Variable calculator -7x-7=6x+19
  • 7,993 Answers
-7x-7=6x+19
  1. Add +7 to both sides: -7x-7+7= 6x+ 19+7
  2. Combine like terms -7x=6x+2626
  3. Subtract 6x from both sides -7x -6x=6x+26-6x
  4. Combine like terms -13x=26
  5. Divide both sides by -13: (-13x)/(-13)=26/(-13)
  6. Simplify to get 1x=-2
Solution is x=-2
Posted on Feb 08, 2014
  • k24674 Feb 08, 2014
    OOPS Combine like terms -7x=6x+26
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Office Equip... Master
  • 102,366 Answers
X=-2
If you're asking how to do this on a particular calculator, please specify the make and mode. If this is homework, be sure to show your work.
Y=x^2-7x+4, y=-8x^2+56x-86
Since the y-variable is isolated in both equations, set the two right sides of the equations equal
x^2-7x+4=-8x^2+56x-86
Combine all like terms on one side of the equal sign
9x^2-63x+90=0. factor out the 9 to get 9(x^2-7x+10)=0
Now solve the equation (x^2-7x+10)=0. The solutions are x=5 and x=2
Calculate the y-value tof be y=-6
The two solutions are (2,-6) and (5,-6)
Graphically, here is how the two curves intersect. One intersection point in the screen capture is (2,-6). You can read that the other intersection point is (5,-6)
Mar 03, 2014 | Office Equipment & Supplies
Equations
You can't simply enter 7x+9=30 into the calculator, there is a way to calculate what the x is but its been a few years since I've done these..
Oct 03, 2008 | Texas Instruments TI-83 Plus Calculator
Invalid implied multiply
An implied multiplication happens when you put two names of variables one after the other without actually entering the multiplication sign (* or cross). The calculator is interpreting this as a multiplication and is telling you it is wrong to do so. I suspect this can happen if you use a variable name made up of two or more letters without first defining the variable. If you use a variable called ax or xa without defining it before it is called, the calculator interprets that as variable a times variable x.
Oct 20, 2013 | Texas Instruments TI-89 Calculator
Reset
You referenced a variable that is not currently defined. For example, you referenced a stat variable when there is no current calculation because a list has been edited, or you referenced a variable when the variable is not valid for the current calculation, such as a after Med-Med.
Jun 06, 2013 | Texas Instruments TI-83 Plus Calculator
Variable equation
3 times integer(x/20)
where integer(x) is the integer portion of x, discarding any fractional portion.
May 05, 2013 | Office Equipment & Supplies
How can you distribute (x+7)(x-7) on texas instrument calculator?
Well, you can't directly distribute it on the TI-84 because the calculator plugs in a number for x. If you know how to distribute it in long hand though, you can just use the calculator for any math you need help with. Or you could plug in the number you want for x by pressing that number, sto>, x. You can do problems like that long hand in the following way. If you were given (x+a)(x-b) you first do x(x-b) and get x^2 -bx, then a(x-b) and get ax-ab, then add those two answers together, giving you x^2-bx+ax-ab and then x^2+(a-b)x-ab. So your problem for example would distribute to (spoiler warning) x^2 -7x+7x-49 and then x^2 - 49 because the - and + sevens cancel. I hope this has, helped, just let me know if you need anything further.
May 09, 2011 | Texas Instruments TI-84 Plus Calculator
How do you find the point intersection of ln x=-7x
Graph both lnx and -7x and then go to the graph. Once there, press 2nd then calc and scroll down to where it says "Intersect", select that, select a point on each line, and press enter and it should give you the intersection point.
Mar 25, 2011 | Texas Instruments TI-84 Plus Silver...
Removing zeroes?
You're right in that the calculator thinks you have 19 data points. You need to delete the nine unwanted rows. After pressing EDIT, press NXT to bring up the second set of editing functions. Scroll down to each unwanted row and press B for -ROW to delete it.
Or else simply delete the Sigma-DAT variable in the current directory and start over.
Jun 30, 2010 | HP 50g Graphic Calculator
Variables
This calculator cannot handle symbolic algebra.
Use the rules to simplify the expressions: Get rid of the parentheses using distributivity od multiplication with respect to addition; group similar terms (terms with x, terms without x).
Hope it helps.
May 07, 2008 | Casio FX-115ES Scientific Calculator
79 people viewed this question
jasbo
jasbo
