Question about Kenmore Digital Rice Cooker
How do I know when Rice is Done?
When I Start my rice cooker on the Brown Rice Setting... It doesn't tell me how long until its done on the timer... Is it Suppose to ? or should it beep when its done???
What else can you do with the rice cooker if you don't cook rice?
You can steam vegetables in your rice cooker. Just make sure you watch the vegetables they will cook faster in your rice cooker than normal.
Sep 27, 2014 | Crock Pots & Slow Cookers
Rice Cooker Timer
I had one, it's just takes practice, time the batch and use a measuring cup, this will help you get dialed in to being the master rice cooker, that hides within you Grasshopper !
Jay the pool pump motor repair guy Longwood Florida
Feb 08, 2014 | Kenmore Digital Rice Cooker
How do I cook brown rice?
Here is a link from Rival with the manuals they have.
Rice Cookers Steamers
Jun 23, 2013 | Rival Automatic Steamer/Rice Cooker 4450...
Where do i get a manuel for Rival steamer/rice cooker model # C4450 serial # 0213
Your manual for the Rival Automatic Steamer/Rice Cooker 4450 can be downloaded from this site:
http://micromatikal.dlinkddns.com:8000/cust/4450.pdf
Sorry someone has not responded sooner.
Oct 08, 2010 | Rival Automatic Steamer/Rice Cooker 4450...
Rival rice steamer instructions
Sep 03, 2010 | Rival Automatic Steamer/Rice Cooker 4450...
Cooking instructions
Here is a tip that I wrote about rice cookers and the amount of rice and water needed...
How much Rice and Water go in the Cooker
http://www.fixya.com/support/r5396567-much_rice_water_go_in_cooker
heatman101
Apr 02, 2010 | Rival Automatic Steamer/Rice Cooker 4450...
Can you boil in a slow cooker?
Generally, with enough heat and good insulation, water will boil. Boiling is caused by non-uniform heating - some spots are hotter.
My wife's slow cooker boils even on the low setting -slowly, but it boils.
Our rice cooker never used to boil until I burned tomato rice in it (OOPs). Don't make tomato rice in a rice cooker.
Mar 21, 2010 | Nutritionist 10 Cup Rice Cooker RA10NR
How much water will i need to fill in well to cook rice in rival4450
11/2 cups of water to 1 cup rice. For softer rice use 2 cups water to 1 cup rice.
May 06, 2009 | Rival Automatic Steamer/Rice Cooker 4450...
Cooking PLAIN rice
Here is my recipe - enjoy and please rate my answer as a fixya!
Raw Rice - 2 Cups (400 gms.)
Water - 6 Cups.
(The ratio of rice to water is 1:3)
PROCEDURE
Step 1:First wash the rice in water thoroughly and drain the water.
Step 2:Take a vessel ,the capacity of which is double the quantity of raw rice that is to be taken.
Step 3:Now,add the washed rice into this vessel and pour 6 cups of water into it .
Step 4:Now, place this vessel containing rice with water in a pressure cooker and add the pressure weight on the cooker top.
Step 5:Heat the pressure cooker for 20 minutes only.
Rice has been cooked.
NOTE:
*After heating the cooker for 20 minutes,donot open the cooker immediately.Wait for 15 minutes and then open ,otherwise the cooker would burst open.
Feb 16, 2009 | Wolfgang Puck 5-Quart Electronic Pressure...
Rival automatic steamer rice cooker 4450 guide needed
Here's all the info I've been able to find:
The older Rival rice cooker steamer should have a base, a lid, steamer basket, and rice bowl.
To cook rice, fill center basin of base with water. Place the rice bowl on basin. Add rice and water as follows. For white rice add water in a 1:1 ratio to rice plus 1/2 cup. For brown rice add water in a 1:1 ratio to rice plus 3/4 cup. Examples: 1 cup white rice, 1-1/2 cup water; 2 cups brown rice, 2-3/4 cups water. Put lid on and plug in and in about 50 minutes you should have delicious rice.
Timing is Everything
Whether using the Rival Steamer for a main dish or for a side dish, cooking is easy. But not Fast. Rice and steamed vegetables actually take twice as long to cook in this steamer. The simplicity comes since you add your rice or vegetables in one step. No waiting for one thing to happen before you can do the next. Put water and fruits, vegetables, fish, poultry or rice in the basket or bowl that come with the unit, cover, plug in and wait for the light to go off per the timing chart.
1/4 cup water takes 6 -7 minutes
1/2 cup water takes 10-12 minutes
3/4 cup water takes 16-17 minutes
1 cup water takes 19-22 minutes
1.25 cups water takes 24-26 minutes
1.5 cups water takes 26-30 minutes
2 cups water takes 38-39 minutes
2.5 cups water takes 43-44 minutes
3 cups water (max fill) takes 45-50 minutes.
Steamed Chocolate Pudding (From the Rival Steamer Guide)
3/4 cup flour
3/4 teaspoon baking powder
1/4 teaspoon salt
1/3 cup butter
1 teaspoon vanilla
1/2 cup sugar
1 egg, beaten
1.5 ounces unsweetened chocolate, melted
1/2 cup milk
1/4 cup chopped nuts
Sift together flour, baking powder and salt; set aside. Cream butter and vanilla until fluffy. Gradually add sugar, beat well. Add egg and melted chocolate; blend well. Add milk alternately with dry ingredients and beat until smooth. Fold nuts into batter. Pour into greased 8"x4" loaf pan. Cover pan with aluminum foil. Place pan in steamer basket. Cover and steam until wooden pick inserted near center comes out clean. Serve warm with **Marshmallow Cream Sauce. Water: 1 cup. Time: 19-22 min.
**Marshmallow Cream Sauce:
16 large marshmallows
1/3 cup cream
In a small saucepan, combine ingredients and melt over low heat. Serve over Steamed Chocolate Pudding.
Feb 23, 2008 | Rival Automatic Steamer/Rice Cooker 4450...
Kenmore Digital Rice Cooker Logo
42 people viewed this question
Top Kenmore Crock Pots & Slow Cookers Experts
tsalagi152
charles
Irene Tulloch
Are you a Kenmore Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
