirushi bbcc-x20 bread
http://www.thegourmetdepotco.com/store/store_partaccess.asp?manufacturer=33&category=-1&search=BBCC-X20
Mar 11, 2009 | Zojirushi BBCC-X20 Home Bakery Supreme...
Zojirushi Home Bakery Virtuoso Breadmaker, BB-PAC20- Stainless Steel, Logo
47 people viewed this question
Top Zojirushi Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Zojirushi Kitchen Appliances - Other Expert? Answer questions, earn points and help others
