Question about Gold N Hot 'N Hot GH9271 Professional Portable 1200 Watt Hard Bonnet Dryer
Gold n hot
Can't get it closed
Our store owns a gold medal #2656 popcorn popper but now it will not pop but few kernels. is it not getting hot enough or is it something else?
no you shouldn't have to do that. you are correct about the heat. what happens is it doesnt get hot enough for the moisture in the seed to expand to pop it, but its hot enough to dry it out so it cant pop. so it burns instead and you end up with a bunch of old maids. the thermostat is the first place to check.
Feb 05, 2016 | Gold Medal Products Gold Medal 2656 6 oz....
Closing the dryer once done with use
might be a spring has popped off or a bushing issue. search for you local electric motor repair shop, these guys are for the most part are firing on all 8 cylinders and are glad to help a damsel in distress.
Jay the pool pump motor repair guy in longwood Florida 32750
Feb 08, 2014 | Gold N Hot 'N Hot GH9271 Professional...
My Gold N Hot flat iron will not heat up
Suspecct failure of the heating element, use a continuity tester to check the element or the connection to the element as the mains wire is OK. Disconnect the power to test.
Jan 17, 2014 | Gold N Hot Gh2168 Professional Ceramic...
How to close hair dryer
Hold the blue 'bar' looking handle in the front in and you should be able to collapse it.
Feb 15, 2013 | Gold N Hot 'N Hot GH9271 Professional...
How do you close the gold n hot 1200 hooded dryer.
Press the purple button on the top of the hood and then push the head back into place
Jan 04, 2011 | Gold N Hot 'N Hot GH9271 Professional...
How do i correct ground and hot rev
You have the hot wire going to the silver terminal and the grounded wire (neutral) going to the gold terminal You need to reverse the. Hot (Black or Red wire to Gold terminal and the White wire to the Silver terminal.
Dec 12, 2010 | IDEAL MCM TESTER GFI CIRCUIT
Why wouldthe center piece between freezer & refrigerator get hot
There is a heater located behind that strip known as the mullion heater.
Look to see if you have a switch labeled "anti-sweat"
Apr 05, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Four prong cord three prong outlet
Ok this is how you will wire the three prong to the dryer.
You have 2 wires that are gold/brass in color, those are the hot wires.
You have 1 wire that is crome/silver in color, that is the neutral
On back of fryer where you wire it you put the wires on like this right to left Gold/brass hot, silver/nuetral, then the other hot wire.
On back of dryer you will have screws from right to left this color gold/brass, silver/crome, then gold/brass again.
If you do have a 4 wire cord the extra wire is ground and you screw that to the machine body.
Mar 14, 2010 | Roper RGS7646KQ Gas Dryer
No heat .....motor is hot,,,, heater blows gold air......ac works fine
no heat .....motor is hot,,,, heater blows gold air......ac works fine
Jan 09, 2010 | 1999 Ford Windstar
Gold N Hot 'N Hot GH9271 Professional Portable 1200 Watt Hard Bonnet Dryer Logo
27 people viewed this question
Top Gold N Hot Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Gold N Hot Health and Beauty Expert? Answer questions, earn points and help others
