Question about HP LaserJet M1522nf Multifunction Printer (CC372A)
My hp laserjet m1522nf wont scan through the document feeder
The scanner will make noise and the wheel rolls but wont push the paper through
SOURCE: HP LaserJet 3055 Won't Scan
Dears
My hp 3055 is working fine on the network bt problem is "SCAN TO" Button is not being configured with the PCs.It displays all the PC names bt not able to scan. it diplays an error "Unable to Connect".
can any body help me out of this matter
Posted on Jan 13, 2008
SOURCE: HP LaserJet 2840 Scanner problem
Yes, but I don't see any actual paper jams. I have a Vista O/S and I've been reading that that might be the problem; the 2840 scanner driver is not compatible with the Vista O/S and HP hasn't produced a solution yet. I appreciate your efforts, thanks.
Posted on Feb 10, 2008
  • 1894 Answers
SOURCE: Problem with scanning both from the auto feeder and from scanner glass
this is what HP has to say
This document applies to all HP product models. Issue When the product is turned on or in the middle of an operation, an unexpected noise occurs, such as clicking, thumping, or grinding. Blinking lights and error codes might accompany the noise. NOTE: Noises can be caused by a number of things. This document focuses on isolating, identifying, and resolving known causes of product noises. Solution Noises are subjective and can be difficult to describe. Some noises are normal to the operation of the product and might include the following:
  • The product might make humming and buzzing sounds as the carriage moves around on the right or left side of the product while cleaning the ink cartridges. This is normal when a product is turned on, before and after printing, after a product has been on standby for some time, after replacing an ink cartridge, or in the middle of a large print job.
  • During a print job, the movement of rollers, gears, carriage, and paper (paper feed and ejection) creates some noise.
  • During a print job, if the product is printing in the fast or draft mode, the noise level might be higher than when using the best or normal mode.
  • At the end of the print job, a louder clicking noise occurs as the paper is pushed to the output tray.
  • At the end of a print job, a noise emanates from the left or right side of the product as the pens are capped. The product might try to do this a couple of times.
Abnormal noises are a symptom of a problem. The most accurate way to determine the origin of a noise is to isolate where it comes from and when it occurs. Use the following steps to try to isolate the noise issue. NOTE: Error codes might indicate the source of the noise. Make a note of any error code or blinking lights that appear. Step one: Check for loose or broken parts
  1. Raise the cover of the product.
  1. Check inside for loose or broken parts.
  2. If there are broken parts, the product needs to be serviced.
  3. Step two: Make sure that accessories are installed correctly
  1. Press the power button (c00636182.gif ) to turn off the product.
  2. Remove the power cord from the back of the product and unplug the power cord from the power source.
  3. Check any accessories (duplexer, envelope feeder, automatic document feeder (ADF)) to make sure each is installed and seated correctly.
  4. Plug the power cord into the back of the product and plug the power cord back into the power source.
  5. Press the power button (c00636182.gif ) to turn on the product.
  6. If the noise still persists, remove each accessory one at a time to try to determine if the noise is associated with a single accessory or a combination.
  7. If the noise stops when a specific accessory is removed, that part might need to be replaced. If possible, exchange the accessory with a known good one or a new one to determine if the noise is associated with the accessory. NOTE: If the product is fully functional with the accessory in place, the noise might be normal.
  8. If the noise persists, proceed to the next step.
Step three: Check connection with computer Turn off the computer to determine if the computer is the source of the noise. If the noise persists, proceed to Step four. If the noise stops when the computer is turned off, try to isolate any issues with connectivity:
  2. Disconnect the USB cable from the product.
  3. Unplug the power cord from the wall outlet and from the back of the product.
  4. Wait a couple of minutes to allow static to be discharged.
  5. Plug the power cord into the wall outlet and plug the power cord into the back of the product.
  6. Connect the product to a different USB port.
  7. Turn on the computer.
  8. Press the power button (c00636182.gif ) to turn on the product.
  9. If the noise persists, service the product.
Step four: Check for a paper jam Paper jams can prevent the internal components of the product from moving, which can create unusual noises.
  2. Disconnect the power cord from the back of the product.
  3. Remove the rear access door.
  4. Remove any paper that is inside the product by pulling it out through the rear access door and then securely replace the rear access door.
    1. If a paper jam cannot be removed from the back of the product, raise the product cover, carefully remove the paper jam from the front of the product, and then lower the cover.
    NOTE: Remove any paper jam carefully as it is possible to damage the product when removing a jam from the front of the product.
    1. Reconnect the power cord to the back of the product.
    2. Reload the paper in the paper tray.
    3. Press the power button (c00636182.gif ) to turn on the product.
    4. Try to print. If a jam is cleared and the product prints, but the noise persists, proceed to the next step.
    5. Step five: Make sure that the carriage moves freely
    2. Disconnect the power cord from the product.
    1. Make sure that the ink cartridges are locked into the carriage and have not come loose. Also make sure that there are no obstructions under or around the carriage to prevent it from moving.
    2. Close the product cover and reconnect the power cord.
    4. If the noise persists, proceed to the next step.
    5. Step six: Plug the product into a wall outlet
    If the product is plugged into an uninterruptible power supply, that source might make a beeping or whistling noise.
    1. Unplug the power cord from any power strips or surge protectors.
    2. Plug the power cord directly into a wall outlet instead.
    3. Press the power button (c00636182.gif ) to turn on the product. If the noise persists, proceed to the next step. If the noise stops when plugged directly into a wall outlet, the power strip or surge protector might not be allowing sufficient voltage to reach the product and might need to be replaced.
