Question about Spherex Xbox 5.1 Surround Sound System Computer Speakers
Yst swo12 how do I connect the speakers to subwoofer
I obtained a pair of Yamaha YST MS50 speakers with no subwoofer. Can they be adapted to use a different sub, such as the inexpensive Yamaha YST MSW5? The clear problem is in different cabling.
If you wish to get some details; check the site linked here. Pull up older posts.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
May 03, 2016 | Yamaha YST-MS50 Computer Speakers
How do I connect the YST-SW45 sub to a different system
It's a standard non-proprietary standalone self-powered sub that accepts any input one could want. Your unnamed electronics will be the determining factor. Manuals spell it all out.
http://www.retrevo.com/support/Yamaha-YST-SW45-Subwoofers-manual/id/320bh343/t/2/
Aug 05, 2011 | Yamaha YST-SW45 Subwoofer
No sound from my Yamaha YST-SW315 subwoofer. When I run the test speakers don't have sound either. Not sure if its the subwoofer or the Yamaha RX-V450 receiver
Feed it with an RCA cable any other audio device you may have (CD, TV, MP3 player, PC) to prove it can or can not woof. It will respond to any audio, not just LFE or subwoofer audio.
Apr 14, 2011 | Yamaha YST-SW315 Subwoofer
I have a problem with my yamaha subwoofer yst sw 215 after about 5 minutes of use it gets this continuous bass vibration through the the sound outlet like its stuck on a bass sound any ideas
could be a problem with one of the filters inside or a short circuit... your best bet would be to have someone skilled in electronics look at it, and stop using it as you may permanently damage your speaker.
Jan 15, 2010 | Yamaha YST-SW215 Subwoofer
Yamaha YST-SW150 Subwoofer
hi, is it a humming noise ??? check if the connector is plugged in properly,check the earthing, if its a three pin mains plug, if its a two pin, then the CPU SMPShave a proper eathing. let me know
Jan 10, 2008 | Yamaha YST-SW150 Speaker
YST-MSW10 quits after about 15 minutes
sounds like a fuse is getting overheated and tripped or to loud, check your volume settings again.
Jul 29, 2007 | Yamaha YST-MSW10 Computer Speakers
Spherex Xbox 5.1 Surround Sound System Computer Speakers Logo
20 people viewed this question
Top Spherex Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Spherex Audio Player and Recorder Expert? Answer questions, earn points and help others
