Question about Epson Stylus NX330 All-In-One Printer
Printing crooked the text is printed crooked on a sheet of paper
  • 18 Answers
SOURCE: paper feed malfunction
sounds like the item in the paper path that you can not see. or it has a faulty sheet feeder or some gears have failed in the printer
Posted on Sep 25, 2007
SOURCE: paper either just rolls through without printing or won't catch and sits there
Me again. I had to get a repairman to come out and he basically CLEANED the bejeezus out of the rubber roller section that pulls the paper through. Seems alright again. For now... He used a solvent (said lighter fluid was okay for this purpose- because I had some on hand from a friend who uses it for cleaning such thing, and he fixes printers as part of his work). He wetted a rag with the solvent, and wearing rubber gloves, worked those rubber rollers over good. That seems to be the answer.
Posted on Feb 07, 2008
sherlyn c
  • 134 Answers
SOURCE: I need a repair service for EPSON stylus photo
Please log on to epson.com. Click on north america, then usa. Go to the drivers and support page. Click on help me find a service center to the right of the page to find an epson certified servicer near to your area.
Posted on May 04, 2009
virtualhost
  • 2185 Answers
SOURCE: Epson stylus DX3800 All in one printer, scanner Unable to print
Open the printer cover and look closely for tiny paper shreds that might got stuck between the rollers. If you have a canned air, try blowing out the paper path as those tiny piece of paper might be blocking the paper sensor.
Posted on Sep 20, 2009
Testimonial: "tried blowing and dusting with a brush Now it comes on as normal - no flashing light but will only take paper about 2 cms then flashes paperjam"
  • 526 Answers
SOURCE: Epson R340 does not feed paper or feeds it crooked
two things I would do, first carefully flip the printer upside down, (anything that looks like it can flap open, tape it well), and jiggle it slightly and see if anything falls out.
second, i would clean the pickup roller with an alcoholic pad or swab, if its not easily accessible, you will probably need to take the upper an middle casing off, which I dont recommend.
thanks adi
Posted on Jan 02, 2010
How do I align the HP Laserjet 1020 to print straight? Its printing crooked every time. No two sheets are in the same position
Most likely to be a page feed problem, look online to clean page feeder rubber rollers.
Try here for the pdf manual which covers problem with jams and skewing
http://www.hp.com/ctg/Manual/c00264334.pdf
Mar 05, 2015 | HP LaserJet 1020 Printer
Printer sending out print crooked at the end of the page
Hi and welcome to fixya
the problem the you are telling is with your printer tray. check it carefully and adjust it with the given adjustments then paper should b came out smoothly
Dec 08, 2012 | Epson Stylus C66 Photo InkJet Printer
My calibration page printed on plain white text paper
When you calibrate the 5100 AIO, first, you push in the photo paper drawer until it CLICKS. Next, print an alignment sheet. It will use the photo paper. Pull the drawer out, put the printed sheet in the scanner bed, with the arrow in the right hand corner, closest to you. Press start and it will scan and print a sheet on full sized paper.
If your initial scan doesn't print onto photo paper, you don't have the drawer pushed in the whole way. There is a definite click and the green light will turn on.
May 14, 2011 | Kodak EASYSHARE 5100 All-In-One Printer
Canon MX860 prints crooked!
Does this happen when printing from the cassette (bottom tray), or the sheet feeder in the back, or both? Check that the paper guides are set snugly (touching but not buckling the paper) against the edges of the paper.
Apr 29, 2010 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
HP Deskjet 5150 print is too small
Printers try to fit web pages on a single sheet of paper. If you configure the printer, in the print dialog, not to shrink images and text to fit the paper, it will print on multiple sheets of paper, but the correct size for the images and text.
In a Word document, it depends on what font size you have selected. Most people would rather have the web page print on a single sheet, with smaller images and text than were on the monitor; than tape together multiple sheets for 100% size printout.
Jan 31, 2009 | HP DeskJet 5150 InkJet Printer
Printer either eats up paper or won't print anything out
what you might try is to find some thing that has been laminated on both sides and manuall feed it in to the feed rollers and see if you are able to push out what ever is in the paper path making your paper go in crooked. brother tech
Jan 17, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Alignment page is printing crooked
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 06, 2009 | HP PSC 750xi All-In-One InkJet Printer
Samsung SCX-4200 manual feed prints crooked
You need to change the pick up rollers for your printer if it pulling the paper unevenly... but first check to see that the paper size adjuster on the tray i self is set to your paper likeness.....adjust to the correct paper size if not...
Please don't forget to vote!
Cheers!
Nov 13, 2008 | Samsung SCX 4200 All-In-One Laser Printer
Brother HL 2040
Make sure the paper aligning slides are tight to the sides of the paper. In the case that they are spring loaded make sure there is not something preventing them from holding the paper properly aligned.
The print head could be 'off-track'...
If the text is properly aligned on the edge of the page, but appears crooked it is related to the print head assembly. If the text is not aligning to the edge of the page then the paper is not feeding straight and the paper aligning slides are at fault.
It is also possible that one of the paper feed rollers are not grasping the paper and it is forcing it to one side as it pulls it in.
Mar 10, 2008 | Brother HL-2040 Laser Printer
Laser Jet 4 Plus
Make sure your sheets are aligned and tucked in with the paper feed rails, otherwise, it will slightly veer off one of the sides.
Also, if you haven't replaced the paper feeder rollers, do so, one must be worn out more than the other, and this also prevents the sheets from going through straight.
Hope That Helps!
Feb 01, 2008 | HP LaserJet 4 plus Printer
Epson Stylus NX330 All-In-One Printer Logo
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
