Question about Campbell Hausfeld Air Tools & Compressors
Wireing for a century motor
I need to see a wiring diagram for a 115v/230v century motor part# 8-135888-02 connection dirgram 115242
2 Suggested Answers
  • 1388 Answers
SOURCE: rewiring mootor from 230v down to 115v
Diagram for aosmith motor b381 is here: http://www.electricmotorwarehouse.com/IMAGES/B381_connection.htm
However, I believe that this motor will be more efficient at 230v depending on load conditions. At 115v this motor will draw more amps and tend to run hot, but situation rules. Enjoy
Posted on Dec 14, 2008
How do I wire up a A.O. Smith 3/4hp PB4 Booster Pump for 230V operation?
Here's some more info diagrams for you http://www.electricmotorwarehouse.com/aosmith/AO_CONNECT.PDF L1 is one hot wire L2 is the other hot wire. L1 can not be connected to a L2 wire and L2 can not be connected to a L1. Ground only to ground.
May 27, 2014 | AO Smith 1.5 hp Swimming Pool - Jet / Well...
How to wire the 115v/230v magnetek pool pump motor (1.5 Hp wth sq flange, 56Y) for 115V ?
if you are not a motor service person do not try this your self get the right help be safe
Sep 23, 2013 | AO Smith 1.5hp 1800RPM 56 Frame Farm Duty...
Changeing 115volt to 230 volt
Most power Flo pumps run above ground pools and run on 115v only.You can look at the wiring diagram on the motor label to see if it is convertible, it will show wiring configurations and amps for both 115v and 230v. If not, it is a 115v motor only.
Sep 11, 2013 | Hayward Power Flo Lx 1 Hp Pool Pump Sp1580
Wiring diagram 3/4 hp boat lift motor
It will be dependent upon the line voltage and switching mechanism...
Please advise drum switch or relays?
115V or 230V
Remote control present?
If a drum switch, is it a 6 or 12 terminal model or some other configuration?
Make and model of the switch?
There may be more questions depending on the answers to these...do you have a wiring diagram for the control? Are you replacing a motor and have the old and new motor schematics?
John
Apr 10, 2011 | AO Smith A O Smith Motors Century 1hp 115v...
I just bought a AOSmith 1hp pool pump. I do not
Well first did you have an old one you're replacing? Check it. Second you could test your voltage with a tester (best idea then you know for sure). Third, you can look at the circuit breaker in your panel, and if it is a single breaker , it is 125V If it's a double pole breaker (two wide with wide handle) then it's 230V. Usually if it is 230V then the wires coming to it would both be black, or black and red, with a bare or green ground. Usually if it's 115V you'll have one black (hot), one white (neutral) and one bare or green(ground) but at times someone will wire one 230 with black and white. There should also be a large bonding copper jumper connected to a lug on the outside of the motor to bond your system to the pool (NOT AN EQUIPMENT GROUND)
Jul 05, 2010 | AO Smith A O Smith Motors Century 1hp 115v...
Just installed a new pump. After one minute of operation it shuts down. Why?
The pump is capable of 115V or 230V operation.
Most likely what is causing your pump to shut down is the thermal overload.
Possible causes of thermal overload:
1. 230 V winding powered by 115V
2. 115V winding powered by 230V
Recheck your connections per the diagram either in the owners manual OR on the label of the motor.
When a NEW pump has issues almost every time the problem is in the connecting wiring either from the main power supply or on the motor terminal lugs.
Just look closely at the wires.. IF your absolutely sure that it is connected correctly. Go to the main power panel.. Push the CB for the pump to OFF hard and then back to on. (This resets the breakers) If it repeats... the symptoms... I need to know what wires you have connected up on the motor to what terminals by LABEL of each terminal.
Kelly
Jun 29, 2010 | Polaris Pb4 - 60 Booster Pump
Change wiring from 230v to 115v
There should be a wiring diagram on the name plate of the motor, or inside the wiring compartment or on that cover . Would be something with dots and HI , LO, and wire numbers.. or just a notation of 120 , 220 volts.
How is it wired now?
May 10, 2010 | Flotec 1 - 1/2 Sprinkler Pump Composite...
My motor is wired for 230v and I need it to be 115v
It should be. Look closely at the motor nameplate and you should see a small diagram telling how to connect the motor for 115v or 230v. Most newer pumps have a small selector of some sorts. Either a plug that pulls off a couple post the include an idicator arrow for where to set the plug for either voltage, or a dial you turn to show it. Either way, you should be able to set the motor for 115 rather easily.
Jun 14, 2009 | Pentair Whisperflo 3/4 Hp 115/230v
Rewiring mootor from 230v down to 115v
Dec 13, 2008 | AO Smith 2 Hp Spl 3450rpm M56 Frame...
Air Tools & Compressors Logo
55 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
