Question about Fellowes Manufacturing Powershred MS-450Cs Shredder
Need a manual for fellowes ms 450c
Where an I get a manual??
HP 450C begins to print then cartridge light begins to blink and no more ink flows, all cartridges are new, what is this problem
you my have a problem in your carriage assembly, or trailling cable, contact me at walid_sayed@hotmail.com to send you the service manual
Mar 30, 2010 | HP DesignJet 450c InkJet Printer
Fellowes MS-450Cs crosscut shredder quit
No, your shredder blades are dull. No replacement parts are available. Sorry
Nov 27, 2009 | Fellowes Manufacturing Powershred ...
WE HAVE A MS-450C MODEL SHREDDER WITH SAFE SENSE OPTION. THE YELLOW LIGHT IS FLASHING THIS MORNING AND WILL NOT GO OFF. ANY SUGGESTIONS?THANKS
The shredder won't go off, as in it is running, or the yellow light won't go off?
Either way, I reccomend a good cleaning, not the outside either, the indside of the shredder. Unplug it first!!!! Either take it outside where the dust can fly or spread out some newspaper to work on. Gently remove the case and clean out as much of the paper pieces as you can. An air compressor and blow gun would be great to help clean (if you are outside) stuff out of the nooks and crannies. While you have it naked in front of you give it a good oiling with whatever Fellowes recomends, 3-in-1 oil or even WD-40 (not the best). Be careful, some of these things have circuit boards and other delicate electricl items that can be broken if handled too roughly.
Sep 03, 2009 | Fellowes Office Equipment & Supplies
HP DesignJet 450c printer issues.
You can purchase a External JetDirect card from any reputable HP (or computer) agent. This will allow you to plug the 450 directly into the network. The problem with the large format printers not being supported is strange to me. I have never had a problem, simply load the drivers and away you go. If the 450 drivers dont work for you, you can select any of the older drivers (750c recomended) and they will work on the 450c
Feb 26, 2009 | HP DesignJet 450c InkJet Printer
450c color problem
The 430 ID is B/W, you need to load the 450C driver to get color, renaming the driver isn't enough.
Oct 13, 2008 | HP DesignJet 450c InkJet Printer
Jam
I have a similar problem. I took the shredder head and gear box apart and found two stripped gears. True, the gears are plastic unfortunately (which is why they stripped.)
The gears are simple to get at and to replace. Does anyone know where I can purchase a set of gears for this unit (there are 3)?
If so, could you, please, email me w/ that information? (pterocarpous@yahoo.com).
I'd really appreciate it.
Thank you in advance.
Joan Rapier
Sep 26, 2007 | Office Equipment & Supplies
Fellowes Manufacturing Powershred  MS-450Cs Shredder Logo
47 people viewed this question
Top Fellowes Manufacturing Office Equipment & Supplies Experts
Andrew Taylor
Andrew Taylor
 Bob Buchholz
Bob Buchholz
Are you a Fellowes Manufacturing Office Equipment and Supply Expert? Answer questions, earn points and help others
