Question about Hotpoint Kitchen Ranges
Gas oven won t light - Hotpoint Kitchen Ranges
2 Suggested Answers
Macmarkus
  • 2605 Answers
SOURCE: Gas oven won't light and the broiler won't light
Hello, welcome to FixYa.
I've read your previous post's and can see a couple of scenarios have been thrown out there, so this may just add fuel to the fire...no pun intended.
It sounds to me like a tripped hi-limit safety thermostat is the culprit, hence neither ignitor so much as glows. I'll explain. If the valve where faulty the ignitors woul;d still glow as it is the ignitors which allow the valves to open not the other way around.
Further to that, if the ignitor where faulty, it is unlikely it would be both at the same time, however if a hi-limit safety tripped it shuts down power to both the broil and bake ignitors thus no oven function at all...that is it's function "safety".
The hi-limit safety on your range is on the back wall so you need to slide the oven out (if you haven't done so by now) to inspect it. To do so is pretty easy, one of two ways.
You can jump across it to see if it allows the oven to operate or you can ohm it out with a meter. it should simply be a closed circuit if good, open if not. It is the non-reset type unfortunately so you'll need to replace it.
example
It is part number 8300802 and available at "repairclinic.com" or "searspartsdirect.com" to name just a couple.
Let me know what you find and I'll be glad to help you moving forward from there. Good luck.
Regards,
Macmarkus :)
Posted on May 31, 2011
Hi,My oven won't light but I can smell gas and hear the clicking when I went to light it Kit. Aid model # KGSS907 Thank you. Steve
which one is your model KGSS907SBL00 (30`` Slide-In GAS OVEN CONVECTION)
> KGSS907SBL01 (30`` Freestanding GAS OVEN CONVECTION)
> KGSS907SBL02 (30`` FREESTANDING GAS OVEN CONVECTION)
> KGSS907SBL03 (30`` Freestanding Gas Range with Convection Oven)
> KGSS907SBT00 (30`` Slide-In GAS OVEN CONVECTION)
> KGSS907SBT01 (30`` Freestanding GAS OVEN CONVECTION)
> KGSS907SSS00 (30`` Slide-In GAS OVEN CONVECTION)
> KGSS907SSS01 (30`` Freestanding GAS OVEN CONVECTION)
> KGSS907SSS02 (30`` FREESTANDING GAS OVEN CONVECTION)
> KGSS907SSS03 (30`` Freestanding Gas Range with Convection Oven)
> KGSS907SWH00 (30`` Slide-In GAS OVEN CONVECTION)
> KGSS907SWH01 (30`` Freestanding GAS OVEN CONVECTION)
> KGSS907SWH02 (30`` FREESTANDING GAS OVEN CONVECTION)
> KGSS907SWH03 (30`` Freestanding Gas Range with Convection Oven)
> KGSS907XSP00 (30`` FREESTANDING GAS OVEN CONVECTION)
> KGSS907XSP01 (30`` FREESTANDING GAS RANGE WITH CONVECTION OVEN)
Jan 04, 2013 | KitchenAid KGSS907SSS Gas Kitchen Range
Tappan 32-1272-10/07056-8509-4080 gas range/oven pilot light works,main oven burner won't come on
You will need to look and see if the igniter is glowing a bright red. If it is weak, the oven will not light. Here is the igniter if you need to order it.
Also check and make sure your getting 3.2-3.6 volts AC to the valve.
Dec 01, 2012 | Tappan TGF320 Gas Kitchen Range
Oven won't light
ck thermal coupling see if its to far from pilot light or burnt out
Feb 18, 2012 | General Ovens
We have a Magic Chef gas oven (model # CPL1100BDW) without electronic ignition. The oven isn't working. The oven pilot is out, can't get it to light, and the oven will not light - (obviously)....
Hello & Welcome to FixYa
If the pilot is clean and still won't light then the problem is with the safety valve that won't open and so needs replacement. Please get back to me if you have any other questions.
Kevin
Nov 14, 2011 | Magic Chef Ovens
When i turn on oven all i smell is gas i cleaned with a wire brush still nothing. also is the pilot light always have to be on and can you see it when oven is off
Most gas ovens that aren't electronic ignition usually have a pilot light.
Usually one in the oven area and one for each burner. (Sometimes shared between two burners.)
These pilot lights must lit at all times...otherwise it won't light up and you'll smell gas.
Usually the pilot light is in the very back of the oven and can be seen with the broiler drawer opened.
There is a small set screw located at the pilot light assembly in the oven and also at every burner.
This allows you to adjust pilot light up or down, thereby letting you set pilot light flame to a level that doesn't get blown out by a draft...or you can turn it off completely.
If you use that set screw to turn off the pilot light gas, you'd need to strike a match to light the oven or burners everytime you needed them.
Jul 17, 2011 | Ovens
Glow plug gets red but oven will not ignite. Broiler ignites but has seperate glow plug.
Check to see if you are getting gas to the oven burner. If it will light with a match then look into adjustment of the flow plug, but if it won't light, then look at the gas valve or switch.
Jun 07, 2011 | Ovens
Gas oven won't light. igniter
Hello there i got disconnected pleas reenter the chat
Nov 26, 2009 | Tappan TGF657 Gas Kitchen Range
I have a spectra gas range and the broiler works but the oven doesn't. When I turn the oven on the middle light blinks but oven won't light, what's wrong? Model#348A8035P017
Mar 30, 2009 | GE Kitchen Ranges
Kitchen Ranges Logo
14 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Justin Duby
Justin Duby
Ismael Rodriguez...
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
