Question about Electrolux Vacuums
Charging light - Electrolux Vacuums
Amber flashing light while on home base. New, pulled tab, placed on dock. First time said charge err1, took out battery and replaced. Now just flashes amber. Is this correct?
Your manuals are here. Flashing lights must be covered. A quick look at the site says flashing red is bin full. In fact, I found it. Flashing Amber is CHARGING.
Roomba 600/500 Battery and Charging Overview On some robots, the CLEAN light should pulse red/amber while charging. ... Amber - partially discharged; Red - nearly discharged; Flashing Red - discharged . homesupport.irobot.com homesupport.irobot.com/.../roomba-600%2F500-battery-and-charging- overview LabeledSupport ... clipped from Google - 12/2015 iRobot: Customer Care - Roomba 700 Anatomy homesupport.irobot.com homesupport.irobot.com/app/answers/.../a.../roomba-700-anatomy images?q=tbn:and9gcss8oogw3vmcv_uom0z_pxoi9q5tq9n4aqrcwbsxn0zd1blfvnacictdbyn iRobot: Customer Care - Roomba 700 Anatomy Solid Red = Battery Discharged; Amber Pulse = Charging; Solid Green = Fully Charged; Quick ... The battery indicator blinks when there is a charging issue. homesupport.irobot.com homesupport.irobot.com/app/answers/.../a.../roomba-700-anatomy LabeledSupport ... clipped from Google - 12/2015 iRobot Roomba 500 Series Battery Maintenance homesupport.irobot.com homesupport.irobot.com/ci/documents/.../042809_500MaintBatt_vib iRobot Roomba 500 Series Battery Maintenance Roombas "CLEAN" light should pulse red/amber while charging. ... Green - fully charged; Amber - partially discharged; Red - nearly discharged; Flashing Red - ... homesupport.irobot.com homesupport.irobot.com/ci/documents/.../042809_500MaintBatt_vib LabeledSupport ... clipped from Google - 12/2015 Roomba 400 Series/Discovery Battery and Charging Overview homesupport.irobot.com homesupport.irobot.com/.../roomba-400-series%2Fdiscovery-battery-and- charging-overview Roomba 400 Series/Discovery Battery and Charging Overview Your Roomba's POWER light should pulse red/amber while charging. ... Amber - partially discharged; Red - nearly discharged; Flashing Red - discharged. homesupport.irobot.com homesupport.irobot.com/.../roomba-400-series%2Fdiscovery-battery-and- charging-overview LabeledSupport ...
iRobot Owner Manuals and Quick Start Guides
Dec 31, 2015 | Roomba Vacuums
Why does navigator freestyle shark vacuum light blink even after charged?
I have had 2 Shark Cordless Freestyle vacuums. The first one, when it was fully charged, the blue light would glow softly. The newest one has a flashing blue light that you can see from outer space. Light is supposed to keep flashing even when it is fully charged. Very annoyed that they changed this feature.
Jun 09, 2014 | Shark Navigator Freestyle Stick Vacuum -...
Charge light won't stay on and therefore won't charge
It could not be making good contact with the charger.Check the contacts on the unit and the charger-sometimes the connectors get bent or something is stopping the circuit to complete. Wiggle the device while it is on charge and try to make the light stay on.
Jan 06, 2014 | Dirt Devil 9.6V Gator Hand Vac, BD10085
Roomba 4220 light says charged but wont turn on
Try resetting
to reset the charging system. You can do this by removing the battery from the robot and unplugging the charger from the wall and robot. Please hold the power button down for 30 seconds. You then should charge the robot....."
Dec 29, 2012 | Vacuums
Should the red light on my 15.6v dustbuster turn green when it's fully charged? It doesn't.
I had the same issue, then i just found the manual, in charging part, it says:"The charging indicator will be lit as long as the
appliance is connected to the plugged-in
charger."
Also it says:"While charging, the charger may get warm, this is
perfectly normal and safe. It can remain on
charge indefinitely without damage or danger. It
is not possible to "overcharge" the battery cells
with the charger provided"
Jul 29, 2012 | Black & Decker 15.6 Volt DustBuster Vacuum
How do I know if it is charging
On your stand there are blue lights that show when it is charging the vacuum. If plugged up with out the vacuum on the base the lights do not show. Once you set the Vacuum on the base the blue lights indicate that it is charging.
Dec 21, 2010 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
Westinghouse Unplugged Vacuum Turns off after 5 Seconds.
If both batteries are behaving the same way then this is probably a charger problem. When you insert the battery pack into the charger does the 'charging' light blink for 30 minutes (fast charge) then go steady? I noticed that one of my batteries was causing the light to come on steady immediately I inserted it into the charger. When I tried to use the battery pack I got the same problem everyone else is seeing, i.e. vacuum cleaner shuts off in less than a minute, so I conclude that when the charging light is on steady then the battery is not being charged.
If the charging light does not blink when you insert the battery (i.e. comes on steady or not at all), try removing the battery and re-inserting it into the charger.
Try a conditioning cycle on your battery packs. To do this:
* Insert the battery pack into the charger
* Before the charging light lights press the 'condition' button located just above the charging light.
* The 'conditioning' light should blink. This is a light which does not normally illuminate, and it is located below the condition button and above the charging light. The charger fan will run quieter in this mode.
* Leave the battery pack in the charger for 24 hours while this cycle is taking place.
I'm not a service technician so perhaps someone else might like to post other solutions or corrections to this one.
Mar 07, 2008 | Vacuums
Vacuums Logo
13 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
