Question about Canon Eos Cameras
Top edge of my photo is a black diagonal shadow
    Problem Solver:
  • 10 Answers
Speed change its working
Posted on Nov 17, 2017
    Guru:
  • Canon Master
  • 575 Answers
Also check your sensor, the part that sits behind the lens.
You may have dirt or some foreign object stuck in there.
As this is a fragile imaging part, blow it with a squeeze-bulb blower brush.
    Master:
  • Canon Master
  • 442 Answers
Sounds like it could be vignetting from either a lens hood or an accessory. Are you seeing this in all photos or flash only? If flash, sometimes a wide shot with a lens hood on will block the flash output and cause the described shadow line.
Posted on Nov 30, 2014
Why does my camera show 2 black sides when I take photos ?It comes up also when I put the photos in my computer
It may be as simple as if you are shooting in RAW by default RAW images are shown with a black edge top or sides, depending on the orientation used, to indicate that it is a RAW image as opposed to a jpeg.
May 11, 2015 | Canon PowerShot Cameras
Epson C88 3/16" gap every inch printing black text
Reload the printer drivers, you can get this from the manufacturers web site under support or downloads.
its a common error and an easy fix.
good luck !
Mar 30, 2017 | Epson Stylus C88 InkJet Photo Printer
Whats the torque settings/pattern for headbolts on a 1998 isuzu pick up truck?
Basic Torque sequences are printed in the more poular DIY Repair manuals sold at Auto Stores. These are COPYWRITTED & I cannot qoute from them without prior permission. There are names such as "Clymer", "Haynes", & "Chilton's" all helpful & good in thier own respects. THEY ARE copywritted. SStep 1: before you even begin a torque sequence, have you taken a "true metal" Straight edge, & taken in diagonally from LH upper corner to RH lower corner, to see if there is warpage, (gap) between the head & the straight edge. Step 2; Go from RH upper corner, to LH lower corner, & again check for gap (warpage) between the head & the straight edge. A "universally" accepted torque sequence is to take your total torque spec's, divide them by 3 & torque in 3 steps. Say it is 90 Ft Lbs. Tighten 30 Ft Lbs, Then 60 Ft Lbs, then 90 Ft Lbs. On an aluminum head; start in the center, top, (or bottom) take it to the 1st 30 ft lb, go to the bolt immediately across from it & repeat. Then take the closest diagonal bolt from it & do the same, cross agin, diagonally to the closest diagonal bolt, & countinue to the last bolt. Take your torque wrench to 2nd Ft Lb setting, repeat. Take your torque wrench to the 3rd setting, repeat to finish. Note: Do to propriety Izuzu, the given Torque Ft Lbs given were for informational instruction only & are ficttious. You must use the proper Ft Lbs recommended buy the Manufacturer.
Aug 31, 2011 | 1999 Isuzu Trooper
Instructions as to HOW TO PLAY DRAUGHTS
  • Set up your pieces on a black-and-white checkered game board with 64 squares of each color. Each player should set their 12 pieces on the 12 black squares closest to them on opposite sides of the game board.Decide who goes first by tossing a coin.Move a game piece forward diagonally along the black squares if you are the first player. You may move only one square at a time per turn and you must go forward on the board.
  • Take your opponent's game piece by jumping over it forward diagonally along the black squares if your opponent has one of his game pieces adjacent to yours and there is a vacant space beyond your opponent's piece. You may take more than one jump if you land on a space where you are able to jump another of your opponent's game pieces
  • Have a game piece crowned as a "king" if you reach the far edge of the board closest to your opponent. Your opponent must place one of the game pieces he has captured from you on top of your king piece to distinguish it from your other pieces. Your king is now allowed to move diagonally forward or backward instead of just forward.Win the game by capturing all of your opponent's game pieces,Hope this helps :D
  • Jul 16, 2011 | Toys
    When I look through the lense everything is just black
    Take the scope outside during the day time. Put the eyepiece with the largest number written on it into the TOP diagonal. There is a "flip" switch on the back that changes between the rear photo port to the TOP eyepiece port.
    Flip it one way or the other until you can see light through the TOP eyepiece. Practice focusing on a distant object during the day time.
    Here is the manual:
    http://www.meade.com/manuals/TelescopeManuals/ETXtelescopes/ETX-90%20w-autostar%20man.pdf
    Dec 15, 2010 | Meade ETX-90EC (325 x 90mm) Telescope
    Shadow along edge of my SHARP DM-3551 copier's copies
    Run a page with the cover or document feeder open. Just a solid black page. If the shadow runs completely edge to edge on the paper, your problem is in the drum unit or less likely the fiser.. If the there is a clean edge delete, then the problem is either dirty scanner mirrors or the laser. It is far less likely in the optical/laser system but still likely. I tend to believe the problem is in the drum unit.
    Mar 12, 2010 | Canon imageCLASS D860 All-In-One Laser...
    Canon PowerShot A620 Photos have shadows
    I was having this problem and found I was placing finger to close to the flash when I was steading the camera.
    Aug 23, 2008 | Canon PowerShot A620 Digital Camera
    Display & photo limited to a diagonal bar
    The fix was simple: The automatic lens cover wasn't opening all the way when I powered up the camera. A simple tap on the lens cover corrected it.
    Mar 10, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
    Rca hd61thw263 61 in. dlp
    Seems a lightning strike took out my bulb
    eventhough i have a surge protector.
    after replacing the bulb perhaps 1 hour later a shadow began to appear at the top of the screen and progressed slowly down until only the edges are visible.
    please can you help?
    Sep 09, 2007 | RCA HD61THW263 61" Rear Projection HDTV
    Cameras Logo
    209 people viewed this question
    Top Canon Cameras Experts
    TC CAMERA REPAIR.Com...
    old marine
    old marine
    Are you a Canon Camera Expert? Answer questions, earn points and help others
