Question about Vocopro UHF-5800 Professional Microphone
Flashing lights on uhf-5800 - Vocopro UHF-5800 Professional Microphone
I need to program a zenith tv to work with the 21.0 ir/uhf pro remote control
I have listed the steps below to assist with programming the remote to your TV. If you have any other questions, let me know at Kimberly.escobar@dish.com!
Look up codes for TV here: http://www.mydish.com/support/apps/remotecodes.aspx?WT.svl=leftnav
1.) Press and hold the clear TV button until all mode lights light up.
2.) Release and TV light will be blinking.
3.) Enter code and press #. The TV button should flash 3 times.
4.) Try functions (Volume, Power, etc..) and see if it is working.
5.) If no function, repeat steps 1-4 with another code.
Feb 14, 2014 | DISH Network ES161256 21.0 IR / UHF Pro...
The vocopro 5800 is constantly losing signal strength and going in and out with movement. How do I fix this problem.
1. Check microphone(s) batteries and replace if the
charge is low.
2 Remove local sources of UHF interference, such as
lighting equipment.
3. Adjust the squelch controls on the front of the UHF-
5800 receiver.
4. Signal may be too weak. If so, reposition antennas.
If possible, move them closer to the transmitter.
5. Reposition the receiver, perform a "walkthrough",
and observe the signal strengths. If audio dropouts
persist, mark these "dead spots" in the operating
area and avoid them during the performance.
If none of these could help it is possible that the device has really some faulty operation and needed to carry it to service center.
gylacz
Mar 18, 2011 | Audio Players & Recorders
On GSM ariena it says the Nokia 5800 has a flash light how do I turn it on and off?
when you select camera of the main menu there is a symbol on the right hand sise of the screen which shows an A with a symbol next to it what reminds me of a bolt of lightening.. if you press that you are given a list of options for the flash. this is on network setting GSM, on a nokia 5800 xpressmusic. hope this helps.
Sep 12, 2010 | Nokia 5800 XpressMusic Smartphone
Problem viewing espn360 on nokia 5800
you cant watch flash player on your , you normal internet browser,you may have to download a different browser like skyfire on the ovi store thats what i did.
Mar 16, 2010 | Nokia 5800 XpressMusic Smartphone
My nokia 5800 xpress screen keeps flashing every 8 seconds but no messages or calls help plz.
You may have set your Nokia to "Breathing"- the slow pulsing light is a kind of "stand by light". See more here: http://thenokiaguide.com/2009/04/28/nokia-5800-xpressmusic-firmware-version-210025-now-available/
Feb 24, 2010 | Nokia 5800 XpressMusic Smartphone
Nokia 5800 wont charge?
Use different charger. When charging leave the phone off. Fully charged after 4 hours.
Jun 10, 2009 | Nokia 5800 XpressMusic Smartphone
78 people viewed this question
Top Vocopro Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Vocopro Audio Player and Recorder Expert? Answer questions, earn points and help others
