Question about Whirlpool Duet GHW9150P Front Load Washer
Can h20.. Be drained from the drum thru the bottom or elsewhere?
  • 46 Answers
Yes ! Remove the boot connected to the basket/ drum housing to the water pump. Be prepared for a water mess. Get a wet/ dry vacuum and plenty of towels.
Posted on Feb 08, 2014
My aqualitis aqxxf149pi is displaying h20 error code, filling correctly at start of wash cycle but mid cycle starting to add excessive water before it goes on drain and spin resulting in flooding
H20 is a water warning. The machine THINKS it has no water coming in (Hence it continues to fill and fill because it can''t see the water). 99% of the time, this is a blocked rubber pipe that goes to the pressure sensor. Water in the drum fills the bottom of the rubber pipe and as the water rises, the air pressure in the pipe increases, which operates a bellows device in the pressure sensor. If the pipe is blocked, the pressure sensor won't operate and it will continue to try to fill until it times out. There COULD be a wire off the sensor or a wire that goes to the sensor loose on the main board, there could even be a failed component on the main board, but all of these scenarios are ar less likely than a blocked pressure sensor pipe. Take the lid off, pull the pipe off the bottom of the sensor, blow down it hard and this may well clear the blockage. Put the pipe back on the sensor and test. Come back if you need more advice
Aug 24, 2015 | Hotpoint Washing Machines
Aquarius wmf560 drum not moving after h20 code
if you do not have an instruction manual for this washer then download from this site.
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/WMF560UK_19507120302_UK.pdf
If the drum is not moving then it is very likely the pressure switch is also faulty. This tells the control that water level has been achieved. It is thinking water is not coming in.
Check this out.
PRESSURE SWITCH
Sep 13, 2014 | Washing Machines
What does h20 mean hotpoint wmf 720p
water cannot be detected.. check that the drain hose is not set too low otherwise syphoning will take place...
Aug 03, 2014 | Washing Machines
H20 ERROR SPIN DRYING
The error indicates a problem with the incoming water supply.
Check for restricted or kinked inlet hose/s, check that tap/s are fully turned on and that you have adequate water pressure.
Mar 27, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Towels smell sour. while cleaning noticed small "hole" (factory made) in bottom of boot in front of three "notches". seems like a drain hole? stuck q-tip in there and stinky black muck discovered. ran...
I think you are talking about the door gasket. Use a mixture of bleach and water in the gasket and also in the drum. Most front load washer are notorious for mold and mildew. Run the washer in a rinse cyle to clean drum. Also clean your drain filter.
Jan 06, 2010 | LG WM2688H Front Load Washer
Hello - we have a top loading Maytag Performa washing machine that leaks water during the spin cycle when my wife is washing heavy items that she has placed on center spindal to avoid an unbalanced load....
Maytag Epic is leaking water from the bottom about 8 or 9 inches from the front door back on the right side. Is there and thing i can do. It only about 2 years old or less.
Oct 13, 2009 | Maytag Performa PAV2200
Fan noise clunking with H20 pushed out vent H20 in pan look full. unit 4years old 5k btu
The drain is clogged causing water to back up into the fan blades. Clear the drain and all should be well.
Aug 24, 2009 | Heating & Cooling
Maytag MAH7550AAW problem
first check under or bottom back of the unit to see the drain hose from the tub , then disconnect the hose from the tub and pull the hair , lint ,ect... that you can
if that don't make it drain better the the front will have to come off , but also if the pump motor is getting weak it may need to be replaced
electech
Oct 26, 2008 | Washing Machines
Kenmore portable washing machine won't drain all the way
most common cause is there is a sock or other small item in the inlet hose from the drum to the pump, restricing water flow and the normal time allowed in timer cycle is not enough
open the cabinet as described elsewhere, I am just too laxy to type it at the moment.
examine the short hose from the drum to the pump, and unblock it
Aug 21, 2008 | Kenmore 2.1 cu. ft. Portable Top Load...
Whirlpool Duet GHW9150P Front Load Washer Logo
22 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
