Question about Dell 3100cn Laser Printer
Printing Problems I'm getting dots (CYMB) on every page is print -- always on the right had side of the page about 1.5" from the right edge of the paper. A series of 4 dots of each color, and then a couple of inches down the page it repeats and continues to repeat. And, how do I find out my print count? And when does the cleaning pad need to change? Thanks. smack48
  • 2 more comments
  • smack48 Oct 26, 2007
    Sorry.  My printer is a Dell 3000cn and I've scrolled through the menu and don't find a 'Print Quality' option.  Any other thoughts?  Thanks.
  • smack48 Oct 28, 2007
    Looks like these are for HP laser printers.  Anything for my Dell?
  • Lat22 Dec 07, 2007
    I've got the exact same problem on my 3100cn. It corrected itself briefly after I replaced the drum cartridge, but it's gone back to doing the same thing. Dots in the same place on every page I print.
  • Anonymous Dec 08, 2007
    I bought a Dell C3100cn printer August 2005. After approx 6 months it began to print those 4 dots. After replacing the drum they disappeared. But, after some months they appeared again. At contacting Dell support I got the explaination that it was a printer manufacturing problem (not clean enough process) and that the only solution was to either replace most of the contaminated parts that was close to the toner/drum or to by a new printer (which would cost less).
    But, if this problem exists with a printer manufactured later than 2006 there probably is some other explanation (presumed Dell corrected their manufacturing process...).
  • 39 Answers
Konica Minolta 2430 DL has Smudges or dots on page
Not an expert on this brand of printers but it looks like dirty feeder rollers to me. Try cleaning them and Print a Blank document and see if the marks show up
Jan 24, 2014 | Konica Minolta magicolor 2430 DL Laser...
Konica c360
RE[place the transfer belt, open the right door, that shiney belt is the image trans fer belt that has the image on it to be placed on the media (paper) right above it is there a small plastic device in the middle that looks like it could cause your dots it was bad design that little thing prevents paper from riding on the belt
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Mar 04, 2018 | Konica Minolta Office Equipment & Supplies
Printouts have marks on right side of paper
1. Check with another cartridge.
2. Replace teflon sleeve if its available or replace fuser assembly.
Nov 29, 2012 | HP LaserJet 2420 Printer
How do you get the Lexmark pro 715 Printer to print on Both sides the manual is not very clear
1 With a document open, click File > Print.
2 Click Properties, Preferences, Options, or Setup.
3 Go to the:Layout tab > Print on Both Sides (Duplex) area > Print on both sides
- Click Long edge for print jobs with pages that are bound along the long edge of the page.
- Click Short edge for print jobs with pages that are bound along the short edge of the page.
4 Click the Paper/Finishing tab, and then select a supported paper type.
5 Click OK to close any printer software dialogs.
6 Click OK or Print.
Oct 22, 2012 | Lexmark Pro 715 All-in-One Printer
Every page has 3 or 4 black dots right down the center. How do I get rid of these?
Are the spots the same on every page?
Start a print from tray 1/manual feed and just as the trailing edge of paper is entering the machine; quickly open it to stop print and take out the cartridge and look at the drum and the paper underneath. If the issue is there at that point then it would point to the cartridge. If not then it is in the fuser area.
If it is the drum area:
Clean the loose toner up with a dry lint free cloth.
If it is the fuser, it may have a bad spot and would need to be replaced.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jun 28, 2011 | Digital Products Brother HL-2040 Laser...
Epson Stylus photo 340 r printer paper jam when trying to print
first, make sure you the paper correctly to avoid paper jam.
Single Sheets 1. Open the paper support and raise the extension. 2. Place your paper short edge first against the right edge of the feeder, under the tab, with the printable (whiter or glossier) side up. If you are loading multiple sheets, fan the stack of paper before loading it to prevent paper jams. Note: Don’t load paper above the arrow mark inside the left edge guide. Some special papers can be loaded only one sheet at a time. Slide the left edge guide against the paper. Make sure it is snug, but not so tight that the paper is bent. (For letter- or A4-size paper, you may not need to move the edge guide over.) paper.4.2.1.jpg 4. Open the output tray and pull out the extension. You should also follow these guidelines:Always load the short edge first, even when you’re printing landscape-oriented pictures. • When using special papers, check the paper package for additional instructions. Some papers require using a support sheet included in the package. Note: Always keep unused paper in the original package and store it flat to prevent curling.
if you loaded the paper, it jammed again, remove the paper and tried to print, still the same, its a hardware issue, alraedy, the printers roller is broken
Feb 09, 2010 | Epson Office Equipment & Supplies
Prints black dots at bottom of page - photoconductor was replaced earlier today
The black dots could be a few things, the most likely would have something to do with the drum area because the dots didn't appear until after service. If the dots are only about an inch apart it is probably the charge roller. If there is only 1-2 dots per page, the issue is likely with the drum. These figures are assuming you are running 8 1/2 x 11 paper with the long edge being fed in first. If this is the case, you can change the paper to feed with the short edge first and this may get you by until the technician gets back out to fix it.
Nov 18, 2009 | Ricoh Aficio 450 Copier
Printer prints a colour dot at every pages edges
Hi ,
if u get red dots on print it may be problem with Red cartridge Lick age please check u r printer with Ok cartridge .if same problem with new cartridge then u need to clean Mirror built in lance assembly
Jul 11, 2008 | HP LaserJet 3800dn Printer
Epson 9800 Prints black dotted vertical line
This is a workaround - I too need a definitive answer. Symptom: black dotted vertical line 1/2 to 3/4" from leftmost image edge. I have begun adding single vertical line to my prints .25" from the left edge of the paper to force the "dots" off my print - this seems to have the desired affect, but it does not answer the cause or provide a true remedy (it will save many of your prints while we wait for complete solution). dkh
Apr 18, 2008 | Epson Stylus Pro 9800 InkJet Printer
2 parallel lines show up on the copies
try to clean the cover glass at the top of the copier with alchol.
be sure that ther is no any dot or lines on top of tha glass specialy the right side.
Apr 11, 2008 | Sharp AL 1631 Copier
Dell 3100cn Laser Printer Logo
290 people viewed this question
Top Dell Office Equipment & Supplies Experts
David Patricia James
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
