Question about Refrigerators
Samsung model rf217acrs making noise
Just happened today every time I open the door the noise stops but when I close it the noise persist.
4 Suggested Answers
micromaster
  • 3614 Answers
SOURCE: FREEZER SOUNDS VERY NOISY
Fridge problem could be the fan is bad or that it is hitting ice. When the noise is kind of a buzzing like it is hitting ice...defrost your unit by unplugging and waiting a day or so for full melt out...then check your door gaskets for cleanliness and good seal.
Thanks.
Posted on Mar 08, 2008
heatman101
  • 43501 Answers
SOURCE: my refrigerator makes a noise
Here is a tip that I wrote about refrigerators and the fan noise that they develop sometimes...
Refrigerator Fan Noise
heatman101
Posted on Apr 17, 2011
SOURCE: refrigerator does not defrost and makes ice hit
wrong model number
Posted on Oct 15, 2013
Samsung rf217acrs freezer is not freezing
would check ur freezer thermistors and cold control thermostat as well as air flow damper vent
Lastly check the cold control thermostat with a meter for both OHMS and volts ( VOLTS is a live test with fridge plugged in so be careful) It must show 110 volts. An open or thermostat that reads infinity will not allow the proper cooling and defrosting cycles to operate and may in fact stop anything from happening as if there is no power to the unit?
ALSO CHECK THE AIR FLOW VENT SYSTEM At times it can get stuck to far closed or open. Some units feature a digital electric adjusting vent system while others are manually set. Check for any ice build up or other obstruction in the vent damper, see if u can manually open or close it. Some times when u have the settings set to the highest it closes off one area while allowing to much cold air flow to the other area!
Aug 14, 2014 | Samsung RF217ACRS Stainless Steel 20 Cu....
Why does the refridgerator sounds like a jackhammer?
On some models when you open the door the door switch also turns off the evaporator blower motor. If the fan is hitting something while the door is closed you will hera the noise, and it will stop when you open the door.
Aug 14, 2014 | Samsung Refrigerators
Where is reset button on samsung RF217ACRS
There is no reset button per se on the refrigerator. Since this model doesn't come with a water or air filter there is nothing to reset. If there is a problem with the operation you could just unplug the unit for 60 seconds and then plug it back in.
Mar 02, 2014 | Samsung RF217ACRS Bottom Freezer French...
What would cause an intermittent buzzer noise from a Samsung RF217ACRS refrigerator? It otherwise works fine.
That's the icemaker cycling.Ifya don't have water connected,it's still think'n its filling trays and dumping frozen cubes and all that stuff.Turn off the icemaker.Rigger said that.C-YAAaaaaaaaaaaaa
Aug 28, 2012 | Samsung RF217ACRS - 20 cu. ft. French Door...
Samsung rf217acrs frost in freezer
I have the same samsung with the same problem. I had a repair company come out. What is happening is you are not opening the freezer door correctly and not pulling the tray out all the way. It is a design problem with the door. You must pull it out from the center of the bar and pull it out all the way for it to align correctly and then the door will close correctly. I was getting frost on the right side roller and top area if I don't do it correctly. There is nothing that can be done I am told. You must not pull from the side of the handle. It works fine now. Try this and see if it helps.
Jun 19, 2012 | Samsung RF217ACRS Bottom Freezer French...
We have a Samsung Model number RS2530BBP that the freezer is making a loud buzzing noise. It only stops when you open the freezer door.
It sounds like the solenoid which opens the ice dispenser door or works the cubed/crushed ice part of the ice dispenser is stuck. Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components.
Check you model number as that one doesn't match any. Here are some close matches. http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=RS2530BBP
You can see diagrams of yours if you find it.
Nov 30, 2010 | Samsung Refrigerators
Loud humming noise as fridge is running
Sounds like the freezer fan is rubbing some wires or possible some foam insulation around the fan. I would look into the freezer compartment fan and go from there. The fan Will Shut off when you open the doors. Let me know how you make out and if you need anymore help.
Thanks,
Bill
Apr 27, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
22 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
