Question about Plymouth neon tube. hcu to front hose-right, right. brake. rt front
Need repair on HCU AL116824 - Plymouth neon tube. hcu to front hose-right, right. brake. rt front
WHAT IS HCU
hcu is as i understand it is the humidity control unit in an ac system
Oct 04, 2015 | Heating & Cooling
Where is the ECU on my Van with 4 wheel ABS system.
ecu is usually located under hood driver side fender
Oct 31, 2014 | Cars & Trucks
Need to know what HCU and ECU stand for
from where are u getting "hcu" & "ecu"
Apr 03, 2012 | 2003 Ford Escape
Sk4000 remote will not pair with headset, tried everything and checked with support. They said be sure and pair remote before pairing phone. Tried that and still nothing. if the remote is no good there is...
If you have verified that the battery is good in the unit, try this (from the folks at Parrot). The HCU is the main control unit.
1) Turn the HCU on
2) Clear the memory on the HCU by holding down the power button and accept call button (the two large buttons on the face of the HCU)
3) Wait until you hear the HCU make the request "please pair device"
4) Hold the volume up and the volume down keys on the remote for 15 seconds
5) Release the buttons on the remote.
It might be fixed now. Press the switch on the bottom of the remote to switch to radio and see.
Jun 09, 2011 | Parrot SA Parrot SK4000 Motorcycle...
Remote does not work on SK4000.
1) Turn the HCU on
Jun 04, 2011 | Parrot SA Parrot SK4000 Motorcycle...
How do to replace the abs control module?
If you are talking about just replacing the electronic ABS module (EBCM), it simply unplugs and unscrews from the hydraulic control unit. If you are talking about replacing the hydraulic control unit (HCU) then you must disconnect the EBCM. Disconnect all of the brake lines from the HCU. Remove the mounting bolts from the HCU and remove HCU from vehicle. Then you reverse th order to reinstall. Once it is installed you must use a scan tool to perform automated bleeding to get all the air out of the hydraulic unit and the rest of the brake system.
Feb 21, 2011 | 2006 Chevrolet Trailblazer
I replaced the brake master cylinder on my 91 Lincoln Mark 7 with a non high pressure master cylinder and the rear brakes do not hold. Do I need to change the cal. on the rear also?
ANTI-LOCK BRAKE SYSTEM (and HCU-Hydraulic Control Unit)
General Information The 4-Wheel Anti-lock Brake System (ABS) is an electronically operated, all wheel brake control system. Major components include the power brake booster, master cylinder, the wheel speed sensors, and the Hydraulic Control Unit (HCU) which contains the control module, a relay, and the pressure control valves. The system is designed to ****** wheel lockup during periods of high wheel slip when braking. Retarding wheel lockup is accomplished by modulating fluid pressure to the wheel brake units. When the control module detects a variation in voltage across the wheel speed sensors, the ABS is activated. The control module opens and closes various valves located inside the HCU. These valves, called dump and isolation valves, modulate the hydraulic pressure to the wheels by applying and venting the pressure to the brake fluid circuits. Some models are equipped with a Traction Assist (TA) system. The TA system senses wheel spin upon acceleration, turns on the Hydraulic Control Unit (HCU) pump and applies fluid pressure to the appropriate rear wheel. Two additional isolation valves in the HCU will also close to permit fluid to flow only to the rear wheels. The TA system monitors TA usage to avoid overheating the rear brakes. If the system does sense brake overheating, the ABS module will inhibit TA operation until the rear brakes are permitted to cool down.
SYSTEM COMPONENTS The anti-lock brake system consists of the following components:
  • Vacuum booster and master cylinder assembly
  • Hydraulic Control Unit (HCU)
  • ABS module
  • Wheel sensors
  • Pedal travel switch
On 1992-1994 and 1995-00 a scanner is used to perform the brake bleed. But on yours, I think it's different according to the manual.
What do you mean change the cal. on the rear also? Do you mean Caliper?
Jul 26, 2010 | 1991 Lincoln Mark VII
HITACHI HCU-AX10E Hifi, how to set the timer & EQ
Clock,timer,eq and presets you can adjust by remote control
Aug 29, 2009 | Audio Players & Recorders
Hcu 1989 mkvll
check ebay or your near by salvage yard
Jul 31, 2009 | 1989 Lincoln Mark VII
Plymouth neon tube. hcu to front hose-right, right. brake. rt front Logo
Top Chrysler Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
elvis0427
john h
Are you a Chrysler Vehicle Part and Accessory Expert? Answer questions, earn points and help others
