Question about Baby Jogger City Elite Stroller
Harness buckle replacement
I need A replacement
Heated and cooled seat on 2004 expedition stopped working how to reset them
Heating and the cooling both don't work ? Just one seat or all seats ?
Your best bet have it checked for DTC'S - diagnostic trouble codes to start .
Climate Controlled Seat Module (CCSM) Diagnostic Trouble Code (DTC) Index DTC Description Source Action B1342 ECU Is Faulted CCSM INSTALL a new CCSM and CARRY OUT programmable module installation (PMI). REFER to Climate Controlled Seat Module . B1358 Ignition Switch or Blower Electronics Circuit Short to Ground CCSM Go To Pinpoint Test Q . B2477 Module Configuration Error CCSM This DTC indicates programmable module installation (PMI) has not been done to a newly installed module. CARRY OUT PMI. REFER to Section 418-01 . CLEAR the DTC. CARRY OUT the self-test. B2486 Climate Controlled Seat Module Voltage Out of Range CCSM DEPOWER the supplemental restraint system (SRS). REFER to Section 501-20B . DISCONNECT driver safety belt buckle pretensioner electrical connector or passenger safety belt buckle pretensioner electrical connector of the affected seat and CONNECT restraint system diagnostic tool 418-F395 to the safety belt buckle pretensioner harness connector. CONNECT the battery ground cable. CHECK circuit 294 (WH/LB) for a fault. REPAIR as needed. If okay, REFER to Section 414-01 . Once the repair is complete, DISCONNECT the restraint system diagnostic tool from the safety belt buckle pretensioner harness connector and CONNECT the safety belt buckle pretensioner connector of the affected seat. REPOWER the SRS. REFER to Section 501-20B . B2488 Thumbwheel Switch Voltage Out of Range High CCSM Go To Pinpoint Test R . B2521 Tach Circuit Failure CCSM Go To Pinpoint Test Q . B2729 Cushion Over-Temp Detected CCSM Go To Pinpoint Test S . B2730 Back Over-Temp Detected CCSM Go To Pinpoint Test S . B2731 Differential Temperature Fault CCSM Go To Pinpoint Test S . B2792 Heat Switch Short to Ground CCSM NOTE: If HEAT is pressed for greater than 20 seconds on the climate controlled seat switch, DTC B2792 will set in the CCSM.
CLEAR the DTC. If the DTC does not clear, DEPOWER the supplemental restraint system (SRS). REFER to Section 501-20B . DISCONNECT driver safety belt buckle pretensioner electrical connector or passenger safety belt buckle pretensioner electrical connector of the affected seat and CONNECT restraint system diagnostic tool 418-F395 to the safety belt buckle pretensioner harness connector. CONNECT the battery ground cable. CHECK circuit 1551 (VT/WH) for a short to ground. REPAIR as needed. If okay, INSTALL a new climate controlled seat switch. Once the repair is complete, DISCONNECT the restraint system diagnostic tool from the safety belt buckle pretensioner harness connector and CONNECT the safety belt buckle pretensioner connector of the affected seat. REPOWER the SRS. REFER to Section 501-20B . B2793 Cool Switch Short to Ground CCSM NOTE: If COOL is pressed for greater than 20 seconds on the climate controlled seat switch, DTC B2793 will set in the CCSM.
CLEAR the DTC. If the DTC does not clear, DEPOWER the supplemental restraint system (SRS). REFER to Section 501-20B . DISCONNECT driver safety belt buckle pretensioner electrical connector or passenger safety belt buckle pretensioner electrical connector of the affected seat and CONNECT restraint system diagnostic tool 418-F395 to the safety belt buckle pretensioner harness connector. CONNECT the battery ground cable. CHECK circuit 1550 (WH/OG) for a short to ground. REPAIR as needed. If okay, INSTALL a new climate controlled seat switch. Once the repair is complete, DISCONNECT the restraint system diagnostic tool from the safety belt buckle pretensioner harness connector and CONNECT the safety belt buckle pretensioner connector of the affected seat. REPOWER the SRS. REFER to Section 501-20B . U2362 UBP Invalid Data Node ID CCSM NOTE: DTC U2362 indicates a network concern, the CCSM is not the source of the fault.
CLEAR the DTC. If the DTC does not clear, REFER Section 418-01 .
Nov 26, 2016 | 2004 Ford Expedition
I took the cover off for washing. Need instructions to put back on
You should be able to download the instruction for this model from this site
Instruction Manuals
You will have to remove the buckle loop holding the harness at the back of the seat and release the straps. Once you insert these through the seat cover and back into the slot on the seat back you can lock the harness by re-inserting he buckle loops.
Aug 25, 2014 | Cosco Baby Gear
2006 grand cherokee seat belt
Have the same problem in my 98 Toyota Rav4. I squirted the female buckle (bolted to seat, not holding strap harness) with wannabe WD-40 lubricant from the $1 store, and it seem to have solved the problem. I'm guessing the spring mechanism is worn out, which is why the harness buckle won't lock. Another solution is to replace the female lock buckle with an identical part from the used parts junkyard store.
The seatbelt light on the dash stays "on," even when everyone has their belt on, but I don't bother servicing that. If yours have an audible alarm instead of an indicator light on the dash, locate the source of the alarm sound and disconnect the wires to silence the sound.
Nov 29, 2013 | Cars & Trucks
Airbag light has started flashing then came on this is the first time we have had an issue with this. after flashing the light stays on.
get the code, but my guess is it\'s the seat belt pre-tensioner connectors. There is a TSB to replace them on both seats at the same time. Not a recall so not covered under warranty. Please rate highly if this helps.
