Question about Fisher and Paykel Washing Machines
Fischer paykel washer machine not turning on
Where is the reset button on the lid
    Problem Solver:
  • 15 Answers
I reset mine by unplugging it for a few minutes and plugging it back in.
Posted on Jun 06, 2014
SOURCE: Fischer Paykell 7.5kg Smart Drive top load washer
Have you checked the lid micro switch under the motor controller which activates when you close the lid to start the machine?
Posted on Jul 24, 2008
SOURCE: top load washer
1. Remove top. 2. remove left side lock accuator. 3. open accuator case. 4. Solder small broken wire back to diode. 4. reassemble 5. enjoy.
Posted on Oct 11, 2008
SOURCE: service manuals and diagnostic codes with results/reset code
http://www.aars.com.au/F&P%20Service%20manual%20517735.pdf
Posted on Feb 06, 2009
  • 30 Answers
SOURCE: Fisher&Paykel Pride washing machine.Main power
If the drain pump is open circuit the unit will not power up (unlikeley). If the pump is ok you need to replace the motor controll module (likeley) this is the larger of the 2 boards under the top cover and being electronic susceptible to power surges and spikes.
Hope this helps
Posted on Dec 01, 2009
TheMobilian
  • 8220 Answers
SOURCE: F&P washer lights on and beeps
Clogged pump stopped up drain. If the washer does not think all water was pumped out in 8 minutes then it shuts down. Slow drain is my first inclination.
Posted on Dec 31, 2009
I only have a hose attached to the cold water tap and inlet valve of my Fischer & Paykel top loader washing machine as I only do cold washes, this hadn't been a problem until recently, when th
it could be that the water level got to high and came out of the valve you could try putting a cap on the valve and see if that works and if it does not then it might be a bigger issue.
Dec 23, 2012 | Fisher and Paykel GWL11 Top Load Washer
I have a Fischer Paykel Smart Drive 5.5 which is leaking water into the machine when it is switched off. Obviously when I turn off the feeding taps the water stops dripping but how can I stop the leaking...
(pre-typed to cover hot and/or cold!)
This is symptomatic of a malfunctioning (not closing completely) water control valve
With power off, if it is hot AND cold fill, turn one or the other off and see which one is causing the problem. Sorry but it needs replacing and a service call ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Sep 17, 2011 | Fisher and Paykel Fisher & Paykel Washer
Fisher and paykel washing machine GW603 (14 years old) will not power up. When the power is turned on from the power point all the LEDs light up, the machine beeps and then all the LEDs turn off within 1...
What you describe is normal for the power on cycle. If if will not work after this, then you have a problem. If it will not turn on by pressing the power button, try one of the wash type buttons. If it responds to the power button or the wash type buttons and beeps with the start/pause button and the lid is closed, then the lid switch is faulty, if it does not beep and the lid is closed, then the button is faulty and can be replaced on it's own by anyone with some soldering ability.
Aug 19, 2010 | Fisher and Paykel Fisher & Paykel Washer
When the washer is pumping water in it makes a noise like the pump is starving for water. I have checked water flow through the lines and the inlet filters ar not stoped up.
The only thing I've ever had to replace on that model washer is the pump, and they go out all the time. You have to order it from fischer and pakel directly, and it is extremely easy to replace (can do it with no tools at all) Remove the wires from the pump. Ther is a plastic tab that releases it so you can turn it. Turn it 1/4 turn and it will come out. To get a pump call 888-936-7872 (fischer and pakel customer care)
Nov 26, 2009 | Fisher and Paykel GWL11 Top Load Washer
After power outtage my f/p washer is dead -no lights nothing
Only reset is to unplug it. Are you sure you have power at the outlet? If you have 120V at the outlet the power surge may have blown the controller, not a cheap fix :(
Apr 12, 2009 | Fisher and Paykel Fisher & Paykel Washer
Problems with fischer paykel self cleaning oven
Sounds like Clothes Washing Machine To Me!!--Methinks You have "Posted Incorrectly"--Stay Upright --Des.
Dec 15, 2008 | 2006 Fischer MRX 650
Jul 24, 2008 | Fisher Paykel EcoSmart GWL15
Washing Machines Logo
35 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
