4 month old computer does not charge battery more than 48%. Does lenovo have junk for batteries?
Very disappointed with the battery of this computer. 4 months old and already the battery only charges 48% when full. This is my first Lenovo poduct. I never had this problem with Toshiba computer.
SOURCE: Battery is not charging
From HP website- worked immediately for me.
This document pertains to HP Notebook PCs with Windows Vista. Understanding battery charging issues If the notebook battery is not charging or the notebook does not indicate that the battery is charging, the most likely scenario is that the battery itself is operating correctly, but its power management software may have become corrupt. In order to correct the problem, you will need to uninstall and reinstall the power management software by using the Device Manager. This document will explain how to uninstall and reinstall the ACPI Battery listings in Windows Vista, as well as how to obtain and install updated BIOS files, if needed to correct other battery issues. Uninstalling and reinstalling power management software in Windows Vista In order to correct problems with the battery's power management software, follow the steps below.
  1. Click Start and type device in the search field, then select Device Manager .
  2. Expand the Batteries category.
  3. Under the Batteries category, right-click the Microsoft ACPI Compliant Control Method Battery listing, and select Uninstall . WARNING: Do not remove the Microsoft AC Adapter driver or any other ACPI compliant driver.
  4. On the Device Manager taskbar, click Scan for hardware changes c01176420.gif . Alternately, select Action > Scan for hardware changes .
Windows will scan your computer for hardware that doesn't have drivers installed, and will install the drivers needed to manage your battery's power. The notebook should now indicate that the battery is charging.
Posted on Mar 06, 2008
Ranvens
  • 61 Answers
SOURCE: VAIO VGNTZ150N Laptop battery runs down when not in use
If the laptop is gone into a suspended mode it is still powered on but sleeping. This will continue to use power and will power down the battery over time.
You could enable hibernation which saves the current state of your pc so that when you activate it again it restores to your previous state of work. This will use close to no battery power to perform.
Posted on Apr 24, 2008
  • 39 Answers
SOURCE: Lenovo 3000 N200 battery wont charge
no it might not be a battorey problem it could be a software problem,
Posted on Sep 13, 2008
SOURCE: Lenovo 3000 N200 battery not charging.
I just had the same problem. My battery had discharged to less than zero and would not start even though the power plug was in. I tried everything... but what fixed it for me was to remove the power plug, remove the battery, plug in the power cord and start the machine. Once the machine was already booted, I put the battery in and it started charging. Dont know if that will fix your problem, but it fixed mine.
Posted on Oct 22, 2009
SOURCE: Lenovo Y530 T 3200 3GHZ 4G Laptop not charging
Take the battery out, with the power plugged in replace battery, orange battery level lights on the laptop will light probably stay on for a few seconds then go out. Repeat until battery level lights indicate a lower level usually one light. continue watching charge state ( the blue battery led on the lower left on the laptop should be blinking) once the battery gets a start charge it should continue to fully charge. Sometimes batteries drained too low don't have enough power to run their internal circuitry to start charging.
Posted on May 12, 2010
Re: Lenovo laptop, series 3000 Is 45% battery capacity sufficient to upgrade BIOS?
As long as you have a good power source from the mains, all will be fine but ensure your firewall is allowing the upgrade!
May 03, 2017 | Lenovo Computers & Internet
Why won't my car start? Battery seems weak. Had it checked. Only 2 yrs. old.
Yes to all of those! Have you checked the alternator is charging the battery?
Aug 15, 2015 | 2000 Ford Expedition
Lenovo Z500 battery
I did not work for me in the beginning because Z500 didn't know it had a battery.
1. First do a clean install of Windows 7.
2. Install all the drivers only for Lenovo site and respect the restarts. Install Lenovo Energy Management last. Go to Lenovo Energy Management and set it for full Performance.
3. The indicator in the animation should be far right not center.
4. Go to Advanced Power Settings in Control Panel -> Lenovo Energy Management and hit ENABLE
5. Now you restart and you should be able to do the firmware update
6. If you cannot do the firmware update then uninstall LEM, remove ACPI from Device Manager, Reinstall LEM, Enable again.
7. If you cannot do the firmware update then try battery gauge reset in Safe Mode and remove ACPI after, and then Reinstall LEM, Enable.
Jul 20, 2013 | Computers & Internet
Lenovo battery won't charge
Battery not charging usually means its dying! If your battery under one year old, you can get replacement from Lenovo. If its older than three year old, its time to find a new battery!
Is the battery not holding the charge at all? that means is the computer shutting off as soon as taken from power outlet or battery lasting less than expected...
Sep 27, 2011 | Computers & Internet
Lenovo Z560 laptop battery charge drops from 50% down to 7% suddenly. And after that, i need to charge the laptop where it gets charged till 99% only. What is the problem i am facing now?. I purchased the...
A sudden drop from 50% to 7% means that the battery is faulty, it is simply a case where it is not holding any charge. I would suggest you contact the seller and check if the battery is under warranty. Hope this helps and good luck.Any question please feel free to ask.
Dec 30, 2010 | Lenovo IdeaPad Z560 Notebook
My problem with my Lenovo is somewhat the same but different. It started shutting off for no apparent reason. We also took out the battery with no longer worked. Bought a new on from the factory and...
If your computer works directly to electricity without the battery, then the battery is faulty. Battery showing you 99% does not mean it is working, because bad battries gets full on time. The cell of the battery might have been dead because only GOD knows how long it had stayed in the factory.
But if you are convinced that the battery is good, then check the adaptor, and if the adapter is good.
Just try to check everything to ascertain the fault. And let me know what happens next.
I wish you the best.
Nov 13, 2009 | Lenovo 3000 N100 CoreDT2080 VB PC Notebook
My battery in my Y510 Ideapad shows full charge but when I go to unplug my power cord the computer shuts down as if there is no battery in it. Is there any way to diagnose this problem? I always keep it...
you should let the battery drain occasionly.it keeps them longer.id say you have wore out the battery by constantly charging it.only other could be adapter is bad.
Sep 27, 2009 | Lenovo IdeaPad Y510 Notebook
My ibm lenovo laptop is plugged in into the AC power, it shows that the battery is charging but when i press the power button so the computer could start up, it won't power on. i removed the battery and...
Had a gateway laptop that had similar issues. 1. Has the unit ever overheated ? . if so you may have to open the case down to the battery, hopefully the unit has a plug in style battery, when you unplug it and wait 30seconds, then plug it back in you will reset the bios on the unit. I was about to junk my 6 month old computer until i tried this step. put it back together... every thing resumed as normal didnt lose or change a thing. hope this helps
Aug 25, 2009 | Lenovo ThinkPad SL500 Notebook
Advent 4211 battery light flashes orange mains power only
Yeah the same has happened to lenovo x61s, i contacted the supplier and they told me i need a new battery, unfortunatly laptop atterys arnt the cheapest things around
Jun 07, 2009 | Advent 4211c Notebook
Battery problem-plugged in, not charging. Lenovo 3000 N100.Type:0768.Model:24U.S.no:L3LA215. Please offer a solution.
Had the same problem with a manufactured refurb, would go to 79 %, if you go to power options, change plan settings, change advance power settings, then to the Lenovo energy management tab, press the big enable Lenovo energy management, click on the blue gear to the left of the question mark, if "Optimize for Battery lifespan" is selected it will only charge the battery to 80%, change this to "Optimize for Battery Runtime" and it will charge to 100%
Feb 26, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Computers & Internet Logo
11 people viewed this question
David Payne
David Payne