    Step eight: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product.
    Comments by scrodamoon in premium
    Posted on Aug 05, 2008
    • 88 Answers
    SOURCE: documnet feeder jam
    Check input paper feeder at top too - easy to miss. Top flips open with a firm (but not excessive) pull, so you can look there.
    If you are sure you've opened and looked under every available panel on the printer (there are many!), turn it off and unplug for half a minute. Make sure all panels are back properly in place, but leave out the paper tray (and no paper either in the rear input paper feeder).
    Plug in and turn on. Wait for it to finish its start-up sequence - it should complain about no paper.
    Check the paper is flat and straight in the paper tray, and no excess room between paper and guides, and put it in again.
    Print test page.
    How is it now?
    Posted on Sep 15, 2009
    • 31 Answers
    SOURCE: How do I scan a document on a HP Laserjet m1522nf...
    install full software, download from www.hp.com
    Posted on Aug 10, 2010
    I've got a all-in-one printer of HP LaserJet M1120 MFP. When I switch it on the screen shows "Scanner Error 20". And I cannot use the scan function. It can print when connected to computer. I've rea
    Follow these steps to scan using HP software:Step one: Load the item to be scanned
    1. Make sure that the product is connected to the computer.
    2. Turn on the product.
    3. Load the item in the document feeder tray or on the scanner glass
    Tip
    Load the following items in the document feeder tray :
    • Single items
    • Items that are not easily damaged
    • Multipage, single sided items that you want to scan into one file
    Load the following items on the scanner glass :
    • Single items
    • Items that are easily damaged, such as old documents and photos
    • Multipage, double sided items that you want to scan into one file
    • Option one: Document feeder tray
      1. Place the item into the document feeder tray. The printed side faces up and the top edge goes into the tray first.
      2. Adjust the width guides to fit the item.
    • Option two: Scanner glass
      1. Open the scanner lid.
      2. Place the item with the print side down on the scanner glass. For the correct position, see the engraved guide near the corner of the glass.
      3. Close the scanner lid.
    Step two: Scan the item Use one of the following methods to open the HP scan window:
    • Double-click the HP scan icon (c02436443.gif ) on the Windows desktop. note.png NOTE:If you have more than one HP product installed, double-click the HP scan icon (c02436443.gif ) for the product you are scanning with.
    • Click Start (c01827528.gif ), click All Programs , click the HP folder, click the name of your HP product, and then click HP Scan .
    Click the scan option for the item you are scanning. note.png NOTE:Depending on your HP product, you might not have all the following scan options available. c02448891.gif
    Save as PDF Use this setting to scan text documents that are not editable. Use the Save as Editable Text (OCR) option to scan text that you can edit. c02448892.gif
    Save as JPEG Use this setting to scan pictures and images.
    Hope this information will be helpful.
    Let me know.
    Regard
    Oct 29, 2011 | HP LaserJet M1120 MFP All-In-One Printer
    Doc feeder jam error on HP laserjet M1522nf continuesly also due to that i am unable to scan and also its showing that "Device is busy try again later"
    Open adf cover, remove adf pick up unit, two sensor located in it 1. paper leading edge sensor, located upper portion of the unit.2. paper out sensor located back side of the adf pick up unit. Carefully open this unit your will easily find out the sensor location..
    Sep 13, 2011 | HP LaserJet M1522nf Multifunction Printer...
    Two black lines down the side of the paper when fed from the top feeder.
    Most likely dirt on the glass for the ADF scanner, but try making a copy from the glass first by lifting the lid and placing the document directly on the scanner. If that is clear, then it is definitely dirt on ADF glass. The ADF glass is the smaller piece of glass you see when you lift the lid. Use window cleaner and a soft cloth to make sure that you have all traces of dirt, liquid paper, post it note glue. Look at the glass from very carefully because even the slightest bit of goop can cause scan defects.
    May 04, 2011 | HP LaserJet M1522nf Multifunction Printer...
    Hi i just cant fix my problem with scanner i got HP Color LaserJet 2820 and if i want to scan it says not set up on pc but its there. Pls tell me step by step how to solve this i use printer through...
    The quick and easy solution here is not to scan from the front panel of the unit.
    Use the HP Solution Center from the PC to initiate the scan and it should work perfectly.
    In other words, put the document(s) in the scanner or document feeder, then go to the computer, launch the HP Solution Center, and use the scan function there.
    It's actually more versatile anyway and gives more scan options with regards to quality, file type etc.
    The Scan-To-PC function from the front panel can be tricky to set up at the best of times.
    If you absolutely must be able to scan from the front panel, I suggest paying for a chat session or phonecall, because there's going to be a lot of back and forth discussion to get it set up right.
    Apr 27, 2011 | HP LaserJet M1522nf Multifunction Printer...
    Not scanning or copying when using the ADF on HP laserjet 3055
    Based on the assumption it's mechanically ok, check the cable connection between the document feeder and the base, if damaged or worked look it can cause errors. If it is a sensor error, check for a small bit of paper or even a staple from a prior jam.
    Jun 18, 2009 | HP LaserJet 3055 All-In-One Printer
    Feeding photos into scanner
    try different position and push down into feeder.
    Feb 09, 2009 | HP LaserJet 3050 All-In-One Printer
    Have you looked to see if there is any paper at all in the trays. That are getting hung up.?? I can help
    Feb 10, 2008 | HP LaserJet 2840 Printer
    HP LaserJet M1522nf Multifunction Printer (CC372A) Logo
    16 people viewed this question
    Seeker5211
    Seeker5211
