Question about Element Electronics Televison & Video
My new element tv will not connect to any of my time warner channels. i don know how to fix this issue.
rulds2008
  • 3866 Answers
SOURCE: Tiling problem with cable card
This is a two sided issue 1. The Tv model you have does not work with there TV card 2. There Tv cards are so outdated its pathetic and do not work for most people on newer TV's that accept the cable card. You can try purchasing your own cable card but would recommend you stay with the cable box for now!
Thanks and please do rate your solution positivly
Posted on Nov 19, 2009
  • 8457 Answers
SOURCE: My girlfriend has a toshiba
After u deleted all the HD channels u don't want.Tries unplug,replug the cable box back like about an hour.For the box to upgrade it softwares,should be deleted all the HD channels u deleted.
Posted on Feb 06, 2011
SOURCE: I have no picture or
no sound
Posted on Apr 10, 2011
  • 8457 Answers
SOURCE: I have the same issue
That tv HDMI hub output for the HD tv signal are could be a bad HDMI cable should tries it with another new HDMI cable.If still have the same problems tries it with another HDMI tv hub hook up.That tv HDMI tv hub the one u using now might have a intermittent shorting like lose or dries solders joints that why sound come an goes.
Posted on Aug 25, 2011
gopakumarg43
  • 74459 Answers
SOURCE: can't get a signal
Contact the service provider.
Posted on Aug 12, 2012
Green squares on LG tv
Is this or does this happen to all channels. First check the connection on the back of you TV is it tight and secure. Second You may also need a new decoder from warner cable to view. (Channels are scrambled) and third look for TV repairman.
Jun 01, 2013 | Televison & Video
Hi, I bought this tv at thrift shop last week. No instruction manual available. I got cable from Time Warner. Got the cable signal and got tv working. 3 days later no cable. I don't know how to...
If using a cable box then you want to set the TV to channel 3 or 4 as the cable box will output to one of those. If no cable box then its possible the TV's tuner is bad or your cable company only transmits in digital form requiring a cable box since this TV only has an analog tuner
Jul 19, 2011 | GE 13GP341 13" TV
Just bought a new Panasonic TC-L42U22, connected it to a samsung time warner HD cable box via HDMI, but the cable remote is not working. There's picture and sound, but can't turn it on or off, change the...
You have to program the remote to work with your specific model tv. If it still doesnt work after that call your cable provider and ask them for another remote.
Mar 24, 2011 | Panasonic TCL42U22 42 in. TV
My girlfriend has a toshiba 32rv530u TV. when she first connected it to her time warner cable everything worked fine. since then time warner has added free hd channels for the local commercial stations...
Feb 06, 2011 | Toshiba REGZA 32RV530U LCD TV
I have Time Warner cable. I have a Symphonic SR90VE vcr/dvd that I have hooked up to the main TV. The cable box services a second tv in another room. I can't seem to get the main tv and the vcr/dvd player...
Cable goes to vcr cable INPUT, then run cables from vcr OUPUT to tv INPUT or AV.
Then put tv on input or av channel or channel 4 and use put the vcr on the channel you want to record.
Apr 19, 2010 | Televison & Video
I was given this tv I need to connect cable
your t.v will hook up directly to cable. if you are asking how to hook to a digital box then you can hook it up the same as you had it hooked on your previous t.v. but if you want to get high def channels then you are going to have to take your digital box back to Time Warner and swap it for a high def digital box. or you can just call Time Warner and have a technician go to your house and swap/ hook things up for you. Hope this helps you.
Feb 02, 2009 | iLO 3200 32 in. LCD Television
I have Time Warner cable. I just bought a new Sony LCD HD tv and the sound and the video are out of sync on some channels - HD and non HD I am using a HDMI cable. Any solutions that you know of?
Yes there is a simple solution. First, for some reason., Time Warner cable boxes have SERIOUS HDMI issues, including no pic, intermittent pic and sound and the one that you are having. The easy fix is to hook the TV to the cable box using the component connections instead of the HDMI. Normally I would suggest getting the cable box replaced, but I have seen customers exchange cable boxes 3 or 4 times and still have the problem or have a new problem. Use the component connections and be sure to let me know if this works. If it does, be sure to rate this solution. Thanks!
Nov 09, 2008 | Televison & Video
Picture in picture problem
When you use the Time Warner Digital box, you're using the tuner inside that box rather than the tuner inside your TV to select a channel. Picture in picture TV's have two tuner's inside so you can view two channels, but they can only tune the analog channels from your cable company, and only if it's hooked up in a manner that will permit this to happen.
So you only have one digital tuner (the Time Warner Box) so you can only view one channel at a time even though your TV supports Picture in Picture.
It MAY be possible to have limited use of the PIP if you connect your TV in a different way. Your Time Warner box is most likely connected to your TV set with composite cables, those are the Yellow, Red, White cables. If you buy a coaxial cable splitter and split the cable before it goes into the Time Warner box you can then run a coax cable into both the Time Warner box and the coax input on your TV. This would allow you to tune the analog Time Warner channels with both of your TV's tuners. In my area I think the first 60 channels or so are still available in analog, but there is no way to watch any of the higher premium channels without the Time Warner box.
If you go through these steps and you select the coax input on your TV your PIP will work on the lower channels. It MAY be possible to tell your TV to display the input from the composite cables on one of the PIP screens and the input from the coax on the other, but I kind of doubt it.
I know this sounds complicated and if you're not familiar with the way all this works it is complicated. The reason lots of people won't respond to this kind of question on this site is because there is no easy fix and by trying to help I run the risk of getting a bad rating. I don't get paid for this, I just like trying to help, so if I have not explained this in a way that's helpful to you please ask some additional questions before you give me a bad rating. Thanks.
Jan 01, 2008 | Panasonic CT-32D31 32" TV
Televison & Video Logo
19 people viewed this question
Top Element Electronics Televison & Video Experts
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
