Question about Konica Minolta bizhub Office Equipment & Supplies
How to remove fuser unit of Konica Minolta Bizhub C-450 110 volt m/c
Misfed detected
  • Konica Minolta Master
  • 6,161 Answers
4 Suggested Answers
  • 214 Answers
SOURCE: Konica Minolta bizhub 350 Error c0500
did you do a trouble reset ?
Posted on May 11, 2008
xeerie
  • 347 Answers
SOURCE: desbloqueo del codigo m2 en konica minolta bizhub 163
Este código significa que la vida las partes de su desarrollo + unidad de imagen se ha caducado. Ahora es el momento de reemplazar las partes.
Posted on Jun 19, 2010
hamzaskilltd
  • 316 Answers
SOURCE: Solution for error code c2557 konica minolta bizhub 250 machine
ADTC sensor failure
Posted on Aug 07, 2010
After paper is printed in konica minolta bizhub 164 printing gets rubbed out what is the remedy plese
Because the fuser is not fusing the toner to the paper replace the fuser unit the hot part
Nov 21, 2016 | Konica Minolta Office Equipment & Supplies
What is error code C3102 in Konica Minolta bizhub 552 printers
Fusing roller failure to turn remove the fuser unit check orange rollers bad replace the fuser unit
May 09, 2015 | Konica Minolta Office Equipment & Supplies
How do I replace the fusing unit in Konica Minolta bizhub C253
POWER OFF MACHINE! Open the front door remove one screw from the small access UPPER RIGHT cover disconnect the three connectors two carry 120 VAC other sensor signals the open the right side of the machine two screws below the fuser and remove the unit. reinstall opposite direction. Be careful not to brake the sensor connector
Apr 11, 2015 | Konica Minolta Office Equipment & Supplies
My konica minolta has a false misfeed showing at fuser area
Check all the sensors, the sensor in the fuser unit might be broken, common thing
Sep 06, 2014 | Konica Minolta Bizhub C550
Please wait message on konica minolta bizhub 164 Machine please give me solution if any one knows
CHECK THE THERMISTOR & THERMOFUSE OF THE FUSER UNIT. CLEAN THEM & TRY. IF NOT SOLVED THEN REMOVE ALL THE CONNECTOR FROM THE MOTHER BOARD & REINSTALL THE CONNECTOR & TRY. GOOD LUCK.
Jan 13, 2014 | Konica Minolta bizhub C250 All-In-One...
Mis feed detected
Verify the paper feed drive transmission,the actuators,the duplex unit,the fusing unit.
Please more details when indicated the misfed location?
Feb 21, 2013 | Konica Minolta Bizhub C550
Abort code
contact service use go to www.konicaminolta.com
Oct 06, 2012 | Genuine Konica Minolta Konica Minolta...
Konica minolta bizhub c300 how to reset fuser unit
you need to get a small pico fuse(small green resistor like part on wire harness in fuser. or if your fast you can remove the fuse and short the wires turn on the machine then count to 10 and unshort them. fuser will reset. this is the only way or get a new fuser (too spendy) write me back if you need help.
Nov 21, 2011 | Konica Minolta Office Equipment & Supplies
Put in newer fuser unit but machine still says to replace
If you want to clear the fuser message you have to be sure you replaced the fuser web. Then go to 25 => counter clear(items 13)=> Clear fuser counter or 36=>counter clear(items 8)=>Clear fuser counter.
May 28, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta bizhub 161f remove fuser
Usually a fuser unit isn't a replaceable item by the end user. It requires a service technician to repair because they are wired to a circuit board and there are glass components in them that have to be handled carefully.
Jul 03, 2008 | Konica Minolta bizhub 161f All-In-One...
27 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
