Question about Marklin Toys
How to repair a 89006 lok - Marklin Toys
Quik lok stereo vol pedal crackles
spray the controll with cleaner. if it dosen't work replace the controll
Jul 16, 2011 | Quik-Lok Quik Lok VP-26 U Sustain Pedals
The passenger side, front door won't open with the key, remote, buttons inside nor can you force the lock open inside. What should I do
sounds like u have a froze up door lok motor.thats wat they do wen they freeze up/lock up..u need to remove door panel an manually force the lok lever to free it up, in order to open door an replace lok motor. good luck
May 01, 2011 | 2000 Buick Century
Can't get the quick-lok cord to release from sawzall
On my current sawzall I dont't have the quick lok cord, but my last one did and so does my milwakee hammer drill. To remove cord push in on cord firmly where it goes into base of saw. Turn counterclockwise and rotate about 90 degrees. Pull gently on cord base and move slightly from side to side. This should release cord. Reinstall carefully by reversing . Hope this helps you.Thanks.
Nov 16, 2010 | Milwaukee Tool 10 Amp Sawzall Plus with...
I have 6020 nokia mobile, and i inserted the pin code code incorrect more than one time. now he ask me to enter the puk code. what is the puk code and where i can find it??
Bhosdina navra betha phone ma ghoda na marta hov to, ghel choida, chodu madan choksi. phone lok karvo hoi to keyguard ma lok marai, nakar apdi gand ma lok marai... have maravo gand lok vagar.
Oct 22, 2010 | Cell Phones
Motor on my sawzall 6572 runs but blade does not move. Blade locked in tight. No reciprocating motion.
The gears are stripped internally in the saw...it will need to be repaired..
heatman101
Jul 27, 2010 | Milwaukee Tool Milwaukee 10 Amp...
Sar nokia1209 contact sarvice dikharahahe.
Please go to a mobile repairing shop or nokia care and show your mobile, it'll be required to flash (change the operating system). If it's not a hardware or cpu failure, you can get it repaired...
Woh lok ke pass ek hardware hai, use software key saath computer main lagaker banaa dengge..
Good luck..
Thanks for using FixYa.
Jun 22, 2010 | Nokia 1209 Cell Phone
What kind of ATF goes in my 1992 cherokee?
Use ATF+4
Do not use Dexron or Mercon
Aug 08, 2009 | 1992 Jeep Cherokee Sport
Dryer will not start. Says LOK on panel?
LOK means the Child Lock is on. Please see your owner's manual for instructions on setting and removing the child lock.
Jun 09, 2009 | Frigidaire Electric Dryer
1990 Nissan 240 SX clutch repair and head gasket repair needed
if time is not of the essence lok into the local vo-tech schools or community colleges that offer auto repair
Aug 14, 2008 | 1990 Nissan 240SX
Toys Logo
23 people viewed this question
Top Marklin Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Marklin Toy Expert? Answer questions, earn points and help others
