Question about Mantis 2-Cycle Tiller
I Have a Mantis tiller that I can get NO spark
I have intalled a new coil and new spark plug. I have also disconnected the kill switch wire. I have also sanded the flywheel off.
    Problem Solver:
  • 11 Answers
Set the coil to the thickness of a dollar bill from the flywheel and tell me what happens. make sure kill wire isn't grounding somewhere else
Posted on Aug 04, 2009
SOURCE:
Tiller suddenly stopped. no spark. replaced spark plug, contacts, condenser, coil, kill switch wiring. still no spark. replaced contacts and condenser with solid state electronic unit (Nova II) still...
points? unhook the coil and see if it has spark then. if it does there is a short in wiring to frame somewhere. is there resistance on the pull rope? it is possible it may have broken a connecting rod.
Nov 17, 2017 | Troy-Bilt Garden
Mantis tiller
is the kill switch off does it fire? have spark? start with the basics .air , fuel, and spark. hope this helps
Jul 06, 2014 | Garden
My mantis tiller 2cycle: Iput new spark plug the on&off switch ok just not getting a spark to the plug. Think its the coil ?
I would say it is the coil, if you have a multimeter you can connect it to the coil and try to start it to see if it producing voltage. Hope this helps Tim
Apr 16, 2011 | Mantis Gas Mini Tiller/Cultivator, 2 -...
Mantis tiller, no spark, kill switch ok. 2 cycle gas has no model or serial numbers. Has voltage pulse from crankshaft end area to coil input, what should this be? What should coil resistance be? any...
unplug the shut off switch and then see if it sparks. also put a different spark plug in to see if its that. if either doesn't fix then coil is probably bad.
Feb 23, 2011 | Garden
Won't start, no spark--
un plug kill wire
or try spark tester on coil wire
Sep 01, 2009 | Mantis Tiller
Item: Mantis Tiller Problem: wire to kill switch came loose from where it attaches under the cowling covering the engine. Question: where does it attach, I need to reconnect it
Hello:
The Shut Off Wire is Attached to the Ign Coil.
There is a Spade Lug on the Coil that the Wire Attaches to.
Hope this Helps.
Good Luck
Respectfully
John
May 10, 2009 | Mantis 2-Cycle Tiller
Mantis tiller sv-4 echo engine: no spark from coil
There are only 4 parts to the 2-stroke Mantis ignition system: the spark plug, the "kill button", the flywheel with embedded magnets, and the coil with integral plug wire. There are no "points" to clean or refurbish. If you've tried a new spark plug, unplugged the wire leading up the handlebars, and the magnets on the side of the flywheel are strong enough to attract a screw driver blade, then it must be a bad coil. That's all it could be. End of story.
Cruising the internet I see where these Echo coils go bad all the time. You can order the coil, but if the machine hasn't run in several years the carb will also need cleaning. So one thing leads to another. The gear box grease also needs replacing each year. What I'm trying to tell you is these are disposable tillers and due to length of time, incomplete care/ storage, ....whatever, this one's time is up.
Sorry.
Feb 26, 2009 | Mantis 2-Cycle Tiller
Mantis 2-Cycle Tiller Logo
1,631 people viewed this question
Top Mantis Garden Experts
ray gallant
ray gallant
mpservices
roeb
Are you a Mantis Garden Expert? Answer questions, earn points and help others
