Question about Cameras
Kodak zx1 use as webcam - Cameras
Video review locked up. I cannot turn off machine or get out screen anyway. Help?
You know when you take off teh batteries the camera is switched off too. But if your camera comes on as soon as you replace the batteries, I think your on / off switch must be jammed. Or perhaps something els could cause a shortage in the camera, doing tehsame as pressing the on switch.
Nov 02, 2013 | Kodak Zx1 Digital Camera
Need instuctions
Click here for the user guide.
Click here for the extended user guide.
Nov 13, 2012 | Kodak Zx1 High Definition Flash Media...
I am attempting to upgrade the firmware on my Zx1 camcorder from version 1.02 to 1.06. I used the the SD/SDHC previously used to extend the camera memory, (with content deleted), to load from my computer...
Did you make a directory on the card called System? It needs the capital S. Put both the files from the unzipped directory (C:/kodak probably) into the System directory on the card and boot the camcorder ensuring there's lots of life in the batteries. I just did it, from 1.02 to 1,06 too, and it worked a treat. The differences aren't huge but the audio is clearer now. Hope that helps.
Jan 24, 2011 | Kodak Zx1 Digital Camera
Can i recover deleted videos?
you can recover deleted videos from camera with digital camera recovery program like asoftech data recovery. find it on facebook
http://www.facebook.com/pages/Asoftech-Data-Recovery/290956907592436?sk=info
You have to use a card reader either on your computer or an external USB card reader. Put the card in the card reader, open the recovery program, then select the drive where files are deleted, then press "Start" and wait for it to do it's magic.
Sep 24, 2010 | Kodak Zx1 Digital Camera
Micro sd card wont read
Check the SD card to see if the 'lock' is engaged. If so unlock and you'll be able to read. Other than that the other possibility is that your card isn't installed correctly. Remove it and check the pin orientation to be sure that it's installed correctly
Sep 23, 2010 | Kodak Zx1 Digital Camera
Kodak ZX1 shuts off randomly every time while in use. Won't stay on for then a few min.
Your problem is likely due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera and give them a full charge (assuming that you're using rechargeable batteries). This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may be due for replacement, or the camera may have a problem that requires professional repair.
Dec 05, 2009 | Kodak Zx1 Digital Camera
How do I set up my webcam on MSN for a C813 digitial zoom camera made by Kodak?
Kodak Easyshare C813 can only take picture, transferred pictures and video to your computer and record video. C813 cannot be use as a webcam if you'll like a kodak webcam you can check this products like Kodak S100 webcam, Kodak W100 webcam and T130 webcam. Check the website www.kodak.com/go/shop and for information about your camera you can visit www.kodak.com/go/C813.
Nov 15, 2009 | Kodak Easyshare C813 Digital Camera
Cameras Logo
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
