Question about Nikon Coolpix SQ Digital Camera
I want to reset date on my nixon camera - Nikon Coolpix SQ Digital Camera
Hi - i need a manual for a nixon The Housing - or how dot I set the time and tide on it
Hi here is the link for all of the nixon manuals
http://www.nixon.com/manuals/index3.html
Kind regards
Sep 12, 2014 | Nixon The Housing Watch
I have a Nixon Lodown and I can't seem to figure out how to save a new tide location. it lets me select a location and then it asks me for the date. After i enter the date it goes back to selecting the...
Has it had a new battery recently? Some of these watches need to be reset properly in order for them to work right, if it has had a new battery this could be your problem. It would need to be reset from inside the watch
Dec 01, 2013 | Nixon Lodown Tide watch
How do i set the date on my nixon sentry
The notch has two positions. when you pull it out completely that is the time adjustment. Now when you pull it just slightly that will be the date setting. Turning it clockwise will change the day and counter clock wise changes the date number. Hope that helps.
I got my watch from a third party w/ out manual cause it was cheaper. Took me awhile to figure out.
Nov 13, 2010 | Nixon Sentry Watch
Help flash Nixon coolpix L11
hello,
make sure when you press the round selection button on the back of the camera flash option, you press the ok in the center of the button on the back.
it will show brief yellow AUTO in the LCD screen upper right corner for a sec.
when you are going to take a picture holding the shutter button half way down, you should see up at the right corner outside of the LCD screen a red led flashing to indicate flash is ready.
one thing to try if this is not working, find the camera reset option in the menu. after doing this you may have to reset the date & time. it will bring the camera back to default settings
on the bad side if these dont work, possible flash circuit may have failed inside the camera.
good luck!
Jun 13, 2008 | Nikon Coolpix L11 Digital Camera
Nixon super rover..need to know how to reset the chronograph
Pull the stem all the way out...like your setting the date. Then hit the upper button and that will move the hand 1 second at a time until it gets here you want.
Feb 14, 2008 | Nixon Super Rover NIX0123
Nikon Coolpix SQ Digital Camera Logo
13 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
