Question about AOC MW0811 Breeze 8Inch Tablet PC Black
How do you remove th battery from aoc tablet - AOC MW0811 Breeze 8Inch Tablet PC Black
Tablet discharging
Probably a faulty motherboard. How old is your tablet?
has it been dropped in water or has water entered it by any means?
Sep 02, 2014 | AOC MW0811 Breeze 8Inch Tablet PC Black
7 inch rca tablet support
What is the model number and brand name of your tablet.
Feb 15, 2014 | Tablets & eReaders
My tablet won't charge.why???please help!!
Is your battery removable? Try removing the battery and then plugging in the tablet. If the tablet runs on only the AC power, then your battery is shot.
Dec 29, 2013 | Dell Latitude XT2 Tablet PC
Unlock a aoc tablet
You will need to do a factory reset:
1. With the device off, press and hold Volume Up and Power.
2. Release the Power button when you see the Samsung logo, but continue to hold Volume Up until the recovery screen appears.
3. Use the Volume buttons to navigate the menu and select wipe data / factory reset. Press Home to choose the selection.
4. Press Volume Up continue.
Oct 30, 2013 | AOC MW0811 Breeze 8Inch Tablet PC Black
My tablet will no longer turn on. The back of it is hot, and there's a burning smell!!
I would suspect that your internal battery may have shorted. If the battery is removable, remove it and try a replacement. If the battery is non-removable you may have to bring the tablet in for service.
Oct 25, 2013 | Irulu 10.1"tft Wifi 3g Android 2.2 Tablet...
How to unlock aoc breeze tablet pattern
i have to many pattern attempts, how I can reset hard , AOC tablet.
Apr 17, 2012 | AOC MW0811 Breeze 8Inch Tablet PC Black
Buenas noches, tengo problema con mi tablet. me sale un mensaje android.process.acore
A mi tambien me salio, no me dejaba entrar a ninguna aplicacion, no lo podia quitar. Tuve que recuperar el sistema operativo para regresar al inicio de fabrica aqui te dice como hacerlo es muy sencillo http://latin.aoc.com/support/troubleshooting.
Te borra las aplicaciones que tengas instaladas pero lo que tienes guardado en tu memoria se mantiene.
No se como evitarlo para, si alguien puede decirme, tks.
Jul 13, 2011 | AOC MW0811 Breeze 8Inch Tablet PC Black
Howto reset cmos on toshiba 3500. I can remove the cmos battery, but have no info on wher any cmos jumper may be. Can't see it on the board.
You can just use a paper clip (straighten to a U shape) and short out the battery contacts.
If you are not sure, just leave the battery out for 20+ mins then put the battery back in the holder.
The BIOS settings will then be set back to th default settings, then go into the BIOS setting and set the Date and Time etc.
Jan 29, 2010 | Toshiba Portege 3500 Tablet PC
AOC MW0811 Breeze 8Inch Tablet PC Black Logo
14 people viewed this question
Top AOC Tablets & eReaders Experts
Are you an AOC Tablet and eReader Expert? Answer questions, earn points and help others
