Question about Stihl Br500 Br550 Br600 Flywheel 42824001200
STIHL CHOKE SHAFT FIT BR600 - Stihl Br500 Br550 Br600 Flywheel 42824001200
2 Suggested Answers
brimax7576
  • 344 Answers
SOURCE: Hard to crank when cold a br600 stihl
With these big boys, stihl has a decompression valve on the side of the manifold so it's easier to pull start. What you wanna do is spray some gum out into the plug hole then reinstall the plug, squirts some in the carb as well... If your unit starts up and runs for a few seconds and cuts out, your carburetor is done.
Basically it's like this, you can adjust the carburetor by the two needles on the carb. The H and the L... the low you adjust at flat idle and the high you adjust by keeping the throttle ppen
Posted on Oct 07, 2015
Where will i find the serial number on my stihl br600-z blower
On backpack blowers, it is on the bar code label and stamped in the top of the cylinder or main crank case. All current serial numbers will be nine digits long and begin with the number 2, 3, 5 or 9.
Source: Frequently Asked Questions about STIHL Blowers STIHL USA
Aug 15, 2017 | Stihl Garden
Just tried to fit new stihl br600 throttle cable, but seems to be a good 1/2 inch to short.
heres a workshop manual that might help
http://stihl.partsmartweb.com/Catdata%2FEMP_IMG%2FSTGSTH%2Fimages%2FSERVICE%5C00589565.PDF
Jun 29, 2017 | Stihl Garden
BP600. How do I adjust valves?
I'm assuming you mean the Stihl BR600, i've added a copy of the breakdown. http://www.mediafire.com/download/56zr9s967sf9a98
you need to access the top of the valves, they should both have an 8mm nit on them. this is the adjustment nut. you get to top dead centre, turn the flywheel by hand until the arrow on the outer of the face lines up with the top ignition module *****. Stihl tools have a feeler gauge you can buy to set them correctly, as normal feeler gauges are too wide to fit under the rocker arms correctly.
Oct 31, 2015 | Garden
How do I replace a fuel primer build on the Stihl BR600 blower/
Disconnect the spark plug wire from the spark plug and ensure it can't come in contact with the spark plug. Removal of the spark plug wire removes any possibility that power can be supplied to the engine of the blower during the repair.
Remove the screws that hold the air filter cover in place. Remove the air filter cover and air filter. Remove the air filter housing from the side of the machine. Removal of these components allows you access to the primer bulb, fuel line and carburetor.
Repair Procedures for Stihl BR600 Backpack Blower Primer
Nov 03, 2014 | Stihl BR600
Stihl manuals free download
nope, nope, and nope. Stihl offers nothing for free and their manuals are all online and you have to have dealer credentials to access them
Aug 30, 2014 | Stihl Magnum Br600 Professional Backpack...
I need stihl BR600-Z parts diagram
had same model, I took my hose (piece) and old broke clamp to ACE and got everything to fix...Even put a new fuel filter hose into gas tank for $ 15.00 less than ordering from factory.
Jul 18, 2014 | Stihl Garden
Gas cap leaks
the seal is missing youve dropped it in a garden somewhere
you need a new one
try ebay
but i will tell you stihl is VERY good at service parts
and very helpfull
http://www.ebay.co.uk/itm/PETROL-FUEL-TANK-CAP-FITS-STIHL-BR500-BR550-BR600-BLOWER-/141346840553?pt=UK_Home_Garden_GardenPowerTools_CA&hash=item20e8ed9fe9
Feb 19, 2014 | Stihl Br500 Br550 Br600 Back Pack Blower...
Backpack blower runs on choke only
replace fuel filter
air filter
spark plug
and clean the carborator jets etc...
change/change out the oil and measure the amount you put in
by the manual info look on the sthil site for the manual
Nov 13, 2013 | Stihl Magnum Br600 Professional Backpack...
How to set the timing on sthil blower br600
you can only adjust the coil to flywheel gap... timing for the flywheel is preset and un-aqdjustable
Aug 31, 2013 | Stihl Magnum Br600 Professional Backpack...
Stihl Br500 Br550 Br600 Flywheel 42824001200 Logo
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
