Question about 4-Button Remote Start/Keyless Entry with DP II Technology
Remote start cranks but won't start
The car receives signal, and doors unlock, but when I try to remote start, the vehicle only cranks but won't completely start. When I try with the key, it starts up right away. Also, sometimes when I try to use the remote in the mornings, the car won't respond to it and I end up having to put it in valet mode and reprogramming the remote in order for it to start responding to the remote again.
5 Suggested Answers
jpk528
  • 95 Answers
SOURCE: remote got wet
you can try reprogramming the remote to the remote start but if that doesnt work you will need to purchase a new one.
Posted on Feb 19, 2009
SOURCE: no lights flashing or siren when I activate or deactivate
where is your program button??
Posted on Aug 11, 2009
raineman_15
  • 273 Answers
SOURCE: I have a 95 yukon and my auto start will make the
It sounds like your security bypass isn't programmed or needs to be replaced. Try to reprogram it and then start the vehicle. Shut it down and try to start it a second time, if it doesn't start the second time the bypass needs to be replaced.
Posted on Dec 15, 2010
valeantudor
  • 787 Answers
SOURCE: My remote start 2 way is working but not
Is it a Viper remote?
Posted on Mar 02, 2011
Where is the keyless remote receiver on a 2008 srx
Remote control door lock receiver (RCDLR)
The remote control door lock receiver (RCDLR) is a multifunction module that operates both the keyless entry system as well as the TPM system. When an RF message is received from a keyless entry transmitter, the RCDLR interprets this signal and will request via serial data that the body control module (BCM) perform the specific function, i.e. door lock, door unlock, or vehicle locate.
Remote Control Door Lock Receiver (RCDLR)
In the right rear quarter panel behind the interior trim panel
Jan 23, 2018 | Cars & Trucks
Looking for location of the keyless remote control module on a 2010 Chevrolet Avalanche LT
The remote control door lock receiver (RCDLR) is a multifunction module that operates both the keyless entry system as well as the tire pressure monitoring (TPM) system. When an RF message is received from a keyless entry transmitter, the RCDLR interprets this signal and will request via serial data that the body control module (BCM) perform the specific function, i.e. door lock, door unlock, or vehicle locate. The RCDLR also sends messages out to the 2 Way Advanced Remote Start transmitter.
Remote Control Door Lock Receiver (RCDLR) (AP3 or AP8, without E52)
Top rear of the passenger compartment above the rear window
Remote Control Door Lock Receiver (RCDLR) (AP3 or AP8, with E52)
Left rear of the vehicle behind the D-pillar trim panel
Body Control Module (BCM)
On the lower left side of the I/P to the left of the steering column
Good luck !
Jun 05, 2017 | Chevrolet Avalanche Cars & Trucks
I have a 2005 colbalt ..i dont hv the remote key..everytime i open the door with key or not alarm goes off..first like a horn sound then louder it goes off and sometimes not untill u turn key on
thats how its suppose to work the key resets alarm ==by a fob online for a few dollars and program to car [free program] ==when you use key to unlock and enter vehicle you have a few seconds after opening door to turn vehicle on or start it and doing so resets alarm when you leave vehicle and lock it alarm is active
Jul 25, 2016 | Cars & Trucks
How does the ignition interlock work on the mazda mpv 2003 ? I can't start the car without the remote control : Simply turning the key will not even crank, does nothing.
Often, you need to press the unlock button on the remote twice. First press unlocks the door and second press disables the immobiliser and allows the vehicle to start. The key alone will not start the vehicle.
Alternatively, when the key is in the ignition - press the remote unlock again.
The remote acts as an immobiliser device. The reason your car won't start on the key is probably because the system won't allow any key in the ignition - it is preventing theft of the vehicle. Once the unlock button on the remote is pressed the system then recognises that key is the legitimate one for the vehicle and the disables the immobiliser and allows you to start the car
Feb 19, 2016 | Mazda Cars & Trucks
Remote start sends signal but truck just cranks over no start
Change the batteries in the remotes. What happens when you press your starter button is it sends signal to the car to crank and then it needs to send another signal to start. The second phase would fail because the battery in the remote was low. Try replacing the and see if that works
Jan 03, 2014 | Remote Start System
Why won't my 2008 Chrysler Aspen start?
