Question about LG TracFone 600 Cell Phone - TF600GP4
How to lock and unlock keyboard on LG100c - LG TracFone 600 Cell Phone - TF600GP4
How do I unlock the keyboard
Wired keyboard usually do not have locks, However some wireless keyboard do. A switch is usually on the top side of the keyboard that slides back and forth.
However you may also be seeing "Caps Lock" which means the Caps lock key is engaged. Simply press the "Caps Lock" key again to unlock it. The caps lock key is located at the left side of the keyboard.
Dec 12, 2014 | Microsoft Wired Keyboard 600
How do I unlock the keyboard of IBM Selectric III???
The Selectric typewriter has several "interlocks" that can cause the keyboard to be locked. When you turn the machine off there is a mechanism that locks the keyboard. When you turn it on the part should move and unlock the keyboard. Sometimes this part sticks and the keyboard will remain locked. When you type any character the keyboard is locked to prevent two keys trying to type at the same time. The machine locks and unlocks very fast. One keys is locked in and prevents others from working. try turning on the machine and hitting every key just a little bit harder and see if it then types. When you shift, as the ball is turning the keyboard is locked temporarily so it won't attempt to type as the ball is turning as that would damage the machine. Sometimes the shift mechanism can cause the keyboard to remain licked as the shift may not have finished it's complete cycle. Also, the return mechanism locks the keyboard temporarily when the carrier is returning to prevent you from typing when the carrier is moving backwards. Only a qualified technician can resolve those issues.
May 08, 2014 | IBM Correcting Selectric III Electric...
My cell phone LG100C on vibrates when it rings and will not ring how do I get the phone to ring
I had the same problem here's the solution:
http://tracfone.deviceanywhere.com/net10/tutorial.seam;jsessionid=771E9E381E2C30A92AFD1AECEC422351?tutorialId=2021&deviceId=648&cid=247250&conversationPropagation=end
Jul 15, 2012 | LG Cell Phones
Activation code
LG 900 v09e
Citazione:
TEST MENU: 277634#*#
LG 900 v10b
Citazione:
TEST MENU: 082065#*#
LG U970 Shine
Citazione:
TEST MENU: 26911147#*970#
LG L600V
Citazione:
TEST MENU: 63342425#*#
LG KU310
Citazione:
ENGINEER MODE: *72346#96
LG KU800
Citazione:
TEST MENU: 26911147#*#
LG KU830
Citazione:
LG KU950
Citazione:
TEST MENU: 7973845#*#
ENGINEER MODE: 21738#96
LG KU990 Viewty
Citazione:
TEST MENU: 3845#*990#
ENGINEER MODE: 364663#96
MENU NCK: 2945#*990#
LG Rhythm
Citazione:
TEST MENU: 2945#*#
Feb 27, 2012 | LG Cell Phones
How to unlock the scroll lock key
Hi!
To unlock the scroll lock key on your zippy keyboard, please press the scroll lock key again.
Every time you press this key it switches between lock/unlock.
Regards,
Aug 20, 2011 | Zippy EL-610 (840556027058) Keyboard
What's the best way to unlock a Caps Lock key that won't unlock by simply pusing the Caps Lock key to unlock it?
goto start > run > type "osk" and click ok...
On-screen keyboard will be displayed...
select keyboard in the menu bar... select 102 keys...
Use the Lock key in the on-screen keyboard... it will turn OFF/ON the CAPS lock
Jan 15, 2011 | Microsoft Computers & Internet
How do you disable web browser on the LG100c tracfone, I keep accidentally hitting the button its charging me .50 of air time each time.
You can disable the browser key to avoid accidental activation. Go to Menu enter the last four digits of your phone number into the "Lock Code" screen, press "OK," choose #2-Restrictions, then #5-Data, and "Lock." The screen will display "Data is restricted."
Oct 04, 2010 | LG TracFone 600 Cell Phone - TF600GP4
How do you unlock the CAPS lock
To unlock the caps lock on your keyboard, please click on the caps lock key again.
Check for few iluminating lights on your keyboard as well, as few of the models does have that.
If the Caps lock is ON the lights normally illuminate and If you click on the caps lock key again, the lights go off.
Feb 07, 2010 | Gateway 2520915 Keyboard
Unlock keyboard
I have an Olympia ES95i and if you hit code on-line it locks the keyboard. To unlock, press code + online then code + clear. Hope this helps
Apr 16, 2007 | Olympia Monica 2 Typewriter
LG TracFone  600 Cell Phone - TF600GP4 Logo
20 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
