Question about Hunter Ceiling Fan Light Remote Control
Transmitter sku#175-776 I replaced the battery, I see the light on the remote when I press light button, but the light on the fan doesn't go on. It was working yesterday.Even the fan. Today nothing works Please help N
4 Suggested Answers
  • 323 Answers
SOURCE: remote not controling fan
You either have a bad receiver or the receiver isn't wired correctly,
On the receiver house wire side are black, white, and green.
On the receiver fan side are white, black, blue, and green. The black is hot for the fan, the blue is hot for the light. They can be wired together from receiver to fan.
At the bottom are a blue and a white wire to go to the lights.
Sometimes when installed the receiver is placed so that a part of the wiring box obstructs the signal from the remote and it doesn't work properly, or misses some commands.
I recommend buying a new remote and receiver and wiring the receiver in so that it rests on the sheetrock beside the wire in box.
Posted on May 26, 2009
perkins48
  • 14406 Answers
SOURCE: I have a Hunter ceiling
I'm assuming your fan is connected to a switch on the wall,if it doesn't turn the fan or light on,as your remote doesn't,then your electrical wires have come loose causing you not to have power to fan,you will have to remove the parts to get to your wing nuts holding your wires together to make a good connection and put electrical tape over wing nuts and wire to keep together,vibration will cause them to come loose,make sure you turn power off at breaker.
Posted on Aug 29, 2011
  • 27 Answers
SOURCE: just replaced the battery remote
Some remotes have a learn button in them, when it lose its power you need to relearn it. Hold the small button for about 5 seconds, to reprogram it with the receiver. If it doesn't work ,then your receiver may need to be replaced.
Posted on Sep 03, 2011
Can a the transmitter and receiver be replaced by wall control for a Hunter fan model 28425?
The part # you need is 85662-01-000. Maybe you can find it somewhere in cyberspace.
Aug 01, 2014 | Hunter 52" Ceiling Fan With Light And...
Can I reprogram my keyless remote from my 1995 eldorado to my 1996 cadillac eldorado
AS programs can be altered I would have it checked out at a dealer service centre as they will need the keys and the vehicle to see if it can be done
Jan 11, 2014 | 1996 Cadillac Eldorado
I have a ceiling fan with a remote and the remote stopped working. The light blinks on the remote when I press the buttons, but the fan doesn't work. The model number of the
The light on the remote is just a battery indicator light. I would try changing the dip switches in the receiver & transmitter first. If that doesn't work, you probably need a new receiver. Good luck since this is a cheap store brand.
Oct 01, 2013 | Hampton Bay 24002 Ceiling Fan
Skytech 1410 fireplace remote (8 yrs. old) has stopped working. Replaced batteries in the transmitter. The red light lights up when
It may need to be re-synchronized:
Make sure the receiver's slide switch is in the REMOTE position.
Press and release the LEARN button on the receiver.
When you hear the "Beep", press and hold the ON or OFF button for about 2 seconds on the transmitter.
You will then hear a series of beeps that indicate that your new transmitter has been accepted by the receiver.
If you press the LEARN button on the receiver and you hear no beeps, the receiver is unable to retain any more transmitter codes
(make sure the transmitter battery is properly installed and fully charged).
To delete all of the transmitter codes on your receiver, press and hold the LEARN button for 10 seconds. Then you will hear a
series of beeps, indicating that the receiver's memory has been cleared.
It could also be dead after 8 years. A new unit can be purchased here: Skytech Remotes. I would even suggest on of the new styles with a built in timer or thermostat.
Nov 08, 2012 | Skytech 1001-A Fireplace Remote Control...
Just replaced the battery remote will NOT work.... I have a very high ceiling.... this is getting annoying.... when I press the remote I get a red light wether I ask for fan or light.... light just blinks...
Sep 03, 2011 | Hunter Ceiling Fan Remote Transmitter...
My fan was working with the remote then it stopped. I replaced the battery but the light doesn not light up when I push the button on the remote. Am I able to order a replacement remote without having to...
Before you rush out to by a new hand held remote, Check the battery to make sure it' s facing the right direction. Also, wipe off the receivers sensor, on the front of the AC unit, as dust and dirt can block it from receiving the infrared signal, If you do end up having to replace it, you can buy just the hand held remote transmitter, that's all you'll need to purchase. It will come with instructions on how to program to your existing receiver. You can probably get one from the manufacturer of your AC unit. Be sure to have the correct Model Number of your AC unit when you do.
Hope this helped you, Mary Alice. Please let me know. Thanks.
Jul 15, 2011 | Heating & Cooling
The fan/light will not come on with the remote. Yes remote batteries are new. The light fixture have power. I think the model # is JY97381. receiver # is UC7067RC. Unsure how to fix this problem. Can u...
Hello Susan,
If the indicator light on your hand-held transmitter lights up when you press the buttons, it normally means it's working. The problem is probably with the UC7067 receiver in the fan. One sure way to destroy the UC7067 is to have the power going to it controlled by a dimmer switch on the wall. If this is the case, replace the dimmer switch with a standard on/off toggle or an in-wall transmitter. You can find both a replacement UC7067 receiver and either another hand-held transmitter RC-210 or an in wall transmitter WC-210 at this address: http://www.fanmanlighting.com/shop/pc/viewCategories.asp?idCategory=57
Hope this helps!
Dec 11, 2010 | Minka Aire Ceiling Fan
Hunter fan remote 85095-02, red signal light glowing continualy
It's continually transmitting. My guess is there is a button stuck causing the unit to run down batteries. If no button stuck, you'll probably have to replace the remote -- it's a fulty transistor.
Charlie
Aug 25, 2009 | Hunter Ceiling Fan Remote Transmitter...
Older Model Hampton Bay Ceiling Fan: The Redington II w/Remote Control
Ironically, i am having the same problem with TWO different Reddington's in my house.
One is brand new, just hung a few weeks ago, the other is about 3 years old.
The new one -- the lights are stuck in a constant dim, bright, off, dim bright off, and the fan wont turn at all.
The old one, the lights wont come on and the fan will only spin slow.
Both failed within a day or two of each other, and this is driving me nuts.
I thought it might be the remotes, so I took both remotes and pulled the batteries out of each, but that didnt do anything.
If anyone else is having this problem, please post.
Dec 11, 2007 | Hampton Bay 52 In. White Redington...
No connection between the fan remote and Ceiling fan
The remote-controlled fans that I've seen all have DIP switches in the transmitter (the "remote") and receiver (up by the fan). For the remote to operate the fan, both sets of switches have to be set to the same code. If you happened to bump the DIP switches (and change the code) while replacing the battery, the fan would no longer respond to the remote.
It's been four months since you posted this problem, so you've probably figured that out by now. Still, other users may run into the same problem occasionally.
Dec 08, 2007 | Universal Remote Control Hampton Bay...
Dryers Logo
48 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