You have 2 issue going on. Its not seeing a valid key,and it is starting with the remote.Your remote entry key did it happen to get wet? Or moisture get in? Lock the vehicle up using the key. enter the vehicle using the key fob.After the vehicle unlocks you have 60 seconds to enter the vehicle insert the key in the ignition start it up.Your remote start up is out of step.
Mar 10, 2012 | 2008 Chrysler Aspen
Hundai Tucson 2006 starting or stop problem
Engine stop without warning,more highly failure is the cranksensor signal dropping out,when it fails you have this problem, when you crank it and the crank signal cannot put out the required signal the ECM triggers the alarm.Becuase it doesnt know the vehicle is cranking.
Mar 07, 2012 | 2006 Hyundai Tucson
Have a Audiovox 901C installed and factory remote will not unlock while remote started. What wirre do I use to by pass.
There is no solution to make your factory remote work when the car is running. This is the issue with honda/acura, toyota/lexus, some fords, etc. Here is what must be done; connect the blue/black of the four pin connector from 901C to the unlock and/or disarm wire of the vehicle. This will unlock the door before start. Also, you have to connect the black/yellow to the vehicles lock wire to relock the doors during crank or, the black with green to relock the door after start. Now, you will be able to press and hold the start button of the 901C remote to unlock the doors while running.
Feb 18, 2011 | APS-901 Prestige Remote Start
I have a 98 GMC JIMMY. Remotes and Dome Lights stopped working. Car would start then immediately die. Took it to the dealer and they stated it was the Body Control Modual (BMC). Picked up the vehicle...
Keyless Entry System Circuit Description
The Power Door Locks/Remote Keyless Entry control system provides several functions. The driver operates the vehicle door locks and rear window release from outside the vehicle using a hand-held radio transmitter. The transmitter sends coded signals to the remote control door lock receiver. The remote control door lock receiver detects and decodes the signal from the transmitter. The remote control door lock receiver issues signals to the body control module (BCM) through a serial data link. The BCM actuates relays to lock and unlock the doors and liftgate. The BCM can also release the liftglass. The power door lock switches provide manual control of the door locks.
Transmitter Programming
Important: Different keyless entry systems are used on General Motors vehicles. The parts are not interchangeable even though the parts may appear to be similar. Observe the back of the transmitter in order to properly identify the system. On 1998 S/T pickups and utilities, use a transmitter identified with GM/UTA preceding the part number.
With the driver door closed, hold down the power unlock button on the door panel.
Turn the ignition switch to the ON position.
Turn the ignition switch to the OFF position.
Release the power unlock button on the door panel.
The remote control door lock receiver will respond in the following manner in order to indicate that the receiver is in the programming mode:
6.1. Locking the doors
6.2. Unlocking the doors
Important: All extra transmitters must be programmed at this time. When a new transmitter is programmed, it will deactivate the old transmitters.
Hold down the lock and unlock buttons on the transmitter until the remote control door lock receiver will respond in the following manner:
7.1. Locking the doors.
7.2. Unlocking the doors.
Repeat step 7 for each additional transmitter.
Turn the ignition switch to the ON position in order to exit the transmitter programming mode.
May 04, 2017 | 1998 GMC Jimmy
Scytek 5100 RS-2W system Problem
How do you reset the remote, alarm. I have a scytek two way security alarm, remote start. I can lock and unlock my vehicle, however the remote start and alarm won't work. When I press the middle button to have the car start it just beeps, and when I lock my car it just locks it doesn't beep to let me know the alarm is on.
Please advise, do I need another alarm, or just reset it.
Claudia
Aug 14, 2009 | 5000RS-2W Remote Starter with...
4-Button Remote Start/Keyless Entry with DP II Technology Logo
Top Crime Stopper Vehicle Parts & Accessories Experts
Colin Stickland
Colin Stickland
Frank Mangiapane
Level 1 Expert
Steve
Steve
Are you a Crime Stopper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
