Question about Canon PIXMA iP3500 Printer
Error code 5100 light flashes green yellow
Caraige slams back and forth when turned on and off, before this it would not print any color
SOURCE: IT WONT PRINT
me too
Posted on Jan 08, 2008
SOURCE: error 5100
Hello! Try this:
1. Unplug the power cord
2. While pressing the ON button, plug the power cord back in.
The power light should flash an orange/yellow color.
Continue pressing the ON button, and press the RESUME button 4 times. The light changes every time you press it.
3. Release both buttons, and restart the printer.
The printer should now stop blinking and operate as usual.
I hope this works for you. OMS
Posted on Apr 07, 2008
pineworks
  • 4041 Answers
SOURCE: error 5100? What does that mean
Hi You can Try 2 things.
There is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Next try.
It may be a piece of paper or a scotch tape or a staple wire.
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 10, 2010
Rider On Way
  • 1679 Answers
SOURCE: error on screen 5100 color light &
I just went through this. My problem was that I had something obstructing my print cartridge. I took the back off with 3 screws, then the side panel (on the cartridge side). this was real easy, take the trim off and there is one screw, then find the little arrows that show where the tabs are that slide into the side of the printer itself. I used a flat head screw driver to unsnap them. Once open, I tipped my printer side ways and saw the object in there. Put it back together and now it works.
But the problem you are having could just be as simple as a loose cartridge. Take the cartridges out and put them back in making sure they snap in.
Good Luck!!
Regards,
Ron
Posted on Mar 22, 2011
F Victor man
  • 817 Answers
SOURCE: I have a cannon MP 510. When I turn it on, the
I suspect you had a paper jam and removed it from under the main cover. It sounds like you have got grease on the encoder strip (the long blackish plastic strip that runs the full width of the machine. The carriage looks at the encoder so it knows where it is. Clean the encoder with soapy water on a cotton bud. You may have even snapped the encoder which will mean you will need a new one.
Good luck
Posted on May 26, 2011
Printer error code 5100
I got error 5100 after a paper jam. There was a small piece of torn paper stuck in the gears, and I had to mess around and move the print cartridges back and forth to get seated back on the ink pads to the right of the printer (if you're looking at it from the front).
Reset the printer by powering it off for 10 seconds and try to repeat a test print.
I was able to get mine to work after a few tries. Good luck.
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
let me know if this is helpful to you
Dec 09, 2009 | Canon Office Equipment & Supplies
CANON I350 DOES NOT PRINT
Green and yellow is a service error, but it flashes a longer green, and then the green yellow flashes, and a longer green again. You need to count the number of yellow-greens in between the longer green flashes, to know the error code.
Sep 17, 2009 | Canon i350 InkJet Printer
Flashing green and yellow lights
You need to count the number of flashes to diagnose the error. Then go here and type error lights in the search box. You';; be able to follow the appropriate code to a solution.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 24, 2009 | Canon iP100 Portable Printer
Cannot get Canon PIXMA MP 150 to work at all
salve la mia mi canon mp 150 lo scanner non funziona e mi da errore code 2,250,0
Apr 18, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Error 5100
Hello! Try this:
Apr 05, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
CANON PIXMA IP1200 resetting
My converted iP1200 is currently blinking green, yellow, green, yellow on the power lights after start up and print request. The pop-up prompt suggests turning off the printer and turning it back on. Error 5100 is always seen.
Please Help Me...
rakibfuture
Mar 30, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Canon pixmaip3000 states printer offline & does not print, flishing power lights green & orange
I have canon PIXMA ip3000. After power cut at night printer doen not print. I re installed the drivers but no result. When try to print message appears printer is offline. POwer button is flashing shorthly green after orange lights. Error code 5100.
Please advice what can I do urgently.
Mar 10, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Pover up trouble
sounds like something is drawing down on your 12 volt supply drives or on board regulators. Try it without the drives connectged, and see if you can get the system to boot up(you'll just get a notice that your drives are unavailable, but you'll already know that, right?
got backup for your Dell?
Feb 15, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Dell 720 printer
Replace the printer- there are no professional repair options here You could take a look at www.fixyourownprinter.com
Jun 12, 2007 | Dell Inkjet 720 Printer
Dell 922 printer giving error code 1200
I get error 1200 and print carrier stall.  The carrier moves fine when I turn it on, in fact it slams to the right!  Will not print at all!
Mar 23, 2007 | Dell 922 All-In-One InkJet Printer
Canon PIXMA iP3500 Printer Logo
16 people viewed this question
old marine
old marine
