Question about Caterpillar Cat Forklift Ignition Switch Parts 66 Caterpillar
Hi...I have a cat p5000 lift that lost all ignition lights today. lights and horn working. Dash completly blank.
No power to radio whatsoever.
mail me at tcifusion a yahoo.com to answer all ur problems jf u want.......u dot have to worry.allsolvable problems
Apr 14, 2014 | 2001 Volkswagen Passat
1987 toyota pickup lost all electrical except headlights
What works? Just headlights? Does anything electrical work that does not need the ignition switch to be in the on position? Possibly four way flashers, brake lights, horn, interior light, dash lights in instrument panel as well as headlights should all work without the key in the ignition and in the acc or on position. If this is what you have, then I would say you need to replace the ignition switch.
Hope this helps.
Jan 12, 2014 | 1987 Toyota Pickup
While driving my 2000 cavalier the car completely shut off. when i put the key in and try to start it. it is as if the key is still in my pocket, absolutely nothing happens. the dome light, horn,...
It could be almost anything - immobiliser, engine management, broken wire somewhere, a relay...
No sign of life from the dash probably indicates it isn't the immobiliser but take nothing for granted. The problem should be approached diagnostically rather than throwing parts at the car. A wiring diagram and a test lamp or voltmeter to follow the circuitry until the fault is found.
Apr 25, 2017 | 2000 Chevrolet Cavalier
Remove ignition switch for a 2004 kia optima
Ignition Switch Removal & Installation To Remove:
  1. Disconnect battery negative cable.
  2. Disarm air bag system.
  3. Remove driver air bag module.
  4. Loosen screw and lift horn pad to remove.
  5. Remove lock nut and washer. CAUTION
    Do not hammer on steering wheel. Damage can occur to the energy absorbing portion of the steering column.
  6. Pull dynamic damper forward and lift up to remove.
  7. Remove steering wheel.
  8. Remove steering column shrouds.
  9. Remove lower cover.
  10. Remove multifunction switch.
  11. Remove entire lower portion of dash.
  12. Remove mounting fasteners and lower steering column.
  13. Remove bolts and separate ignition switch from steering column.
To Install:
  1. Install ignition switch to steering column and install bolts.
  2. Raise steering column and install mounting fasteners.
  3. Install lower portion of dash.
  4. Install multifunction switch.
  5. Install lower cover.
  6. Install steering column shrouds.
  7. Install steering wheel.
  8. Install dynamic damper.
  9. Install washer and lock nut.
  10. Lift horn pad and install screw.
  11. Install driver air bag module.
  12. Connect battery negative cable.
Jul 17, 2010 | 2004 Kia Optima
Recently I lost my wipers, horn and head light control. All fuses and relays are good. The head lights come on with ignition and go off when ignition is off, but no brights or control otherwise. Turn
Much easier to replace the switch assembly. If it is something minor repair it but do not open the switch assembly packaging so that you can return it.
Jun 24, 2017 | Dodge Ram 1500 Cars & Trucks
Keyless entry not working
Try re-programming the remotes, here is the procedure for your car.
JAGUAR
XJ8 Remote Control Programming
1. Unlock the trunk with key.
2. Turn Ignition on.
3. Warning light on dash comes on.
4. When they go out, lift arm rest, inside their is a valley button, Press 5 times within 5 secs of lights on dash going out, Horn & Lights Flash.
5. Press any button on remote, remote programmed
Dec 11, 2008 | 2006 Jaguar XJ8
Caterpillar Cat Forklift Ignition Switch Parts 66 Caterpillar Logo
Top Caterpillar Toys Experts
fordexpert
Ted Maxwell
Are you a Caterpillar Toy Expert? Answer questions, earn points and help others
