Question about LG MG230d Cellular Phone
Lg 7020 usb driver - LG MG230d Cellular Phone
Why won't Brother DCP 7020 Scanner connect to computer?
Try opening the Scan function from the computer and pull it from the MFP printer instead of being at the scanner trying to push it to the computer. Your Brother DCP 7020 would have to be on the same network and installed on the computer you are trying to use. Check your usb cable, Ethernet cable or if wireless - check the Wi-Fi connection settings (network name and correct passphrase).
Aug 30, 2014 | Brother Dcp-7020 All-in-one Laser...
How to install DCP 7020 Printer software, without CD-ROM?
Manuals, drivers and other info for the DCP-7020 can be obtained from here, if your operating system is supported.
Good Luck!
Feb 08, 2010 | Brother DCP-7020 All-In-One Laser Printer
I'm running xp pro sp3. I have a brother dcp 7020. I can't install the scanner and ocr software. the install gets as far as searching for the usb connection aqnd hangs up. What can I do? Just use the 7020...
Make sure it's plugged into a good USB port and that Windows responds to that.  If you're using the most recent driver install program, things should go fine...otherwise, perhaps something is keeping the printer authentication handshake from going on (antivirus, firewall) and you can chill that out for the time it takes for the install to succeed.
Aug 12, 2009 | Computers & Internet
Printer wont work
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 06, 2009 | Brother DCP-7020 All-In-One Laser Printer
SCANNING WITH A BROTHER DCP 7020
I cant find the machine DCP-7020 but I think this machine is the same with model MFC-7420 if you have the installer CD follow these steps:
For USB Interface Cable Users
For Mac OS® 9.1 to 9.2
& Software
1 Turn off and unplug the MFC from the AC outlet and disconnect it from your Macintosh, if you already connected an interface cable.
2 Turn on your Macintosh.
3 Insert the supplied CD-ROM for Macintosh into your CD-ROM drive.
4 Double-click the Start Here OS 9.1-9.2 icon to install the printer and scanner drivers. If
the language screen appears, select your language.
5 Click MFL-Pro Suite to install.
6 Follow the on-screen instructions, and restart your Macintosh.
7 Connect the USB interface cable to your Macintosh, and then connect it to the MFC.
DO NOT connect the MFC to a USB
port on a keyboard or a nonpowered
USB hub.
8 Plug in the power cord and turn on the MFC.
9 From the Apple menu, open the Chooser.
10 Click the Brother Laser icon.
On the right side of the Chooser, select the
MFC to which you want to print.
Close the Chooser.
The MFL-Pro Suite, Printer driver and Scanner driver have been installed.
To install Presto! PageManager, click the
11 Presto! PageManager icon and follow the on-screen instructions.
Presto! PageManager has been installed and the installation is now complete.
You can easily scan, share and organize photos and documents using Presto!PageManager.
Dec 11, 2008 | Brother DCP 7010 Multifunction Laser...
DCP-7020 start up confusion!!
Yes, you can get the power cord and the USB cable from any electronics store. For the USB cable, get one that is an "A-B" cable, e.g. the cable with a square head on one end and a rectangular head on the other.
The power cable should be a standard 120v cable with male pins on one end (that go into the outlet) and female on the other (that go int othe printer. A used computer store would have lots of those they'll sell you for pretty cheap.
You will need drivers and software to use the printer. This normally comes on a CD, but you can also download it online.
http://drivers.softpedia.com/progDownload/Brother-DCP-Full-DriverampSoftware-Package-Download-19399.html
Jan 31, 2008 | Brother DCP-7020 All-In-One Laser Printer
Printer Fault
USB port is set wrong on driver...
Unplug usb, delete driver, reinstall driver, plug usb in only when directed by install
Jan 15, 2008 | Brother DCP-7020 All-In-One Laser Printer
LG MG230d Cellular Phone Logo
13 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