TSB 05-17-11
RESTRAINT SYSTEM - SAFETY BELT BUCKLE AND PRETENSIONER DIAGNOSTIC TROUBLE CODE (DTC) B1877 AND/OR B1881
FORD:
2001-2004 Escape
This article supersedes TSB 04-24-4 to update the service procedure.
ISSUE:
Some 2001-2004 Escape vehicles may exhibit an intermittent air bag lamp on and diagnostic trouble code (DTC) B1877 and/or B1881. This may be caused by a variation in the electrical continuity between the pins of the driver and/or passenger side wiring harness and the buckle pretensioner connector. If this condition were to occur, the air bag system remains fully functional.
ACTION:
Install a replacement harness connector kit ON BOTH the driver and passenger safety belt buckle pretensioners, even if the DTC is present for only one side. The kit includes improved connector halves to replace the existing connectors on both the body harness and the safety belt buckle pretensioner.
One kit is required per side (2 kits per vehicle). Refer to the instruction sheet included in the kit for complete repair procedure.
OPERATION
DESCRIPTION
TIME
051711A
2001-2004 Escape Install A Replacement Harness Connector On Both The Body Side And Safety Belt Buckle Pretensioner Harness For Both Driver And Passenger Safety Belt Buckle Pretensioners (Do Not Use With 14056D)
2.0 Hrs.
Sep 09, 2010 | 2004 Ford Escape
Buckle on 5 point harness of stroller broke.
Hi I have a trends for kids stroller and I los the harnes, where can I buy those
Feb 09, 2010 | Chicco Cortina Travel System - Discovery...
Need to adjust restraining straps up to next position cannot get straps through and cannot see how they come out (No instruction Manual when bought) Actual Model not known but on a label has SI 2008 265776
Contact the manufacturer. They ought to email you a manual within minutes. Manuals for car seats are very important, so you'll know when your child outgrows it. In my car seats, the harness is hooked on the back to a metal buckle-looking thing that is attached to a piece of webbing. The webbing goes under the seat and out the front, where you pull on it to adjust the tension. Simply remove the harness straps from the buckle-looking thing, pull out the front, push through the higher harness strap position, and reattach to the buckle-looking thing.
Jun 11, 2009 | Baby Gear
Need help with putting straps back on
I know this is months later, but here you are in case you (or anyone else) needs the info again. First, though, I feel that it wouldn't be responsible to neglect to tell you that if you got the seat in 2000, it is expired and no longer safe to use. Car seats generally expire after 6 years because the plastic degrades over time - in a 10 year old seat, it can look fine but actually be brittle enough that the entire harness can rip out of the seat if it's an accident. For the manual, visit Cosco's website and fill in the product number and date of manufacture. It will bring up a PDF file of the manual that you can download. To rethread the straps, first replace the **** strap. Slide the metal plate down through the slot in the seat, with the buckle facing out. Slide the metal clip under the tab and push it down to lock it in place. Facing the seat, start by threading the end of the harness strap down through the slot of the left side of the bottom (where the child's right hip would be). Under the pad/cover, thread it across the bottom of the seat and up through the matching slot on the right side. Pull it until you have equal lengths on both sides. Thread the buckles onto the the strap (one one each end) and buckle them. Thread the chest buckle onto both ends, making sure that the harness doesn't twist. Buckle it, too. Push the ends through the harness slots. Pull the harness through to the back, making sure that it goes OVER the metal bar, but UNDER the plastic adjuster handle. There is a loop sewn into each end of the harness. The adjuster strap has a splitter plate, kind of shaped like a Y. Slide each loop over the ends of the plate and all of the way into the slot, so that the curved ends of the splitter plate are exposed and the strap is secure in it's slot. Adjust the harness height by squeezing the metal bar on the back of the seat (the one behind the harness) forward and moving it and the plastic adjuster bar up or down to the correct position (at or below the shoulders for rear-facing, at or above the shoulders for forward facing). Do note that the very top slot is NOT for use with the harness - it's only to adjust the headrest when the seat is being used as a seat belt positioning booster and is not reinforced to support the harness in an accident! Adjust the tightness of the straps with the button/extra length on the front of the seat. Properly tightened straps should lay in a straight line without sagging and you should not be able to pinch up any slack (lengthwise going down the harness, not across the width of it) at the shoulders or hips. Adjust the chest buckle to lie in line with your child's armpits, never his neck or belly.
Oct 15, 2008 | Cosco Alpha Omega Elite 5-Point 22-155
Evenflo aura travel system
I hope this information helps:
1) There are harness anchors (metal clips) located on the bottom of the seat. Push these up through the slot to the front of the seat on both sides. To do this, you will need to pull them toward you, and then turn the anchors to fit through the slots.
2) You should be able to remove the bottoms of the straps at this point. Remove them, then pull the tops of the straps through the slots. (You will need to remove the buckles during this process.)
3) Slide the straps through the slot you need for the correct harness height.
4) Replace the buckles in the correct positions.
5) Replace the bottoms of the straps into the harness anchors.
6) Push the harness anchors through the padding and back into the bottom of the seat. Clip into place.
Dec 04, 2007 | Evenflo Aura Traditions Travel System...
Baby Jogger City Elite Stroller Logo
69 people viewed this question
Top Baby Jogger Baby Gear Experts
Lyle Siemens
Lyle Siemens
john h
Are you a Baby Jogger Baby Gear Expert? Answer questions, earn points and help others
