Goldtronic keyboard manual - Audio Players & Recorders
Kensington keyboard manual
Your model number isn't listed, but all published Kensington keyboard manuals are available at
http://www.kensington.com/manuals
My keyboard (model K39336) connected easily, so here's what I had to do. Ensure the Ipad Bluetooth is on in settings. Turn on the keyboard, and when you see a single blue light, press the connect button. The iPad will give you a four digit code to type in on the keyboard. When you type in this code, the iPad and keyboard become 'paired' and keyboard input is available whenever the keyboard is turned on.
Aug 18, 2014 | Kensington KeyFolio Bluetooth Keyboard and...
G81 8308 manual
Hello Pam,
Download the manual for the Cherry 8000 series keyboards from the link below.
www.cherrycorp.com/english/keyboards/pdf/CHE_213636_G81_8000_r1.pdf
Hope it helps.Thanks!
Jan 05, 2012 | Cherry Electrical Cherry G81 8308 Keyboard
I have lost my book of instructions for my Pro Sound Goldtronic Keyboard model number: 9644 do you know where i can get another one fr0m?
i bought 1 used from a surplus toy store in QC last week for P100, been looking around for info on it but to no avail, maybe we can help each other?
Sep 28, 2010 | Audio Players & Recorders
Need to download a keyboard manual
use this link u will get all the info online only no manual needed!
http://www.microsoft.com/hardware/mouseandkeyboard/productdetails.aspx?pid=038
please do rate and reply me ok?
Jul 09, 2010 | Microsoft K5100141 Keyboard
Where can I find users manual for MS Wireless
I found what I wanted by navigating as follows:
Control Panel -> Devices and Printers -> Wireless Comfort Keyboard -> Configure My Keyboard -> Keyboard Properties -> Key settings.
Nov 18, 2009 | Microsoft Wireless Laser Desktop 4000...
Keyboard replacement
Manual can be found here. Parts 1-3 must be downloaded before opening.
Directions from the manual for removing the keyboard:
Removing the Keyboard
(User-Replaceable)
Required Equipment
• #1 Phillips screwdriver.
Removal Procedure
Unplug the AC adapter, if present, and remove the battery.
Remove the keyboard cover (page 2-12).
Remove the four M2.5×4.0 mm screws that secure the keyboard to the top case.
Lift up on the keyboard at the switchboard PCA end and then pull it toward the display assembly to release the tabs from the top case.
Turn the keyboard over and disconnect the motherboard cable.
Remove the keyboard.
Reassembly Notes
Caution
Do not excessively bend or fold the keyboard cable. Excessive flexing can damage the keyboard cable connectors.
• Lay the keyboard face down on the top case, forward of its normal position, then reconnect the keyboard cable.
• Slide the metal tabs on the bottom of the keyboard into their slots in the top case, then lower the keyboard into place.
Apr 01, 2008 | HP Compaq Business Notebook NX9010
MANUAL
I cannnot locate a manual either !!! My keyboard seems to be doing ok but the mouse will not do anything !!!! HELP PLEASE !!!
Thank You ; Derek
Feb 11, 2008 | Innovations kb985w RF Wireless Keyboard
29 people viewed this question
 Grubhead
Grubhead
